Get private Bluetooth device address
I am reading through IETF RFC7668, IPv6 over BLUETOOTH(R) Low Energy. In section 3.2.2, it states the following:
At network interface initialization, both 6LN and 6LBR SHALL generate
and assign to the Bluetooth LE network interface IPv6 link-local
addresses [RFC4862] based on the 48-bit Bluetooth device addresses
(see Section 2.3) that were used for establishing the underlying
Bluetooth LE connection. A 6LN and a 6LBR are RECOMMENDED to use
private Bluetooth device addresses. A 6LN SHOULD pick a different
Bluetooth device address for every Bluetooth LE connection with a
6LBR, and a 6LBR SHOULD periodically change its random Bluetooth
device address.
With the newest nRF5 SDK (v15), there is currently no way to get a private address, so that it's not possible to follow this recommendation, correct?
Is it possible to manually set a private address? I believe this used to be possible by using sd_ble_gap_address_set() with cycle mode set to BLE_GAP_ADDR_CYCLE_MODE_NONE.
