Error while execute DFU example in Mesh SDK
Hi all,
I am testing DFU example in Mesh SDK . I follow this tutorial : http://infocenter.nordicsemi.com/index.jsp . But when I execute to step 4 :
dfu$ python device_page_generator.py -d nrf52832_xxAA -sd "s132_5.0.0"
I get this error :
Any suggestion for this ? I use NRF52832 DK . Thank !!!
  • Hi Giang,
    The issue is that the public key isn’t being converted to a bytearray properly.
    Applying the following diff will solve the problem
    diff --git a/tools/dfu/device_page_generator.py b/tools/dfu/device_page_generator.py
    index 9fa9e6435..a3aa74028 100644
    --- a/tools/dfu/device_page_generator.py
    +++ b/tools/dfu/device_page_generator.py
    @@ -66,7 +66,7 @@ class DevicePageEntry(object):
             #print("Type: ", type(data).__name__)
             if not (isinstance(bl_info_type, BLInfoType) and
                     (isinstance(data, bytearray) or isinstance(data, str))):
    -            raise TypeError
    +            raise TypeError("Invalid type %r" % (type(data)))
             self.bl_info_type = bl_info_type
             if (isinstance(data, str)):
    @@ -96,7 +96,7 @@ class DevicePage(object):
             self.softdevice = softdevice
         def generate_entries(self, platform, softdevice, bootloader_config):
    -        public_key = bootloader_config["public_key"] \
    +        public_key = bytearray.fromhex(bootloader_config["public_key"]) \
                          if "public_key" in bootloader_config else None
             if public_key:
                 self.entries.append(
    Additionally, there was an issue where the device_page_generator.py would always output the same filename (device_page_nrf52832_xxAA_s132_6.0.0.hex). That is fixed with the following diff:
    index a3aa74028..0e8eb9e3d 100644
    @@ -207,7 +207,7 @@ def main():
         for plt in platforms:
             plt_str += ''.join(plt["name"]) + '\n'
    -    SOFTDEVICE = "s132_5.0.0"
    +    SOFTDEVICE = "s132_6.0.0"
         DEVICE = "nrf52832_xxAA"
         parser = argparse.ArgumentParser(description="Device Page Generator")
         parser.add_argument("-d", "--device", help="Select device: " + ''.join(plt_str),
    @@ -217,12 +217,15 @@ def main():
         parser.add_argument("-c", "--bootloader-config",
                             default="bootloader_config_default.json",
                             help="Bootloader configuration file")
    -    parser.add_argument("-o", "--output-file", help="Output hex file",
    -                        default="bin/device_page_%s_%s.hex" % (DEVICE, SOFTDEVICE))
    +    parser.add_argument("-o", "--output-file",
    +                        help="Output hex file (default: bin/device_page_%s_%s.hex)." % ("<DEVICE>", "<SOFTDEVICE>"),
    +                        default=False)
         parser.add_argument("--all", default=False, action="store_true",
                             help=("Writes all known device page combinations to "
                                   + "\'bin/\'"))
         args = parser.parse_args()
    +    if not args.output_file:
    +        args.output_file = "bin/device_page_%s_%s.hex" % (args.device, args.softdevice)
         dirname = os.path.dirname(args.output_file)
         if not os.path.exists(dirname):
    For your convenience I’ve uploaded a copy of the script with the changes applied:
    # Copyright (c) 2010 - 2018, Nordic Semiconductor ASA
    # All rights reserved.
    # Redistribution and use in source and binary forms, with or without
    # modification, are permitted provided that the following conditions are met:
    # 1. Redistributions of source code must retain the above copyright notice, this
    #    list of conditions and the following disclaimer.
    # 2. Redistributions in binary form must reproduce the above copyright
    #    notice, this list of conditions and the following disclaimer in the
    #    documentation and/or other materials provided with the distribution.
    # 3. Neither the name of Nordic Semiconductor ASA nor the names of its
    #    contributors may be used to endorse or promote products derived from this
    #    software without specific prior written permission.
    # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
    # AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
    # IMPLIED WARRANTIES OF MERCHANTABILITY, AND FITNESS FOR A PARTICULAR PURPOSE
    # ARE DISCLAIMED. IN NO EVENT SHALL NORDIC SEMICONDUCTOR ASA OR CONTRIBUTORS BE
    # LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
    # CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
    # SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
    # INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
    # CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
    # ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
    # POSSIBILITY OF SUCH DAMAGE.
    import argparse
    import enum
    import struct
    import intelhex
    import sys
    import json
    import os
    PACKAGE_PARENT = '..'
