nRF sniffer not working
I try to use the nRF sniffer but it doesn't display anything.
System used :
Windows 10 Family x64
Wireshark 2.4.4
Python 2.7.14 (in C\Python27 included in PATH)
jlink 6.22c
Hardware used: PCA10040 V1.1.1
nRF sniffer 2.0.0-beta-1_51296aa
Log of command nrf_sniffer.bat
C:\Program Files\Wireshark\extcap>nrf_sniffer.bat --extcap-interfacesextcap {version=2.0.0}{display=nRF Sniffer}{help=www.nordicsemi.com/.../nRF-Sniffer {number=0}{type=selector}{display=Device}{tooltip=Device list}control {number=1}{type=string}{display=Passkey / OOB key}{tooltip=6 digit temporary key or 16 byte Out-of-band (OOB) key in hexadecimal starting with '0x', big endian format. If the entered key is shorter than 16 bytes, it will be zero-padded in front'}{validation=\b^(([0-9]{6})|(0x[0-9a-fA-F]{1,32}))$\b}control {number=2}{type=string}{display=Adv Hop}{default=37,38,39}{tooltip=Advertising channel hop sequence. Change the order in which the siffer switches advertising channels. Valid channels are 37, 38 and 39 separated by comma.}{validation=^\s*((37|38|39)\s*,\s*){0,2}(37|38|39){1}\s*$}{required=true}control {number=3}{type=button}{role=help}{display=Help}{tooltip=Access user guide (launches browser)}control {number=4}{type=button}{role=restore}{display=Defaults}{tooltip=Resets the user interface and clears the log file}control {number=5}{type=button}{role=logger}{display=Log}{tooltip=Log per interface}value {control=0}{value= }{display=All advertising devices}{default=true}
Log of wireshark
INFO: Log started at 01/30/18 08:56:03
INFO: args: ()
INFO: kwargs: {'callbacks': [('*', <bound method Sniffer.passOnNotification of <Sniffer(Thread-2, initial)>>)]}
INFO: board ID: 3
INFO: starting scan
INFO: starting scan
INFO: Sent key value to sniffer: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
INFO: Packet read timed out.
Data came from the serial port (COM3: JLink CDC UART Port).
Can you help me
Best regards
