I am trying to merge ble_app_uart with light switch server example by following this link. But while building I am getting the following errors.
I am using SES to build it.
Any help would be appreciated.
The structures are defined in nrf_uarte.h
Have you made sure path to nrf_uarte.h is included in the User directories ?
How did you integrate Mesh and BLE ? You add Mesh into BLE project or vice versa ?
Have you made sure you enable NRFX_UARTE inside sdk_config.h ?
I have solved that issue was with adding the user directory... I have integrated mesh into BLE but now I am getting errors like undefined reference to some functions. I have added all the files as mentioned in the documentation made appropriate changes as well. Please look into my code and the errors as well.
* Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "app_error.h"
#include "app_uart.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "ble_advdata.h"
#include "ble_nus_c.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "boards.h"
#include "simple_hal.h"
#include "log.h"
#include "access_config.h"
#include "simple_on_off_server.h"
#include "light_switch_example_common.h"
#include "mesh_app_utils.h"
#include "net_state.h"
#include "rtt_input.h"
#include "mesh_stack.h"
#include "mesh_softdevice_init.h"
#include "mesh_provisionee.h"
#include "nrf_mesh_config_examples.h"
#include "nrf_mesh_configure.h"
#include "nrf_mesh_events.h"
#include "nrf_nvic.h"
#define RTT_INPUT_POLL_PERIOD_MS (100)
#define LED_PIN_NUMBER (BSP_LED_0)
#define LED_PIN_MASK (1u << LED_PIN_NUMBER)
#define LED_BLINK_INTERVAL_MS (200)
#define LED_BLINK_CNT_START (2)
#define LED_BLINK_CNT_RESET (3)
#define LED_BLINK_CNT_PROV (4)
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag that refers to the BLE stack configuration we set with @ref sd_ble_cfg_set. Default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shoulnd't need to modify this value. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW 0x001E /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION 0x0000 /**< Timout when scanning. 0x0000 disables timeout. */
#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Determines minimum connection interval in millisecond. */
#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Determines maximum connection interval in millisecond. */
#define SLAVE_LATENCY 0 /**< Determines slave latency in counts of connection events. */
#define SUPERVISION_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 millisecond. */
#define ECHOBACK_BLE_UART_DATA 1 /**< Echo the UART data that is received over the Nordic UART Service back to the sender. */
BLE_NUS_C_DEF(m_ble_nus_c); /**< BLE NUS service client instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc); /**< DB discovery module instance. */
#define MESH_SOC_OBSERVER_PRIO 0
static void mesh_soc_evt_handler(uint32_t evt_id, void * p_context)
nrf_mesh_on_sd_evt(evt_id);
NRF_SDH_SOC_OBSERVER(m_mesh_soc_observer, MESH_SOC_OBSERVER_PRIO, mesh_soc_evt_handler, NULL);
static simple_on_off_server_t m_server;
static bool m_device_provisioned;
static void node_reset(void);
static void mesh_init(void);
static void config_server_evt_cb(const config_server_evt_t * p_evt);
static void provisioning_complete_cb(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
dsm_local_unicast_address_t node_address;
dsm_local_unicast_addresses_get(&node_address);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
hal_led_mask_set(LEDS_MASK, LED_MASK_STATE_OFF);
hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
/**@brief Connection parameters requested for connection. */
static ble_gap_conn_params_t const m_connection_param =
(uint16_t)MIN_CONNECTION_INTERVAL, // Minimum connection
(uint16_t)MAX_CONNECTION_INTERVAL, // Maximum connection
(uint16_t)SLAVE_LATENCY, // Slave latency
(uint16_t)SUPERVISION_TIMEOUT // Supervision time-out
static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
/**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
static ble_data_t m_scan_buffer =
m_scan_buffer_data,
/** @brief Parameters used when scanning. */
static ble_gap_scan_params_t const m_scan_params =
.active = 1,
.interval = SCAN_INTERVAL,
.window = SCAN_WINDOW,
.timeout = SCAN_DURATION,
.scan_phys = BLE_GAP_PHY_1MBPS,
.filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
/**@brief NUS uuid. */
static ble_uuid_t const m_nus_uuid =
.uuid = BLE_UUID_NUS_SERVICE,
.type = NUS_SERVICE_UUID_TYPE
/**@brief Function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function to start scanning. */
static void scan_start(void)
ret_code_t ret;
ret = sd_ble_gap_scan_start(&m_scan_params, &m_scan_buffer);
APP_ERROR_CHECK(ret);
ret = bsp_indication_set(BSP_INDICATE_SCANNING);
/**@brief Function for handling database discovery events.
