We used nRF5_SDK_15.0.0_a53641a and nrf5_SDK_for_Mesh_v2.0.0_src.
We are following DFU quick start guide http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.meshsdk.v0.10.0%2Findex.html
For nRF52:
For nRF52:
You were fine to skip step 8, as the mesh stack has already been built before being uploaded as a zip file to the nordic semi homepage. Did you use the dfu_nrf52832_xxAA_s132_6_0_0 segger project to build the dfu example? If so, then you will need to make sure all of the steps before 8 also use the s132 softdevice version 6. I believe you have used version 5 up until this point. Did you flash the program via nrfjprog or via segger embedded studio (SES) directly? If you used SES, then you will have flashed the softdevice to the device again, which is not a good idea. I would build the example with SES & then program the hex file located in the build folder via nrfjprog (like shown in step 8).
I believe the reason you are getting the serial port error is that you are not running the cmd prompt as an administrator. You can start command prompt as an administrator by searching for "cmd", right click on the command prompt icon & run as administrator.
We started command prompt on an administrator. I have make sure all the steps before and after step 8 using s132 softdevice version 6.0. We tried to flash the program via both SES and nrfjprog (like shown in step 8). We also used difference Bud rate 115200, 57600, 38400, 19200, 14400 and 9600.
Attached are the cmd script file
Microsoft Windows [Version 6.1.7601] Copyright (c) 2009 Microsoft Corporation. All rights reserved. C:\Users\ALaw>cd C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>nrfutil keys --gen-key private_key.txt Generated key at: private_key.txt C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>nrfutil keys --show-vk hex private_key.tx t Verification key Qx: d78ea2728b31c63b185402f4209803b478d0828b02a0f44da9f5d782b04 7fe45 Verification key Qy: b60bf4db2e572b4b6053c0c7e9371b309c93ee53c300906afc6c7f2d99c e11cd C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>nrfutil dfu genpkg --application bin/blin ky/blinky_nrf52832_xxAA_s132_6.0.0.hex --company-id 0x00000059 --application-id 1 --application-version 2 --key-file private_key.txt --sd-req 0x009D --mesh dfu_ test.zip Key file was given, setting DFU version to 0.8 Zip created at dfu_test.zip C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>cd tools/dfu C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src\tools\dfu>python device_page_generator.py -d nrf52832_xxAA -sd "s132_6.0.0" Wrote device page for nrf52832_xxAA with the s132_6.0.0 SoftDevice to bin/device _page_nrf52832_xxAA_s132_6.0.0.hex. C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src\tools\dfu>cd .. C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src\tools>cd .. C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>nrfjprog --eraseall Erasing user available code and UICR flash areas. Applying system reset. C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>nrfjprog --program bin/softdevice/s132_nr f52_6.0.0_softdevice.hex --chiperase Parsing hex file. Erasing user available code and UICR flash areas. Applying system reset. Checking that the area to write is not protected. Programming device. C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>nrfjprog --program bin/bootloader/armcc/m esh_bootloader_serial_armcc__nrf52832_xxAA.hex Parsing hex file. ERROR: The file specified could not be found. C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>nrfjprog --program bin/bootloader/armcc/m esh_bootloader_serial_armcc_nrf52832_xxAA.hex Parsing hex file. Reading flash area to program to guarantee it is erased. Checking that the area to write is not protected. Programming device. C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>nrfjprog --program examples\dfu\build\dfu _nrf52832_xxAA_s132_6.0.0_Debug\dfu_nrf52832_xxAA_s132_6.0.0.hex Parsing hex file. Reading flash area to program to guarantee it is erased. Checking that the area to write is not protected. Programming device. C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>nrfjprog --program tools/dfu/bin/device_p age_nrf52832_xxAA_s132_6.0.0.hex Parsing hex file. Reading flash area to program to guarantee it is erased. Checking that the area to write is not protected. Programming device. C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>nrfjprog --reset Applying system reset. Run. C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>nrfutil dfu serial -pkg dfu_test.zip -p C OM46 -b 115200 -fc --mesh Upgrading target on COM46 with DFU package C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_sr c\dfu_test.zip. Flow control is enabled. [------------------------------------] 0% Failed to upgrade target. Error is: Failed to establish connection Possible causes: - bootloader, SoftDevice or application on target does not match the requirement s in the DFU package. - baud rate or flow control is not the same as in the target bootloader. - target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode. C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>nrfutil --verbose dfu serial -pkg dfu_tes t.zip -p COM46 -b 115200 -fc --mesh Upgrading target on COM46 with DFU package C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_sr c\dfu_test.zip. Flow control is enabled. [------------------------------------] 0%Flushing com-port... Opened com-port Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, applicat ion size: 1912 Sending DFU start packet, afterwards we wait for the flash on