Hi all , when I combine light switch server and remote server in 1 Node and use Provisioner Node for provisioning and config for it . I have error
Log in provisioner :
<t: 0>, main.c, 799, ----- BLE Mesh Light Switch Provisioner Demo ----- <t: 0>, mesh_softdevice_init.c, 112, Initializing SoftDevice... <t: 0>, mesh_softdevice_init.c, 77, Enabling BLE... <t: 1>, mesh_softdevice_init.c, 88, Ram base: 0x200032C8 <t: 588>, main.c, 728, Initializing and adding models <t: 603>, main.c, 781, Setup defaults: Adding keys, addresses, and bindings <t: 751>, provisioner_helper.c, 333, netkey_handle: 0 <t: 764>, main.c, 830, <start> <t: 766>, main.c, 837, Device UUID : 9A533F70C6C4C2C8913CA3844E7ADF05 <t: 27386>, main.c, 140, Flash write complete <t: 27389>, main.c, 814, Starting application ... <t: 27391>, main.c, 816, Provisoned Nodes: 0, Configured Nodes: 0 Next Address: 0x0100 <t: 27395>, main.c, 817, Dev key : D05076E02025338264CE79A4EDEB0444 <t: 27398>, main.c, 818, Net key : 5EE6580480F65DFD78F6E495A47960D6 <t: 27401>, main.c, 819, App key : 9893A869A333E9032D8D746668D7F213 <t: 27403>, main.c, 822, Node Address: 0x0001 <t: 27405>, main.c, 823, Press Button 1 to start provisioning and configuration process. <t: 188640>, main.c, 611, Button 1 pressed <t: 188642>, main.c, 528, Waiting for Server node to be provisioned ... <t: 193406>, provisioner_helper.c, 286, Scanning For Unprovisioned Devices <t: 216201>, provisioner_helper.c, 144, UUID seen: 0059FFFF00000000A567C89D6A4AE18A <t: 216204>, provisioner_helper.c, 95, UUID filter matched <t: 217691>, provisioner_helper.c, 263, Provisioning link established <t: 365539>, provisioner_helper.c, 258, Static authentication data provided <t: 377291>, provisioner_helper.c, 196, Provisioning completed received <t: 377294>, provisioner_helper.c, 201, Adding device address, and device keys <t: 377300>, provisioner_helper.c, 218, Addr: 0x0100 addr_handle: 0 netkey_handle: 0 devkey_handle: 2 <t: 380730>, provisioner_helper.c, 155, Local provisioning link closed: prov_state: 2 remaining retries: 2 <t: 380734>, main.c, 429, Provisioning successful <t: 380737>, main.c, 439, idx = 1 <t: 380738>, provisioner_helper.c, 185, Provisioning complete. Node addr: 0x0100 elements: 3 <t: 380742>, node_setup.c, 726, Configuring Node: 0x0100 <t: 380746>, node_setup.c, 640, Config client setup: devkey_handle:2 addr_handle:0 <t: 380749>, node_setup.c, 384, Getting composition data <t: 380812>, main.c, 140, Flash write complete <t: 432961>, main.c, 488, Config client event <t: 432964>, node_setup.c, 394, Adding appkey <t: 436881>, main.c, 488, Config client event <t: 436884>, node_setup.c, 279, opcode status field: 6 <t: 436886>, node_setup.c, 405, App key bind: Health server <t: 437553>, main.c, 488, Config client event <t: 437555>, node_setup.c, 279, opcode status field: 0 <t: 437558>, node_setup.c, 420, App key bind: Simple On/Off server <t: 438525>, main.c, 488, Config client event <t: 438527>, node_setup.c, 279, opcode status field: 0 <t: 438530>, node_setup.c, 473, Setting publication address for the health server to 0x0001 <t: 440883>, main.c, 488, Config client event <t: 440886>, node_setup.c, 279, opcode status field: 0 <t: 440888>, node_setup.c, 500, Set: on/off server pub addr: 0x0003 <t: 472388>, main.c, 488, Config client event <t: 472390>, node_setup.c, 279, opcode status field: 0 <t: 472392>, node_setup.c, 511, Adding subscription <t: 474252>, main.c, 488, Config client event <t: 474255>, node_setup.c, 279, opcode status field: 0 <t: 474257>, main.c, 353, Configuration of device 0 successful <t: 474261>, provisioner_helper.c, 286, Scanning For Unprovisioned Devices <t: 474317>, main.c, 140, Flash write complete
Opcode = 6 is error . But number 6 indicate for what ?
In Node : If i insert code :
/* TODO: This should be handled by the configuration server model. */ mesh_key_index_t net_key_index; uint32_t count = 1; ERROR_CHECK(dsm_subnet_get_all(&net_key_index, &count)); m_netkey_handle = dsm_net_key_index_to_subnet_handle(net_key_index); uint8_t appkey[NRF_MESH_KEY_SIZE] = {0}; ERROR_CHECK(dsm_appkey_add(0, m_netkey_handle, appkey, &m_appkey_handle)); ERROR_CHECK(dsm_address_publish_add(PROVISIONER_ADDRESS, &m_provisioner_address_handle));/* Bind the keys to the Simple OnOff clients. */ ERROR_CHECK(access_model_application_bind(m_remote_server.model_handle, m_appkey_handle)); ERROR_CHECK(access_model_publish_address_set(m_remote_server.model_handle, m_provisioner_address_handle)); // ERROR_CHECK(access_model_publish_address_set(m_server.model_handle, m_provisioner_address_handle)); ERROR_CHECK(access_model_publish_application_set(m_remote_server.model_handle, m_appkey_handle)); ERROR_CHECK(access_model_publish_ttl_set(m_remote_server.model_handle, 6)); ERROR_CHECK(pb_remote_server_enable(&m_remote_server)); ERROR_CHECK(pb_remote_server_prov_bearer_set(&m_remote_server, nrf_mesh_prov_bearer_adv_interface_get(&m_prov_bearer_adv)));
I will have above error . But this code need for remote function in server Node . If I dont insert above code into server Node so light switch function work fine , opcode = 0 .
I want remote function and light switch function all work . Pls show me solution ! Thank very much !!!