* @details This function is callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function should forward the events
* to their respective services.
* @param[in] p_event Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
/**@brief Function for handling characters received by the Nordic UART Service.
* @details This function takes a list of characters of length data_len and prints the characters out on UART.
* If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
ret_code_t ret_val;
NRF_LOG_DEBUG("Receiving data.");
NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
for (uint32_t i = 0; i < data_len; i++)
do
ret_val = app_uart_put(p_data[i]);
if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
APP_ERROR_CHECK(ret_val);
} while (ret_val == NRF_ERROR_BUSY);
if (p_data[data_len-1] == '\r')
while (app_uart_put('\n') == NRF_ERROR_BUSY);
if (ECHOBACK_BLE_UART_DATA)
// Send data back to peripheral.
do
ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
/**@brief Function for handling app_uart events.
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
static uint16_t index = 0;
uint32_t ret_val;
switch (p_event->evt_type)
/**@snippet [Handling data from UART] */
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
do
ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_BUSY) )
index = 0;
NRF_LOG_ERROR("Communication error occurred while handling UART.");
case APP_UART_FIFO_ERROR:
NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@brief Callback handling NUS Client events.
* @details This function is called to notify the application of NUS client events.
* @param[in] p_ble_nus_c NUS Client Handle. This identifies the NUS client
* @param[in] p_ble_nus_evt Pointer to the NUS Client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
ret_code_t err_code;
switch (p_ble_nus_evt->evt_type)
case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
NRF_LOG_INFO("Discovery complete.");
err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
NRF_LOG_INFO("Connected to device with Nordic UART Service.");
case BLE_NUS_C_EVT_NUS_TX_EVT:
ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
case BLE_NUS_C_EVT_DISCONNECTED:
NRF_LOG_INFO("Disconnected.");
scan_start();
* @brief Function for shutdown events.
* @param[in] event Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
switch (event)
case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
// Prepare wakeup buttons.
return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
/**@brief Function for handling the advertising report BLE event.
* @param[in] p_adv_report Advertising report from the SoftDevice.
static void on_adv_report(ble_gap_evt_adv_report_t const * p_adv_report)
if (ble_advdata_uuid_find(p_adv_report->data.p_data, p_adv_report->data.len, &m_nus_uuid))
err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
&m_scan_params,
&m_connection_param,
APP_BLE_CONN_CFG_TAG);
if (err_code == NRF_SUCCESS)
// scan is automatically stopped by the connect
NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
p_adv_report->peer_addr.addr[0],
p_adv_report->peer_addr.addr[1],
p_adv_report->peer_addr.addr[2],
p_adv_report->peer_addr.addr[3],
p_adv_report->peer_addr.addr[4],
p_adv_report->peer_addr.addr[5]
err_code = sd_ble_gap_scan_start(NULL, &m_scan_buffer);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
case BLE_GAP_EVT_ADV_REPORT:
on_adv_report(&p_gap_evt->params.adv_report);
break; // BLE_GAP_EVT_ADV_REPORT
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected to target");
err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
// start discovery of services. The NUS Client waits for a discovery result
err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
case BLE_GAP_EVT_TIMEOUT:
if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
NRF_LOG_INFO("Scan timed out.");
scan_start();
else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
NRF_LOG_INFO("Connection Request timed out.");
// Pairing not supported
err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
// Accepting parameters requested by peer.
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
NRF_LOG_INFO("ATT MTU exchange completed.");
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
switch (event)
case BSP_EVENT_SLEEP:
nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
/**@brief Function for initializing the UART. */
static void uart_init(void)
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = UART_BAUDRATE_BAUDRATE_Baud115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
/**@brief Function for initializing the NUS Client. */
static void nus_c_init(void)
ble_nus_c_init_t init;
init.evt_handler = ble_nus_c_evt_handler;
err_code = ble_nus_c_init(&m_ble_nus_c, &init);
/**@brief Function for initializing buttons and leds. */
static void buttons_leds_init(void)
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
/**@brief Function for initializing the timer. */
static void timer_init(void)
/**@brief Function for initializing the nrf log module. */
static void log_init(void)
/** @brief Function for initializing the Database Discovery Module. */
static void db_discovery_init(void)
ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
* @details Handle any pending log operation(s), then sleep until the next event occurs.
