difference with ble_app_uart and hrs_pairing_nfc
Hello.
I'm having to merge with ble_app_uart and hrs_pairing_nfc example. But, happend some problem.
I succeeded in merge by adding ble_app_uart example to the hrs_pairing_nfc example. it works very well.
However, in the opposite case, nfc does not work even if the same code is activated. (it same path, project file configuration, C/C++ include path ...)
below I attached J-LINK log.
1. succeeded in mergy by adding ble_app_uart -> hrs_pairing_nfc (base on hrs)
it send to normal message that field detected -> selected -> rx_fend -> send ... reinitialize
2.failed in mergy by adding hrs_pairing_nfc ->  ble_app_uart (base on ble_app_uart)
I think it detects the nfc field but falls in to an infinite loop.
I don't know this reason. I will wait your answer.
thanks.
