Hi All,
I am designing circuit to Turn ON 4 LEDs at a time based on high and low of GPIO
Supply voltage is 3.3V my doubt below circuit is fine whether it will work fine for using 3.3V as supply
Hi All,
The topology should be fine, but R3 = 2.2 Ohm might be a little small. This should be easy to test and adjust if needed though.
Andreas
Since each LED is configured for 10mA so used 2.2E instead of 2.5E
Hope current supply limit of nRF doesn't affect this circuit
Isolated, the 'LED1' GPIO might be a little high, but below 5 mA should be fine. You should also not be sourcing 5 mA from more than 3 GPIOs at a time.
Andreas
