PASSKEY
 I’ve downloaded     nRF5_SDK_11.0.0_89a8197 and starting with examples from \examples\ble_peripheral\???\pca10040\s132\arm5_no_packs\
 I would like the other device to request a passkey (constant) at pairing (the passkey on my side is constant - no display needed)
After   gap_params_init();I’ve added the following code:
 static ble_opt_t optS;
   static uint8_t passw[]="123456";
 optS.gap_opt.passkey.p_passkey=passw;
   err_code =sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &optS);
err_code returned :  0
Still the module will pair and communicate without requesting a passkey.
I've tried to find an answer in Q&A . in some answers there was a reference to fields : io_caps,mitm. cant make out what does it mean.
(these fields belong to structs relevant to services, not pairing)
Thanks for any help
   Yona
  • Hi again
    from some of the discussions - it seems that some updates needed in struct /union ble_evt_t. (mitm,lesc ...)
    this struct "pops up" in function on_ble_evt  called at these  events in a service:
    BLE_GAP_EVT_CONNECTED,
    BLE_GAP_EVT_CONN_PARAM_UPDATE,
    BLE_GATTS_EVT_WRITE,
    BLE_GAP_EVT_DISCONNECTED,
    still - never called for BLE_GAP_EVT_SEC_PARAMS_REQUEST
    moreover - there is a remark at the following line : // Pairing not supported
    does someone know  whats to be done ??
    Yona
  • Hi Yona,
    You can change the permission/security level on the BLE characteristics to require MITM pairing. The central does not need to pair with the device if security level is set to "open".
    E..g, change BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm) to BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM (&attr_md.read_perm) if you want to limit read access to a certain characteristic.
  • thank you for the answer.
    making this change - finally  "produces"  the  events:
    BLE_GAP_EVT_SEC_PARAMS_REQUEST,   BLE_GAP_EVT_AUTH_STATUS
    how should I deal with them ?
    (as the cellphone application does not know that passkey is needed- so reading the characteristic results in a  BLE disconnection)
    Yona
  • Recommend to use the device manager module for handling of security requests. Device manger is implemented in most of the ble_peripheral examples, ble_app_hrs for instance.
  • I would like to apologize for my repeating questions.
    I took ble_app_hrs project ( DEVICE_NAME  =  "Nordic_HRM")
    it contains code for dealing with BLE_GAP_EVT_SEC_PARAMS_REQUEST
    I've added this code to define a constant passkey
    err_code =sd_ble_opt_set(BLE_GAP_OPT_PASSKEY,&optS);
    than I've changed (for characteristic "Body Sensor Location")
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_bsl_attr_md.read_perm);
     to
    BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&hrs_init.hrs_bsl_attr_md.read_perm);
    the result is that  "Body Sensor Location" will not preform the read (the read request from the cellphone application does not respond)
    all other services work normal
    what am I missing ?
    thanks again
    Yona
