Interrupt based temperature sensor on nrf52840 using SDK v15.0.0
I have to implement temperature sensor readings continuously through interrupts instead of busy waiting example in SDK in order to notify those values over BLE to cloud.
I took code in below reference and compiled in SDK v15.0.0 on nrf52840.
https://devzone.nordicsemi.com/f/nordic-q-a/15729/nrf51822-tempeture-based-on-interrupt
Below is code and issue comes after running statement NRF_TEMP->TASKS_START = 1; in main function code is going to  NRF_BREAKPOINT_COND; in app_error_fault_handler function.
What is reason and to be implemented to get it worked
static void temp_init(void){
NRF_TEMP->INTENSET |= TEMP_INTENSET_DATARDY_Enabled;
sd_nvic_SetPriority(TEMP_IRQn, APP_IRQ_PRIORITY_LOWEST);
sd_nvic_EnableIRQ(TEMP_IRQn);
/* Interrupt handler for TEMP data ready event */
void TEMP_IRQHandler(void){
int32_t volatile temp;
NRF_TEMP->EVENTS_DATARDY = 0;
/**@note Workaround for PAN_028 rev2.0A anomaly 29 - TEMP: Stop task clears the TEMP register. */
temp = (nrf_temp_read() / 4);
/**@note Workaround for PAN_028 rev2.0A anomaly 30 - TEMP: Temp module analog front end does not power down when DATARDY event occurs. */
NRF_TEMP->TASKS_STOP = 1; /** Stop the temperature measurement. */
ble_temps_measurement_send(&m_temps, temp);// function to send notifications
nrf_temp_init();
temp_init();
// Initialisions.......
advertising_start();
NRF_TEMP->TASKS_START = 1; /** Start the temperature measurement. */
for (;;)
idle_state_handle();
