Direct connection after disconnect
I am using the iPhone 8, BLE device (51822/51422), s130, SDK 12.3.0.
and using a bonding and passkey to connect.
However, Direct connection after disconnect
For example,
1.
- At first connection, it is connected and the passkey input window appears.
- Press the cancel button.
- Disconnected.
- However, it is reconnected immediately and the passkey input window appears again.
- After this, if i press cancel button or input wrongly, disconnect, and then the input window appears immediately after connection.
2.
- After entering the passkey, connect and disconnect normally. (In this case, after disconnect , it normally advertises)
- Delete the bond erase in device (keep the phone's bond information intact)
- If i try to connect, it will fail because it does not have the device's bond information. (normal)
- But... After I disconnect, I just want to advertise. However, as soon as the advertisement is disconnected, direct connection - failure - disconnect - advertisement - connection - failure - disconnect - advertisement... repeats itself.
main.c
 * Copyright (c) 2015 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
 * @brief Blinky Sample Application main file.
 * This file contains the source code for a sample server application using the LED Button service.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "DeviceVersion.h"
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_gap.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "nrf_gpio.h"
#include "softdevice_handler.h"
#include "ble_srv_common.h"
#include "ble_conn_params.h"
#include "boards.h"
#include "app_timer.h"
#include "fstorage.h"
#include "fds.h"
#include "ble_lls.h"
#include "peer_manager.h"
#include "app_button.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "ble_conn_state.h"
#include "nrf_drv_rng.h"
#include "nrf_drv_gpiote.h"
#include "app_uart.h"
#include "nrf_drv_uart.h"
#include "ble_nus.h"
#include "ble_lbs.h"
#include "ble_dis.h"
#define NRF_LOG_MODULE_NAME "APP"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define GPIO_PIN_HIGH                   1
#define GPIO_PIN_LOW                    0
#define CENTRAL_LINK_COUNT              0                                           /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
#define PERIPHERAL_LINK_COUNT           1                                           /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
#if (NRF_SD_BLE_API_VERSION == 3)
#define NRF_BLE_MAX_MTU_SIZE            GATT_MTU_SIZE_DEFAULT                       /**< MTU size used in the softdevice enabling and to reply to a BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST event. */
#define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2        /**< Reply when unsupported features are requested. */
#define BT_CONN_PIN                     2
#define BT_RESET_PIN                    1
#define DEBOUNCE_INIT_PIN               200
#define DEVICE_NAME                     "example"                                 /**< Name of device. Will be included in the advertising data. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS      BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED       /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
#define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_MAX_TIMERS            6                                           /**< Maximum number of simultaneously created timers. */
#define APP_TIMER_OP_QUEUE_SIZE         6                                           /**< Size of timer operation queues. */
#define SECURITY_REQUEST_DELAY          APP_TIMER_TICKS(400, APP_TIMER_PRESCALER)   /**< Delay after connection until Security Request is sent, if necessary (ticks). */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(40, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY      APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY       APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT        3
#define APP_GPIOTE_MAX_USERS            1                                           /**< Maximum number of users of the GPIOTE handler. */
#define INITIAL_LLS_ALERT_LEVEL         BLE_CHAR_ALERT_LEVEL_NO_ALERT               /**< Initial value for the Alert Level characteristic in the Link Loss service. */
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  1                                           /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_DISPLAY_ONLY                /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
#define PASSKEY_TXT                     "Passkey:"                                  /**< Message to be displayed together with the pass-key. */
#define PASSKEY_TXT_LENGTH              8                                           /**< Length of message to be displayed together with the pass-key. */
#define PASSKEY_LENGTH                  6                                           /**< Length of pass-key received by the stack for display. */
#define APP_ADV_FAST_INTERVAL           0x0028                                      //!< Fast advertising interval (in units of 0.625 ms. This value corresponds to 25 ms.). */
#define APP_ADV_SLOW_INTERVAL           0x0C80                                      //!< Slow advertising interval (in units of 0.625 ms. This value corrsponds to 2 seconds). */
#define APP_ADV_FAST_TIMEOUT            30                                          //!< The duration of the fast advertising period (in seconds). */
#define APP_ADV_SLOW_TIMEOUT            180                                         //!< The duration of the slow advertising period (in seconds). */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define STATIC_PASSKEY                  "FFFFFF"
static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
static ble_lls_t                        m_lls;                                      /**< Structure used to identify the Link Loss service. */
APP_TIMER_DEF(m_sec_req_timer_id);                                                  //!< Security request timer. The timer lets us start pairing request if one does not arrive from the Central. */
static ble_opt_t  m_static_pin_option;
uint8_t passkey[] = STATIC_PASSKEY;
char n_passkey[PASSKEY_LENGTH];
uint8_t  prev_bond;
pm_peer_id_t  m_peer_to_be_deleted = PM_PEER_ID_INVALID;
static void advertising_start(void);
static void on_lls_evt(ble_lls_t * p_lls, ble_lls_evt_t * p_evt);
/**@brief Function for assert macro callback.