target to be initi alized before continuing. PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd Failed to upgrade target. Error is: Failed to establish connection Possible causes: - bootloader, SoftDevice or application on target does not match the requirement s in the DFU package. - baud rate or flow control is not the same as in the target bootloader. - target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode. Closing serial port... C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>nrfutil dfu serial -pkg dfu_test.zip -p C OM46 -b 57600 -fc --mesh Upgrading target on COM46 with DFU package C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_sr c\dfu_test.zip. Flow control is enabled. [------------------------------------] 0% Failed to upgrade target. Error is: Failed to establish connection Possible causes: - bootloader, SoftDevice or application on target does not match the requirement s in the DFU package. - baud rate or flow control is not the same as in the target bootloader. - target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode. C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>nrfutil --verbose dfu serial -pkg dfu_tes t.zip -p COM46 -b 38400 -fc --mesh Upgrading target on COM46 with DFU package C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_sr c\dfu_test.zip. Flow control is enabled. [------------------------------------] 0%Flushing com-port... Opened com-port Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, applicat ion size: 1912 Sending DFU start packet, afterwards we wait for the flash on target to be initi alized before continuing. PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd Failed to upgrade target. Error is: Failed to establish connection Possible causes: - bootloader, SoftDevice or application on target does not match the requirement s in the DFU package. - baud rate or flow control is not the same as in the target bootloader. - target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode. Closing serial port... C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>nrfutil --verbose dfu serial -pkg dfu_tes t.zip -p COM46 -b 19200 -fc --mesh Upgrading target on COM46 with DFU package C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_sr c\dfu_test.zip. Flow control is enabled. [------------------------------------] 0%Flushing com-port... Opened com-port Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, applicat ion size: 1912 Sending DFU start packet, afterwards we wait for the flash on target to be initi alized before continuing. PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd Failed to upgrade target. Error is: Failed to establish connection Possible causes: - bootloader, SoftDevice or application on target does not match the requirement s in the DFU package. - baud rate or flow control is not the same as in the target bootloader. - target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode. Closing serial port... target -> PC: e8 C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>nrfutil --verbose dfu serial -pkg dfu_tes t.zip -p COM46 -b 14400 -fc --mesh Upgrading target on COM46 with DFU package C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_sr c\dfu_test.zip. Flow control is enabled. [------------------------------------] 0%Flushing com-port... Opened com-port Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, applicat ion size: 1912 Sending DFU start packet, afterwards we wait for the flash on target to be initi alized before continuing. PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd Failed to upgrade target. Error is: Failed to establish connection Possible causes: - bootloader, SoftDevice or application on target does not match the requirement s in the DFU package. - baud rate or flow control is not the same as in the target bootloader. - target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode. Closing serial port... C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>nrfutil --verbose dfu serial -pkg dfu_tes t.zip -p COM46 -b 9600 -fc --mesh Upgrading target on COM46 with DFU package C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_sr c\dfu_test.zip. Flow control is enabled. [------------------------------------] 0%Flushing com-port... Opened com-port Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, applicat ion size: 1912 Sending DFU start packet, afterwards we wait for the flash on target to be initi alized before continuing. PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd PC -> target: 0502aabbccdd Failed to upgrade target. Error is: Failed to establish connection Possible causes: - bootloader, SoftDevice or application on target does not match the requirement s in the DFU package. - baud rate or flow control is not the same as in the target bootloader. - target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode. Closing serial port... C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src> C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src>
Step 1: private_key.txt
-----BEGIN EC PRIVATE KEY----- MHcCAQEEIHPeFxystPEoiZd7uOpCqfRxyO69QavgEeIowj7u+fp2oAoGCCqGSM49 AwEHoUQDQgAE146icosxxjsYVAL0IJgDtHjQgosCoPRNqfXXgrBH/kW2C/TbLlcr S2BTwMfpNxswnJPuU8MAkGr8bH8tmc4RzQ== -----END EC PRIVATE KEY-----
Step 2: bootloader_config_default.json
"bootloader_config": {
"bootloader_id": 1,
"bootloader_version": 1,
"company_id": 89,
"application_id": 1,
"application_version": 1,
"public_key":
"d78ea2728b31c63b185402f4209803b478d0828b02a0f44da9f5d782b047fe45b60bf4db2e572b4b6053c0c7e9371b309c93ee53c300906afc6c7f2d99ce11cd"