    SCRIPT_DIR = os.path.dirname(os.path.realpath(os.path.join(os.getcwd(), os.path.expanduser(__file__))))
    sys.path.append(os.path.normpath(os.path.join(SCRIPT_DIR, PACKAGE_PARENT)))
    from deviceutil.deviceutil import \
        get_application_limits, \
        make_bootloader_for_platforms, \
        set_softdevices_for_platforms, \
        load_softdevies, \
        load_platforms
    WORD_SIZE = 4
    class BLInfoType(enum.IntEnum):
        INVALID = 0x00
        ECDSA_PUBLIC_KEY = 0x01
        VERSION = 0x02
        JOURNAL = 0x03
        FLAGS = 0x04
        SEGMENT_SD = 0x10
        SEGMENT_BL = 0x11
        SEGMENT_APP = 0x12
        LAST = 0x7FFF
        def __init__(self, bl_info_type, data):
               data = bytearray.fromhex(data)
            self.data = self.pad(data)
        @property
        def word_count(self):
            return (len(self.data) + WORD_SIZE) // WORD_SIZE
        def pad(self, data):
            pad_byte_count = (WORD_SIZE - len(data) % WORD_SIZE) % WORD_SIZE
            if pad_byte_count > 0:
                data += bytearray([0xFF] * pad_byte_count)
            return data
        def serialize(self):
            return (bytearray(struct.pack('<HH', self.word_count, self.bl_info_type)
                              + self.data))
        def __init__(self, platform, softdevice, bootloader_config):
            self.entries = []
            self.generate_entries(platform, softdevice, bootloader_config)
            self.platform = platform
            if public_key:
                    DevicePageEntry(BLInfoType.ECDSA_PUBLIC_KEY, public_key))
            app_limits = get_application_limits(platform, softdevice)
            app_segment = bytearray(struct.pack("<II",
                                                app_limits["flash_start"],
                                                app_limits["flash_size"]))
            sd_segment = bytearray(struct.pack("<II",
                                               softdevice["flash_start"],
                                               softdevice["flash_size"]))
            bl_segment = bytearray(struct.pack("<II",
                                               platform["bootloader"]["flash_start"],
                                               platform["bootloader"]["flash_size"]))
                DevicePageEntry(BLInfoType.SEGMENT_APP, app_segment))
                DevicePageEntry(BLInfoType.SEGMENT_SD, sd_segment))
                DevicePageEntry(BLInfoType.SEGMENT_BL, bl_segment))
            version_data = bytearray(struct.pack("<HBBIHI",
                                                 int(softdevice["version"], 16),
                                                 bootloader_config["bootloader_id"],
                                                 bootloader_config["bootloader_version"],
                                                 bootloader_config["company_id"],
                                                 bootloader_config["application_id"],
                                                 bootloader_config["application_version"]))
            #print(version_data)
            self.entries.append(DevicePageEntry(BLInfoType.VERSION,
                                                version_data))
            self.entries.append(DevicePageEntry(BLInfoType.FLAGS,
                                                bytearray(struct.pack('I', 0xFFFFFFFF))))
        def write_hex(self, hexfile):
            # Info page metadata
            raw_data = bytearray(struct.pack("<BBBB", 4, 1, 8, 8))
            raw_data += bytearray().join(map(DevicePageEntry.serialize, self.entries))
            raw_data += bytearray(struct.pack("<HH", 0xFFFF, BLInfoType.LAST))
            hex_output = intelhex.IntelHex()
            hex_output.frombytes(raw_data,
                                 self.platform["flash_size"] - self.platform["page_size"])
            hex_output.tofile(hexfile, "hex")
    def write_specific_page(platforms, softdevices, args):
        platform = next((p for p in platforms if args.device == p["name"]), None)
        if not platform:
            print("Unknown device: \"%s\" in list %r" % (args.device, [p["name"] for p in platforms]))
            sys.exit(1)
        softdevice = next((s for s in softdevices if args.softdevice == s["name"]), None)
        if not softdevice:
            print("Unknown SoftDevice: \"%s\"" % (args.softdevice))
            sys.exit(1)
        if args.softdevice not in platform["softdevices"]:
            print("Unknown SoftDevice \"%s\" for platform \"%s\"" %
                  (args.softdevice, args.device))
            sys.exit(1)
        # Filter out the others...
        platforms = [p for p in platforms
                     if args.device.lower() in p["name"].lower()]
        make_bootloader_for_platforms(platforms)
        set_softdevices_for_platforms(platforms, softdevices)
        # Dict is updated by reference
        # platform = platforms[args.device]
        # softdevice = softdevices[args.softdevice]
        with open(args.bootloader_config, "r") as f:
            bootloader_config = json.load(f)["bootloader_config"]
        device_page = DevicePage(platform, softdevice, bootloader_config)
            args.output_file = "_".join(["device_page",
                                         self.platform["name"],
                                         self.softdevice["name"]]) + ".hex"
        device_page.write_hex(args.output_file)
    def write_all(platforms, softdevices, args):
        for platform in platforms:
            for softdevice in platform["softdevices"]:
    def main():
        softdevices = load_softdevies("../configuration/softdevices.json")
        platforms = load_platforms("../configuration/platforms.json")
        sd_str = ''
        for sd in softdevices:
            sd_str += ''.join(sd["name"]) + "\n"
        plt_str = ''
                            default=DEVICE)
        parser.add_argument("-sd", "--softdevice", help="Select SoftDevice: "  + ''.join(sd_str),
                            default=SOFTDEVICE)
                            default=False)
                                  + "\'bin/\'"))
            os.mkdir(dirname)
        if args.all:
            print("Wrote for device pages for all devices.")
        elif args.softdevice and args.device:
            print("Wrote device page for %s with the %s SoftDevice to %s." %
                  (args.device, args.softdevice, args.output_file))
    if __name__ == "__main__":
        main()
    Best,
    Thomas