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    ret_code_t err_code;
    //NRF_LOG_INFO("Peer evt : %d \r\n", p_evt->evt_id);
    switch (p_evt->evt_id)
        case PM_EVT_BONDED_PEER_CONNECTED:
            prev_bond = 1;
            NRF_LOG_INFO("Connected to a previously bonded device.\r\n");
        } break;
        case PM_EVT_CONN_SEC_SUCCEEDED:
            pm_conn_sec_status_t conn_sec_status;
            // Check if the link is authenticated (meaning at least MITM).
            err_code = pm_conn_sec_status_get(p_evt->conn_handle, &conn_sec_status);
            if (conn_sec_status.mitm_protected)
                NRF_LOG_INFO("Link secured. Role: %d. conn_handle: %d, Procedure: %d\r\n",
                             ble_conn_state_role(p_evt->conn_handle),
                             p_evt->conn_handle,
                             p_evt->params.conn_sec_succeeded.procedure);
                // The peer did not use MITM, disconnect.
                NRF_LOG_INFO("Collector did not use MITM, disconnecting\r\n");
                err_code = pm_peer_id_get(m_conn_handle, &m_peer_to_be_deleted);
                err_code = sd_ble_gap_disconnect(m_conn_handle,
        } break;
        case PM_EVT_CONN_SEC_FAILED:
            NRF_LOG_INFO("Failed to secure connection. Disconnecting.\r\n");
            err_code = sd_ble_gap_disconnect(p_evt->conn_handle,
            /* Often, when securing fails, it shouldn't be restarted, for security reasons.
             * Other times, it can be restarted directly.
             * Sometimes it can be restarted, but only after changing some Security Parameters.
             * Sometimes, it cannot be restarted until the link is disconnected and reconnected.
             * Sometimes it is impossible, to secure the link, or the peer device does not support it.
             * How to handle this error is highly application dependent. */
        } break;
        case PM_EVT_CONN_SEC_CONFIG_REQ:
            // Reject pairing request from an already bonded peer.
            pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
            pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
        } break;
        case PM_EVT_STORAGE_FULL:
            // Run garbage collection on the flash.
            err_code = fds_gc();
            if (err_code == FDS_ERR_BUSY || err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                // Retry.
        } break;
            advertising_start();
        } break;
        case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
            // The local database has likely changed, send service changed indications.
            pm_local_database_has_changed();
        } break;
        case PM_EVT_PEER_DATA_UPDATE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
        } break;
        case PM_EVT_PEER_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
        } break;
        case PM_EVT_PEERS_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
        } break;
        case PM_EVT_ERROR_UNEXPECTED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
        } break;
        case PM_EVT_CONN_SEC_START:
        case PM_EVT_PEER_DELETE_SUCCEEDED:
        case PM_EVT_LOCAL_DB_CACHE_APPLIED:
        case PM_EVT_SERVICE_CHANGED_IND_SENT:
        case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
/**@brief Function for handling the Security Request timer timeout.
 * @details This function will be called each time the Security Request timer expires.
