PASSKEY
 I’ve downloaded     nRF5_SDK_11.0.0_89a8197 and starting with examples from \examples\ble_peripheral\???\pca10040\s132\arm5_no_packs\
 I would like the other device to request a passkey (constant) at pairing (the passkey on my side is constant - no display needed)
After   gap_params_init();I’ve added the following code:
 static ble_opt_t optS;
   static uint8_t passw[]="123456";
 optS.gap_opt.passkey.p_passkey=passw;
   err_code =sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &optS);
err_code returned :  0
Still the module will pair and communicate without requesting a passkey.
I've tried to find an answer in Q&A . in some answers there was a reference to fields : io_caps,mitm. cant make out what does it mean.
(these fields belong to structs relevant to services, not pairing)
Thanks for any help
   Yona
  • I tried to advertise manufacturer data. even coping a full function from Nordic help. for some reason- didn't work .
    the application(cellphone) guy didn't like the appearance because he would have to preform a READ to get that info.
    then I realized that the advertised Service isn't a real functional service. so advertising in is actually
    "for free".
    the app guy  didn't object so that's how we solved that.
    so now a new issue.hope you still have some more patience left for my questions.
    when trying to make the passkey work- you recommended to use ble_app_hrs example project .
    (I'm using nRF5_SDK_11.0.0_89a8197 packege).
    I've noticed but  didn't pay attention to it then:    the SW  RESETS every some time (~ 4 minutes) due to an error :   NRF_ERROR_SOC_POWER_OFF_SHOULD_NOT_RETURN returned by function sd_power_system_off   (called from sleep_mode_enter).
    if I remove this function all together then the SW will not reset- BUT the BLE goes dead after the same time (~4 minutes).
    meanwhile the SW is still running and the application timers are still on ( timers resulting from app_timer_create).
    coming out of this situation - by resetting the HW/SW .
    what would you say ?
    thanks again
    Yona
  • one more thing:
    I've tried  using  nRF5_SDK_15xxxxx package  with ble_app_hrs example project.
    its way too heavy . too many elements to remove (and than it gives some internal error).
    so I still need your help regarding the resets/BLE dying .
    I'd prefer not to call  sd_power_system_off if I can avoid it
    Thanks
    Yona
  • If you do not want the ble_app_hrs example to go to SYSTEM OFF, then simply comment out the sleep_mode_enter(); call under the BLE_ADV_EVT_IDLE case in on_adv_evt() and under the  BSP_EVENT_SLEEP case in bsp_event_handler().
    Best regards
    Bjørn
  • me again, new issue
    now that a peripheral BLE is working (including the passkey), I'm requested to develop a tester for that unit.
    For that I need A BLE central .
    so I started with nRF5_SDK_11.0.0_89a8197\examples\ble_central\ble_app_multilink_central .
    all is fine.the only issue is again: how to operate the passkey (as a central unit)
    thanks
    Yona
  • HI Yona,
    you need to reply to the BLE_GAP_EVT_AUTH_KEY_REQUEST with sd_ble_gap_auth_key_reply with the passkey as a parameter, see the Bonding: Passkey Entry, User Inputs on Central or OOB MSC.
    You can also take a look at this post.
    Best regards
    Bjørn
