How to scan Bluetooth5 and Bluetooth4 advertisements at the same time?
Hello all,
I'm trying to do a "BLE scanner" in order to read non connectable advertisements. These advertisements can be PHY_CODED and PHY_1MBPS (classic BLE advertisements).
I'm using a nRF52840, nRF5 SDK v15.0.0 and S140 SoftDevice v6.0.0 API.
Currently, I have a code for reading PHY_1MBPS advertisements  and a code for reading PHY_CODED advertisements. But I am not able to read both kind of advertisements at same time.
I saw in documentation I can choose the type of advertisements scanned in the struct ble_gap_scan_params_t. So, I chose scan all of them:
.scan_phys		  = BLE_GAP_PHYS_SUPPORTED,
I'm trying it with this code:
static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_EXTENDED_MIN];
static ble_data_t m_scan_buffer =
    m_scan_buffer_data,
static ble_gap_scan_params_t const m_scan_params =
	.active   = 0,
    .interval = SCAN_INTERVAL,
    .window   = SCAN_WINDOW,
    .timeout          = SCAN_DURATION,
    .filter_policy    = BLE_GAP_SCAN_FP_ACCEPT_ALL,
	.extended = 1,
static void scan_start(void)
    ret_code_t ret;
    ret = sd_ble_gap_scan_start(&m_scan_params, &m_scan_buffer);
    APP_ERROR_CHECK(ret);
But the function returns "invalid parameters error".
However, if I use
.scan_phys        = BLE_GAP_PHY_1MBPS,
or
.scan_phys        = BLE_GAP_PHY_CODED,
I can read PHY_1MBPS advertisements or PHY_CODED advertisements alternately.
Any idea?
Manuel Montenegro