 * @param[in]   p_context   Pointer used for passing some arbitrary information (context) from the
 *                          app_start_timer() call to the timeout handler.
static void sec_req_timeout_handler(void * p_context)
    uint32_t                err_code;
    pm_conn_sec_status_t    status;
        if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
        // Initiate bonding.
        err_code = pm_conn_sec_status_get(m_conn_handle, &status);
        if(!status.encrypted){
            NRF_LOG_INFO("Start encryption\r\n");
            err_code = pm_conn_secure(m_conn_handle, false);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module.
static void timers_init(void)
    uint32_t err_code;
    // Initialize timer module, making it use the scheduler.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    // Create Security Request timer.
    err_code = app_timer_create(&m_sec_req_timer_id,
                                APP_TIMER_MODE_SINGLE_SHOT,
                                sec_req_timeout_handler);
/**@brief Function for handling Service errors.
static void service_error_handler(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    uint32_t                err_code;
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_UNKNOWN);
/**@brief Function for handling Link Loss events.
 * @details This function will be called for all Link Loss events which are passed to the
 *          application.
 * @param[in] p_lls  Link Loss structure.
 * @param[in] p_evt  Event received from the Link Loss service.
    switch (p_evt->evt_type)
        case BLE_LLS_EVT_LINK_LOSS_ALERT:
            break; // BLE_LLS_EVT_LINK_LOSS_ALERT
            // No implementation needed.
 /**@brief Function for initializing the Link Loss Service.
static void lls_init(void)
    uint32_t       err_code;
    ble_lls_init_t lls_init_obj;
    // Initialize Link Loss Service
    memset(&lls_init_obj, 0, sizeof(lls_init_obj));
    lls_init_obj.evt_handler         = on_lls_evt;
    lls_init_obj.error_handler       = service_error_handler;
    lls_init_obj.initial_alert_level = INITIAL_LLS_ALERT_LEVEL;
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&lls_init_obj.lls_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&lls_init_obj.lls_attr_md.write_perm);
    err_code = ble_lls_init(&m_lls, &lls_init_obj);
    lls_init();
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module that
 *          are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply
 *       setting the disconnect_on_fail config parameter, but instead we use the event
 *       handler mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling a Connection Parameters error.
 * @param[in]   event   Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_DISCONNECT:
        case BSP_EVENT_WHITELIST_OFF:
                err_code = ble_advertising_restart_without_whitelist();
    uint32_t ret;
    ret = ble_advertising_start(BLE_ADV_MODE_FAST);
    APP_ERROR_CHECK(ret);
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising\r\n");
        case BLE_ADV_EVT_SLOW:
            NRF_LOG_INFO("Slow advertising\r\n");
            err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_SLOW);
        case BLE_ADV_EVT_IDLE:
            //sleep_mode_enter();
/**@brief Function for handling the Application's BLE stack events.
 * @param[in] p_ble_evt  Bluetooth stack event.
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t err_code = NRF_SUCCESS;
        case BLE_EVT_TX_COMPLETE:
        case BLE_GAP_EVT_SEC_INFO_REQUEST:
        case BLE_GAP_EVT_AUTH_STATUS:
            if(p_ble_evt->evt.gap_evt.params.auth_status.auth_status == BLE_GAP_SEC_STATUS_SUCCESS){
                nrf_gpio_pin_write(BT_CONN_PIN, GPIO_PIN_HIGH);
                NRF_LOG_INFO("CONN_PIN_HIGH.\r\n");
            }else{
                err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gap_evt.conn_handle,
                }else{
                    NRF_LOG_INFO("FATAL ERROR !\r\n");
        case BLE_GAP_EVT_CONN_SEC_UPDATE:
            if(prev_bond || p_ble_evt->evt.gap_evt.params.auth_status.bonded){
                    prev_bond = 0;
            NRF_LOG_INFO("Disconnected.\r\n");
            prev_bond = 0;
            nrf_gpio_pin_write(BT_CONN_PIN, GPIO_PIN_LOW);
            /*check if the last connected peer had not used MITM, if so, delete its bond information*/
            if (m_peer_to_be_deleted != PM_PEER_ID_INVALID)
                ret_code_t ret_val = pm_peer_delete(m_peer_to_be_deleted);
                APP_ERROR_CHECK(ret_val);
                NRF_LOG_INFO("Collector's bond deleted\r\n");
            break; // BLE_GAP_EVT_DISCONNECTED
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected\r\n");
            prev_bond = 0;
            uint8_t p_buff[4];
            err_code = nrf_drv_rng_rand(p_buff, 4);
            for(uint8_t i=0; i<4; i++){
                passkey[i+2] = p_buff[i] % 9 + 48;
            m_static_pin_option.gap_opt.passkey.p_passkey = &passkey[0];
            err_code =  sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &m_static_pin_option);
            err_code = app_timer_start(m_sec_req_timer_id, SECURITY_REQUEST_DELAY, NULL);
            break; // BLE_GAP_EVT_CONNECTED
        case BLE_GAP_EVT_PASSKEY_DISPLAY:
            char passkey[PASSKEY_LENGTH + 1];
            memcpy(passkey, p_ble_evt->evt.gap_evt.params.passkey_display.passkey, PASSKEY_LENGTH);
            passkey[PASSKEY_LENGTH] = 0;
            // Don't send delayed Security Request if security procedure is already in progress.
