Problem with frame length to sent of APP
I am developing a system where I have a app and a Rigado BMD-300 Module. I am using, for experiment, the nRF Connect App and in program, I use SDK 14.2 and s132 softdevice.
My question is that I want sending 5 bytes (40 bits) but the App only permite sending 4 bytes (32 bits).
I don't understand if my problem is in APP or in my code.
I believe that it is in APP and/or in definition of parameter GATT because I got following error when I send a frame: error 13 (0xd): GATT INVALID ATTR LEN.
I, also, thought that can to be limitation of Bluetooth but I don't no idea.
I want help for understand the error and I want meet a solution for problem.
Thanks and the best regards,
Daniel Fernandes
  • Hi Daniel,
    can you post the snippet from the application code where you add the characteristic that you're trying to write to? I want to make sure that the size of the characteristic is set 5 and not 4.
    Best regards
    Bjørn
  • I don't know if I understand your question, but I send this short part of my code.
    static uint32_t our_char_add(ble_os_t * p_our_service, ble_gatts_char_handles_t* p_chandle, uint16_t chuuid, bool notifyenabled, bool writeenabled, uint32_t* p_value)
        uint32_t            err_code;
        ble_uuid_t          char_uuid;
        ble_uuid128_t       base_uuid = BLE_UUID_OUR_BASE_UUID;
        char_uuid.uuid = chuuid;
        err_code = sd_ble_uuid_vs_add(&base_uuid, &char_uuid.type);
        // Add read only properties to our characteristic
        ble_gatts_char_md_t char_md;
        memset(&char_md, 0, sizeof(char_md));
        char_md.char_props.read = 1;
        char_md.char_props.write = 0;
        if (notifyenabled) {
            // Configuring Client Characteristic Configuration Descriptor metadata
            // for notification and add to char_md structure
            // This should be read/write
            static ble_gatts_attr_md_t cccd_md;
            memset(&cccd_md, 0, sizeof(cccd_md));
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
            cccd_md.vloc                = BLE_GATTS_VLOC_STACK;
            char_md.p_cccd_md           = &cccd_md;
            char_md.char_props.notify   = 1;
        // Configure the attribute metadata
        ble_gatts_attr_md_t attr_md;
        memset(&attr_md, 0, sizeof(attr_md));
        attr_md.vloc        = BLE_GATTS_VLOC_USER; // user provided location
        // Set read/write security levels to our characteristic
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
        if (writeenabled) {
            char_md.char_props.write = 1;
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
        } else {
            BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&attr_md.write_perm);
        // Configure the characteristic value attribute
        ble_gatts_attr_t    attr_char_value;
        memset(&attr_char_value, 0, sizeof(attr_char_value));
        attr_char_value.p_uuid      = &char_uuid;
        attr_char_value.p_attr_md   = &attr_md;
        // Define characteristic length (in number of bytes) and set
        // initial value to whatever passed to here
        attr_char_value.max_len     = 4;
        attr_char_value.init_len    = 4;
        attr_char_value.p_value     = (uint8_t *)p_value;
        // Add our new characteristic to the service
        err_code = sd_ble_gatts_characteristic_add(p_our_service->service_handle,
                                                    &char_md,
                                                    &attr_char_value,
                                                    p_chandle);
        return NRF_SUCCESS;
  • Exactly what I wanted. In your code you'll see that the length of the characteristic value is set to 4, i.e. 4 bytes.
    If you change this to
    attr_char_value.max_len = 5;
    attr_char_value.init_len = 5;
    Then you should be able to write 5bytes to the characteristic.
    Best regards
    Bjørn
  • Thanks, I didn't already remember this part of code. When, I sent for you this part of code and I saw this lines I did remember that it are this.
  • OK, are you now able to write 5 bytes to the characteristic?