nrf_pwr_mgmt_run();
static void button_event_handler(uint32_t button_number)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
switch (button_number)
/* Pressing SW1 on the Development Kit will result in LED state to toggle and trigger
the STATUS message to inform client about the state change. This is a demonstration of
state change publication due to local event. */
case 0:
uint8_t value = !hal_led_pin_get(LED_PIN_NUMBER);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "User action \n");
hal_led_pin_set(LED_PIN_NUMBER, value);
(void)simple_on_off_server_status_publish(&m_server, value);
/* Initiate node reset */
case 3:
/* Clear all the states to reset the node. */
mesh_stack_config_clear();
node_reset();
static bool on_off_server_get_cb(const simple_on_off_server_t * p_server)
return hal_led_pin_get(LED_PIN_NUMBER);
static void app_rtt_input_handler(int key)
if (key >= '0' && key <= '4')
uint32_t button_number = key - '0';
button_event_handler(button_number);
static bool on_off_server_set_cb(const simple_on_off_server_t * p_server, bool value)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Got SET command to %u\n", value);
return value;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset -----\n");
hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
/* This function may return if there are ongoing flash operations. */
mesh_stack_device_reset();
static void initialize(void)
__LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Server Demo -----\n");
hal_leds_init();
#if BUTTON_BOARD
ERROR_CHECK(hal_buttons_init(button_event_handler));
nrf_clock_lf_cfg_t lfc_cfg = DEV_BOARD_LF_CLK_CFG;
ERROR_CHECK(mesh_softdevice_init(lfc_cfg));
mesh_init();
static void models_init_cb(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
m_server.get_cb = on_off_server_get_cb;
m_server.set_cb = on_off_server_set_cb;
ERROR_CHECK(simple_on_off_server_init(&m_server, 0));
ERROR_CHECK(access_model_subscription_list_alloc(m_server.model_handle));
uint8_t dev_uuid[NRF_MESH_UUID_SIZE];
uint8_t node_uuid_prefix[SERVER_NODE_UUID_PREFIX_SIZE] = SERVER_NODE_UUID_PREFIX;
ERROR_CHECK(mesh_app_uuid_gen(dev_uuid, node_uuid_prefix, SERVER_NODE_UUID_PREFIX_SIZE));
mesh_stack_init_params_t init_params =
.core.irq_priority = NRF_MESH_IRQ_PRIORITY_LOWEST,
.core.lfclksrc = DEV_BOARD_LF_CLK_CFG,
.core.p_uuid = dev_uuid,
.models.models_init_cb = models_init_cb,
.models.config_server_cb = config_server_evt_cb
ERROR_CHECK(mesh_stack_init(&init_params, &m_device_provisioned));
if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
node_reset();
static void start(void)
rtt_input_enable(app_rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
ERROR_CHECK(mesh_stack_start());
if (!m_device_provisioned)
static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
mesh_provisionee_start_params_t prov_start_params =
.p_static_data = static_auth_data,
.prov_complete_cb = provisioning_complete_cb
ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
const uint8_t *p_uuid = nrf_mesh_configure_device_uuid_get();
__LOG_XB(LOG_SRC_APP, LOG_LEVEL_INFO, "Device UUID ", p_uuid, NRF_MESH_UUID_SIZE);
hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
// Initialize.
log_init();
timer_init();
uart_init();
buttons_leds_init();
db_discovery_init();
power_management_init();
ble_stack_init();
gatt_init();
nus_c_init();
// Start execution.
printf("BLE UART central example started.\r\n");
NRF_LOG_INFO("BLE UART central example started.");
scan_start();
initialize();
execution_start(start);
// Enter main loop.
for (;;)
idle_state_handle();
Have you included simple_on_off_server.h in your main.c ?
When you see a description of a function missing, you can go to the original mesh project and look for that function to see where it described and include that into your project.
Ok I fixed that issue but now I am getting new errors related to interrupts like,
1.multiple definition of `SWI2_EGU2_IRQHandler'
2.multiple definition of `nrf_nvic_state'.
How to solve that?
Could you check where they are defined ?