Step 3: dfu_test.zip dfu_test.zip
Step 4: Modified dfu_nrf52832_xxAA_s132_6.0.0.py from 5.0.0 to 6.0.0
# Copyright (c) 2010 - 2018, Nordic Semiconductor ASA
# All rights reserved.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are met:
# 1. Redistributions of source code must retain the above copyright notice, this
# list of conditions and the following disclaimer.
# 2. Redistributions in binary form must reproduce the above copyright
# notice, this list of conditions and the following disclaimer in the
# documentation and/or other materials provided with the distribution.
# 3. Neither the name of Nordic Semiconductor ASA nor the names of its
# contributors may be used to endorse or promote products derived from this
# software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
# IMPLIED WARRANTIES OF MERCHANTABILITY, AND FITNESS FOR A PARTICULAR PURPOSE
# ARE DISCLAIMED. IN NO EVENT SHALL NORDIC SEMICONDUCTOR ASA OR CONTRIBUTORS BE
# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
# POSSIBILITY OF SUCH DAMAGE.
import argparse
import enum
import struct
import intelhex
import sys
import json
import os
PACKAGE_PARENT = '..'
SCRIPT_DIR = os.path.dirname(os.path.realpath(os.path.join(os.getcwd(), os.path.expanduser(__file__))))
sys.path.append(os.path.normpath(os.path.join(SCRIPT_DIR, PACKAGE_PARENT)))
from deviceutil.deviceutil import \
get_application_limits, \
make_bootloader_for_platforms, \
set_softdevices_for_platforms, \
load_softdevies, \
load_platforms
WORD_SIZE = 4
class BLInfoType(enum.IntEnum):
INVALID = 0x00
ECDSA_PUBLIC_KEY = 0x01
VERSION = 0x02
JOURNAL = 0x03
FLAGS = 0x04
SEGMENT_SD = 0x10
SEGMENT_BL = 0x11
SEGMENT_APP = 0x12
LAST = 0x7FFF
class DevicePageEntry(object):
def __init__(self, bl_info_type, data):
#print("Type: ", type(data).__name__)
if not (isinstance(bl_info_type, BLInfoType) and
(isinstance(data, bytearray) or isinstance(data, str))):
raise TypeError("Invalid type %r" % (type(data)))
self.bl_info_type = bl_info_type
if (isinstance(data, str)):
data = bytearray.fromhex(data)
self.data = self.pad(data)
@property
def word_count(self):
return (len(self.data) + WORD_SIZE) // WORD_SIZE
def pad(self, data):
pad_byte_count = (WORD_SIZE - len(data) % WORD_SIZE) % WORD_SIZE
if pad_byte_count > 0:
data += bytearray([0xFF] * pad_byte_count)
return data
def serialize(self):
return (bytearray(struct.pack('<HH', self.word_count, self.bl_info_type)
+ self.data))
class DevicePage(object):
def __init__(self, platform, softdevice, bootloader_config):
self.entries = []
self.generate_entries(platform, softdevice, bootloader_config)
self.platform = platform
self.softdevice = softdevice
def generate_entries(self, platform, softdevice, bootloader_config):
public_key = bytearray.fromhex(bootloader_config["public_key"]) \
if "public_key" in bootloader_config else None
if public_key:
self.entries.append(
DevicePageEntry(BLInfoType.ECDSA_PUBLIC_KEY, public_key))
app_limits = get_application_limits(platform, softdevice)
app_segment = bytearray(struct.pack("<II",
app_limits["flash_start"],
app_limits["flash_size"]))
sd_segment = bytearray(struct.pack("<II",
softdevice["flash_start"],
softdevice["flash_size"]))
bl_segment = bytearray(struct.pack("<II",
platform["bootloader"]["flash_start"],
platform["bootloader"]["flash_size"]))
DevicePageEntry(BLInfoType.SEGMENT_APP, app_segment))
DevicePageEntry(BLInfoType.SEGMENT_SD, sd_segment))
DevicePageEntry(BLInfoType.SEGMENT_BL, bl_segment))
version_data = bytearray(struct.pack("<HBBIHI",
int(softdevice["version"], 16),
bootloader_config["bootloader_id"],
bootloader_config["bootloader_version"],
bootloader_config["company_id"],
bootloader_config["application_id"],
bootloader_config["application_version"]))
#print(version_data)
self.entries.append(DevicePageEntry(BLInfoType.VERSION,
version_data))
self.entries.append(DevicePageEntry(BLInfoType.FLAGS,
bytearray(struct.pack('I', 0xFFFFFFFF))))
def write_hex(self, hexfile):
# Info page metadata
raw_data = bytearray(struct.pack("<BBBB", 4, 1, 8, 8))
raw_data += bytearray().join(map(DevicePageEntry.serialize, self.entries))
raw_data += bytearray(struct.pack("<HH", 0xFFFF, BLInfoType.LAST))
hex_output = intelhex.IntelHex()
hex_output.frombytes(raw_data,
self.platform["flash_size"] - self.platform["page_size"])
hex_output.tofile(hexfile, "hex")
def write_specific_page(platforms, softdevices, args):
platform = next((p for p in platforms if args.device == p["name"]), None)
if not platform:
print("Unknown device: \"%s\" in list %r" % (args.device, [p["name"] for p in platforms]))
sys.exit(1)
softdevice = next((s for s in softdevices if args.softdevice == s["name"]), None)
if not softdevice:
print("Unknown SoftDevice: \"%s\"" % (args.softdevice))
sys.exit(1)
if args.softdevice not in platform["softdevices"]:
print("Unknown SoftDevice \"%s\" for platform \"%s\"" %
(args.softdevice, args.device))
sys.exit(1)