            err_code = app_timer_stop(m_sec_req_timer_id);
            memcpy(n_passkey, passkey, PASSKEY_LENGTH);
            //err_code = app_timer_start(m_mcu_rsp_timer_id, MCU_RESPONSE_DELAY, NULL);
            //APP_ERROR_CHECK(err_code);
            NRF_LOG_INFO("Passkey: %s\r\n",nrf_log_push(passkey));
        } break; // BLE_GAP_EVT_PASSKEY_DISPLAY
            /*err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                   BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                   NULL,
                                                   NULL);
            APP_ERROR_CHECK(err_code);*/
            break; // BLE_GAP_EVT_SEC_PARAMS_REQUEST
            break; // BLE_GATTS_EVT_SYS_ATTR_MISSIN
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
    uint32_t      err_code;
    ble_advdata_t advdata;
    ble_adv_modes_config_t options;
    // Build and set advertising data
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance = true;
    advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    options.ble_adv_whitelist_enabled      = false;
    options.ble_adv_directed_enabled       = false;
    options.ble_adv_directed_slow_enabled  = false;
    options.ble_adv_directed_slow_interval = 0;
    options.ble_adv_directed_slow_timeout  = 0;
    options.ble_adv_fast_enabled           = true;
    options.ble_adv_fast_interval          = APP_ADV_FAST_INTERVAL;
    options.ble_adv_fast_timeout           = APP_ADV_FAST_TIMEOUT;
    options.ble_adv_slow_enabled           = true;
    options.ble_adv_slow_interval          = APP_ADV_SLOW_INTERVAL;
    //options.ble_adv_slow_timeout           = APP_ADV_SLOW_TIMEOUT;
#if(UART_TEST_MODE)
    ble_advdata_t scanrsp;
    memset(&scanrsp, 0, sizeof(scanrsp));
    scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    scanrsp.uuids_complete.p_uuids  = m_adv_uuids;
    err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
#else
    err_code = ble_advertising_init(&advdata, NULL, &options, on_adv_evt, NULL);
/**@brief Function for dispatching a BLE stack event to all modules with a BLE stack event handler.
 * @details This function is called from the scheduler in the main loop after a BLE stack
 *          event has been received.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
    ble_conn_state_on_ble_evt(p_ble_evt);
    pm_on_ble_evt(p_ble_evt);
    ble_lls_on_ble_evt(&m_lls, p_ble_evt);
    ble_conn_params_on_ble_evt(p_ble_evt);
    ble_advertising_on_ble_evt(p_ble_evt);
/**@brief Function for dispatching a system event to interested modules.
 * @details This function is called from the System event interrupt handler after a system
 * @param[in] sys_evt  System stack event.
static void sys_evt_dispatch(uint32_t sys_evt)
    // Dispatch the system event to the fstorage module, where it will be
    // dispatched to the Flash Data Storage (FDS) module.
    fs_sys_event_handler(sys_evt);
    // Dispatch to the Advertising module last, since it will check if there are any
    // pending flash operations in fstorage. Let fstorage process system events first,
    // so that it can report correctly to the Advertising module.
    ble_advertising_on_sys_evt(sys_evt);
    uint32_t err_code;
    nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
    // Initialize the SoftDevice handler module.
    SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
    ble_enable_params_t ble_enable_params;
    err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                    PERIPHERAL_LINK_COUNT,
                                                    &ble_enable_params);
    //Check the ram settings against the used number of links
    CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT, PERIPHERAL_LINK_COUNT);
    // Enable BLE stack.
    ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE;
    err_code = softdevice_enable(&ble_enable_params);
    // Subscribe for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    // Register with the SoftDevice handler module for BLE events.
    err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
/**@brief Function for the Peer Manager initialization.
 * @param[in] erase_bonds  Indicates whether bonding information should be cleared from
 *                         persistent storage during initialization of the Peer Manager.
static void peer_manager_init(bool erase_bonds)
    err_code = pm_init();
    if (erase_bonds)
        err_code = pm_peers_delete();
    sec_param.bond              = SEC_PARAM_BOND;
    sec_param.mitm              = SEC_PARAM_MITM;
    sec_param.lesc              = SEC_PARAM_LESC;
    sec_param.keypress          = SEC_PARAM_KEYPRESS;
    sec_param.io_caps           = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob               = SEC_PARAM_OOB;
    sec_param.min_key_size      = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size      = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc     = 1;
    sec_param.kdist_own.id      = 1;
    sec_param.kdist_peer.enc    = 1;
    sec_param.kdist_peer.id     = 1;
/**@brief Function for the Power Manager.
static void power_manage(void)
    uint32_t err_code = sd_app_evt_wait();
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                                 APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                 bsp_event_handler);
/**@brief Function for application main entry.
    bool erase_bonds;
    err_code = NRF_LOG_INIT(NULL);
    timers_init();
    ble_stack_init();
#if(SEC_PARAM_BOND)
    peer_manager_init(false);
    gap_params_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    NRF_LOG_INFO("VERSION ... %s \r\n", nrf_log_push(FW_VERSION));
    // Enter main loop.
    for (;;)
            power_manage();
  • Hi RY Yoo,
    Could you please upload whole project for your problem?
    I can't compile with only main.c you attached due to you modified several functions.
    And, please let me know about below questions.
    1. How to check your problem?
    With nRF Connect Apps or something else?
    Please describe in detail.
    2. Were this problem also detected with an Andrond App(nRF Connect) if you used nRF Connect App for an Apple?
    When I checked this issue with GLS example, I could not detect this issue.
    I checked an Apple device and an Android device both.
    BR
    Justin
  • Thank you for answer. Please understand that I am inexperienced in English...
    The same problem happens in the GLS example. Android is normal and only appears on the iPhone. (I checked an iPhone 5, iPhone 8 with an Apple App(nRF Connect))
    You can check in the following order.
    1. After entering the passkey, connect and disconnect normally. (In this case, after disconnect , it normally advertises)
    2. bond erase in device (keep the phone's bond information intact)
         - In this case, you need to modify the GLS example code slightly.
         - In my case, I modified the [peer_manager_init(erase_bonds);] in the main door to [peer_manager_init(true);],
            downloaded it again and bond erased it.
    3. Then, if you make a connection, repeat the connection and disconnect. This is my log.
    APP:INFO:Failed to secure connection. Disconnecting.
    APP:INFO:Disconnected
    APP:INFO:Fast advertising
    APP:INFO:Connected
    APP:INFO:Connected
    APP:INFO:Connected
    APP:INFO:Connected
  • Hi, RY Yoo.
    I don't why this issue is detected with only an Apple device.
    Anyways,
    In your code, when secure connection failed, gap_disconnect is called.
    However, it doesn't need to call.
    In GAP, disconnect will happen.
    I think that this code influence to Bluetooth code of an Apple device.
    So, please do that with below code.
                //m_conn_handle = BLE_CONN_HANDLE_INVALID;
                //err_code = sd_ble_gap_disconnect(p_evt->conn_handle,
                //                                 BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            } break;
    BR
    Justin
  • Thanks. I tried. But the same problem repeats.
    APP:INFO:Connected
    APP_ERROR:ERROR:Fatal
    APP:INFO:GLS Start!
    APP:INFO:Connected
    APP:INFO:GLS Start!
    APP:INFO:Connected
    APP:INFO:GLS Start!
    APP:INFO:Connected
    APP:INFO:GLS Start!
    APP:INFO:Connected
  • I got same error before modifying.
    Did you modify correctly?
    "Fatal" message came from APP_ERROR_CHECK(err_code).
    I think something wrong.
    Please check them out again.
    BR
    Justin
