S140 6.0.0 SCANNING ISSUE
Hi All!
Faced with big problem with SCANNING procedure (nRF52840)
We have a BLE network : one CENTRAL and up to 6 PERIPHERALs can be connected simultaneously to the CENTRAL.
Advertising period of Peritherals is 1 second.
THE PROBLEM:
if no connected devices, CENTRAL report "BLE_GAP_EVT_ADV_REPORT" occur each 1 sec very STABLE.
if connections established, CENTRAL report "BLE_GAP_EVT_ADV_REPORT" very not stable sometimes with 5..6 seconds delay , depends on conenction count.
SCANNING PARAM:
#define _SCANPARAM_ {                                         \
    .active   = 1,                                            \
    .interval = (uint16_t) MSEC_TO_UNITS(20, UNIT_0_625_MS),  \
    .window   = (uint16_t) MSEC_TO_UNITS(20, UNIT_0_625_MS),  \
    .timeout          = BLE_GAP_SCAN_TIMEOUT_UNLIMITED,       \
    .scan_phys        = BLE_GAP_PHY_1MBPS,                    \
    .filter_policy    = BLE_GAP_SCAN_FP_ACCEPT_ALL,           \
CONNECTIN PARAM:
#define _CONN_PARM_PREFF_ {
         .min_conn_interval = (uint16_t) MSEC_TO_UNITS(65, UNIT_1_25_MS), \
         .max_conn_interval = (uint16_t) MSEC_TO_UNITS(65, UNIT_1_25_MS), \
         .slave_latency     = 0,                                          \
         .conn_sup_timeout  = (uint16_t) MSEC_TO_UNITS(1000,UNIT_10_MS) } \
HOW to provide stable ADV report during CONNECTIONs or it is IMPOSSIBLE ?
waiting for answer.
    Having a short scanning interval means that the softdevice has to change channel more often. Can you please try to increase the scanning interval a bit. Just for testing, try to set both the .interval and .window to something like 0x0FFF.
    BR,
    Edvin
  • Hi Edvin,
    I tested > 100  variants, in my case, stable result only with use;
    .interval = 3200 , .window  = 2615
    all other cases work very unstable (10/10, 20/20, 0xfff/0xfff, 3200/3200, 3200/2000, etc ....)
    Please, exlain how it does work.
    .. also, I find after ~ 2 minutes , Scanning again becomes unstable until RESET...
    Sorry for the late reply. I just wanted to let you know that I have to check what the softdevice does with the scanning when it is in a connection, and gets a connection event within the scan interval. I am not sure whether it resumes the scanning afterwards, or if it waits for the next scan interval to resume the scanning.
    I will come back to you as soon as I know anything.
    BR,
    Edvin
    Please see Section 15.4 in the S140 v6 SoftDevice Specification.
    Also note that there have been some issues with a too long scanning interval. Set it below 16.7 seconds to be sure.
    But as you see in section 15.4 (Scheduling -> scanner timing), if you set the scan window longer than:
    Scan window = connection interval - ( Σt_[connection event] + t_[scan_reserved]) you may loose a connection event, resulting in a lost connection unless you have slave latency.
    You can try to increase your advertising interval to increase the chance of detecting an advertisement. This will cost a bit more power while advertising, but that is a cost of increasing the chance to be detected sooner.
    Advertising and scanning is not a way of communication that is guaranteed to be detected at once, since the communication is not synchronized. See the advertising and scanning timing scheduling in the SoftDevice Specification.
    Edvin
