Dear Nordic Team,
Thanks for supporting. Now i want to integrate GPIOTE with BLE UART example. When i call gpio_init(); this function got error like below image.please support anyone
SDK : SDK12.3.0
Hardware : PCA10040
Dear Nordic Team,
SDK : SDK12.3.0
Hardware : PCA10040
my hardware some issue. Now its rectified. Now working GPIOTE with BLE Uart example. But still i am facing Flickering issue.
when i test with "pin_change_int" example its working good. But this example merge with BLE UArt example i got flickering issue.
Great! Please describe this "flickering issue" in more details. What are the symptoms? How are you controlling the AC device?
Above circuit is used to control the AC device. In output i am using 230 V AC Lamp. This circuit control the lamp brightness as per PIN_OUT signal. Its controlled brightness as per the signal but some time blink the the lamp. if you want video i will make and send you.
Could you check the PIN_IN and PIN_OUT lines with a logic analyzer, to see if there are any visible glitches corresponding with the "flickering"? Which pins are you using for the input and output?
