I'm using JLinkRTTViewer to look at RTT output from my code.
The problem is that when I try to go into POWER_OFF, it generates a reset instead.
Is there a way to go into power off and then reconnect the SWD interface after it wakes up?
Thanks!
Thanks!
Systemoff will generate a reset when you wake up, which may introduce issues with your current RTT session.
Note, when going into systemoff when in debug mode it is recommended to add a infinite loop afterwards. More detailed explanation can be found here:
Håkon