# Filter out the others...
platforms = [p for p in platforms
if args.device.lower() in p["name"].lower()]
make_bootloader_for_platforms(platforms)
set_softdevices_for_platforms(platforms, softdevices)
# Dict is updated by reference
# platform = platforms[args.device]
# softdevice = softdevices[args.softdevice]
with open(args.bootloader_config, "r") as f:
bootloader_config = json.load(f)["bootloader_config"]
device_page = DevicePage(platform, softdevice, bootloader_config)
if not args.output_file:
args.output_file = "_".join(["device_page",
self.platform["name"],
self.softdevice["name"]]) + ".hex"
device_page.write_hex(args.output_file)
def write_all(platforms, softdevices, args):
for platform in platforms:
for softdevice in platform["softdevices"]:
def main():
softdevices = load_softdevies("../configuration/softdevices.json")
platforms = load_platforms("../configuration/platforms.json")
sd_str = ''
for sd in softdevices:
sd_str += ''.join(sd["name"]) + "\n"
plt_str = ''
for plt in platforms:
plt_str += ''.join(plt["name"]) + '\n'
SOFTDEVICE = "s132_6.0.0"
DEVICE = "nrf52832_xxAA"
parser = argparse.ArgumentParser(description="Device Page Generator")
parser.add_argument("-d", "--device", help="Select device: " + ''.join(plt_str),
default=DEVICE)
parser.add_argument("-sd", "--softdevice", help="Select SoftDevice: " + ''.join(sd_str),
default=SOFTDEVICE)
parser.add_argument("-c", "--bootloader-config",
default="bootloader_config_default.json",
help="Bootloader configuration file")
parser.add_argument("-o", "--output-file", help="Output hex file",
default="bin/device_page_%s_%s.hex" % (DEVICE, SOFTDEVICE))
parser.add_argument("--all", default=False, action="store_true",
help=("Writes all known device page combinations to "
+ "\'bin/\'"))
args = parser.parse_args()
dirname = os.path.dirname(args.output_file)
if not os.path.exists(dirname):
os.mkdir(dirname)
if args.all:
print("Wrote for device pages for all devices.")
elif args.softdevice and args.device:
print("Wrote device page for %s with the %s SoftDevice to %s." %
(args.device, args.softdevice, args.output_file))
if __name__ == "__main__":
main()
to generate
device_page_nrf52832_xxAA_s132_6.0.0.hex device_page_nrf52832_xxAA_s132_6.0.0.hex
Step 6: s132_nrf52_6.0.0_softdevice.hex s132_nrf52_6.0.0_softdevice.hex
Step 7: s132_nrf52_6.0.0_softdevice.hex mesh_bootloader_serial_armcc_nrf52832_xxAA.hex
Step 8: Program device using nrfjprog to download dfu_nrf52832_xxAA_s132_6.0.0.hex dfu_nrf52832_xxAA_s132_6.0.0.hexdfu_nrf52832_xxAA_s132_6.0.0.map
Step 9: Program device_page_nrf52832_xxAA_s132_6.0.0.hex device_page_nrf52832_xxAA_s132_6.0.0.hex
Step 10: We tried difference Baud Rates, press Button 4 and RESET and release both to enter DFU mode and use s132 and version 6.0.0, still got
"Error is: Failed to establish connection"
Please advise. Thanks.
Sorry for the delayed response. This error could be due to an error in the device_page_generator.py script. I have mentioned this to the developers & will let you know when I receive an update. I unfortunately do not have a better answer than this at the moment. Will keep you posted.
I got a few tips from a Mesh developer here at Nordic:
"The original issue seems to be an error in the json file. Looks like there is an extra "}" at the end, maybe.
Next, is the customer sure that the com port used is the correct com port?
The SEGGER DFU build had a known issue with the flash_placement.xml file. I would advise the customer to use some of the pre-compiled binaries to test the DFU first."
But I believe you have fixed the first issue, correct? I also believe you are using the correct com port & I believe you have used the pre-compiled binaries & not your own built hex files.
I am not sure these tips will help all too much, but it's worth giving it a shot!
To reply to your suggestions:
Please ask your Mesh developer continue working on this until a solution. Thanks
