buttonless DFU integration Problem - Compiling
Hello, I am trying to integrate buttonless DFU functionality to my project.
However, when I compile the project I get this error
Linking target: _build/nrf52832_xxaa.out
arm-none-eabi-gcc: error: _build/nrf52832_xxaa/bootloader.o: No such file or directory
../../../../nRF5_SDK/components/toolchain/gcc/Makefile.common:292: recipe for target '_build/nrf52832_xxaa.out' failed
make: *** [_build/nrf52832_xxaa.out] Error 1
The steps I took was to start with the BLE application I have(That is working. start from hrs example), and I added BLE service for DFU to it from the `ble_app_buttonless_dfu` project.
Basically I added
    // Initialize the async SVCI interface to bootloader.
    err_code = ble_dfu_buttonless_async_svci_init();
    dfus_init.evt_handler = ble_dfu_evt_handler;
    err_code = ble_dfu_buttonless_init(&dfus_init);
and
`static void ble_dfu_evt_handler(ble_dfu_buttonless_evt_type_t event)` function and all the dependencies to them.
I just dont understand where to start debugging this. The Error message is not giving me enough information on where to start
I could not find documentation for integration buttonless DFU into an exisitng DFU project.
Can I get pointers on how to integrate buttonless  DFU(Adding DFU service)
    Could you give more information about the SDK version you used ?
    Could you send the makefile you have  ?
  • Here is the Make file
    ROJECT_NAME     := ble_app_hrs_pca10040_s132
    TARGETS          := nrf52832_xxaa
    OUTPUT_DIRECTORY := _build
    SDK_ROOT := ../../../../nRF5_SDK
    UHMS_ROOT := ../../../../
    PROJ_DIR := ../../..
    $(OUTPUT_DIRECTORY)/nrf52832_xxaa.out: \
      LINKER_SCRIPT  := ble_app_hrs_gcc_nrf52.ld
    # Source files common to all targets
    SRC_FILES += \
      $(SDK_ROOT)/modules/nrfx/mdk/gcc_startup_nrf52.S \
      $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_backend_rtt.c \
      $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_backend_serial.c \
      $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_backend_uart.c \
      $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_default_backends.c \
      $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_frontend.c \
      $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_str_formatter.c \
      $(SDK_ROOT)/components/libraries/button/app_button.c \
      $(SDK_ROOT)/components/libraries/util/app_error.c \
      $(SDK_ROOT)/components/libraries/util/app_error_handler_gcc.c \
      $(SDK_ROOT)/components/libraries/util/app_error_weak.c \
      $(SDK_ROOT)/components/libraries/scheduler/app_scheduler.c \
      $(SDK_ROOT)/components/libraries/timer/app_timer.c \
      $(SDK_ROOT)/components/libraries/util/app_util_platform.c \
      $(SDK_ROOT)/components/libraries/crc16/crc16.c \
      $(SDK_ROOT)/components/libraries/fds/fds.c \
      $(SDK_ROOT)/components/libraries/hardfault/hardfault_implementation.c \
      $(SDK_ROOT)/components/libraries/util/nrf_assert.c \
      $(SDK_ROOT)/components/libraries/atomic_fifo/nrf_atfifo.c \
      $(SDK_ROOT)/components/libraries/atomic_flags/nrf_atflags.c \
      $(SDK_ROOT)/components/libraries/atomic/nrf_atomic.c \
      $(SDK_ROOT)/components/libraries/balloc/nrf_balloc.c \
      $(SDK_ROOT)/external/fprintf/nrf_fprintf.c \
      $(SDK_ROOT)/external/fprintf/nrf_fprintf_format.c \
      $(SDK_ROOT)/components/libraries/fstorage/nrf_fstorage.c \
      $(SDK_ROOT)/components/libraries/fstorage/nrf_fstorage_sd.c \
      $(SDK_ROOT)/components/libraries/experimental_memobj/nrf_memobj.c \
      $(SDK_ROOT)/components/libraries/pwr_mgmt/nrf_pwr_mgmt.c \
      $(SDK_ROOT)/components/libraries/experimental_section_vars/nrf_section_iter.c \
      $(SDK_ROOT)/components/libraries/strerror/nrf_strerror.c \
      $(SDK_ROOT)/components/libraries/sensorsim/sensorsim.c \
      $(SDK_ROOT)/modules/nrfx/mdk/system_nrf52.c \
      $(SDK_ROOT)/components/boards/boards.c \
      $(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_clock.c \
      $(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_uart.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_clock.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_gpiote.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_power_clock.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/prs/nrfx_prs.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_uart.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_uarte.c \
      $(SDK_ROOT)/components/libraries/bsp/bsp.c \
      $(SDK_ROOT)/components/libraries/bsp/bsp_btn_ble.c \
      $(PROJ_DIR)/main.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_Syscalls_GCC.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_printf.c \
      $(SDK_ROOT)/components/ble/common/ble_advdata.c \
      $(SDK_ROOT)/components/ble/ble_advertising/ble_advertising.c \
      $(SDK_ROOT)/components/ble/common/ble_conn_params.c \
      $(SDK_ROOT)/components/ble/common/ble_conn_state.c \
      $(SDK_ROOT)/components/ble/common/ble_srv_common.c \
      $(SDK_ROOT)/components/ble/peer_manager/gatt_cache_manager.c \
      $(SDK_ROOT)/components/ble/peer_manager/gatts_cache_manager.c \
      $(SDK_ROOT)/components/ble/peer_manager/id_manager.c \
      $(SDK_ROOT)/components/ble/nrf_ble_gatt/nrf_ble_gatt.c \
      $(SDK_ROOT)/components/ble/nrf_ble_qwr/nrf_ble_qwr.c \
      $(SDK_ROOT)/components/ble/peer_manager/peer_data_storage.c \
      $(SDK_ROOT)/components/ble/peer_manager/peer_database.c \
      $(SDK_ROOT)/components/ble/peer_manager/peer_id.c \
      $(SDK_ROOT)/components/ble/peer_manager/peer_manager.c \
      $(SDK_ROOT)/components/ble/peer_manager/pm_buffer.c \
      $(SDK_ROOT)/components/ble/peer_manager/pm_mutex.c \
      $(SDK_ROOT)/components/ble/peer_manager/security_dispatcher.c \
      $(SDK_ROOT)/components/ble/peer_manager/security_manager.c \
      $(SDK_ROOT)/components/ble/ble_services/ble_bas/ble_bas.c \
      $(SDK_ROOT)/components/ble/ble_services/ble_dis/ble_dis.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh_ble.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh_soc.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_spi.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_spim.c \
      $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_pdm.c \
      $(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_spi.c \
      $(UHMS_ROOT)/sensor_library/bmi160/driver/bmi160.c \
      $(UHMS_ROOT)/sensor_library/bmi160/ble/ble_bmi160.c \
      $(UHMS_ROOT)/sensor_library/max30001/driver/max30001.c \
      $(UHMS_ROOT)/sensor_library/max30001/ble/ble_max30001.c \
    # Include folders common to all targets
    INC_FOLDERS += \
      $(SDK_ROOT)/components/nfc/ndef/generic/message \
      $(SDK_ROOT)/components/nfc/t2t_lib \
      $(SDK_ROOT)/components/nfc/t4t_parser/hl_detection_procedure \
      $(SDK_ROOT)/components/ble/ble_services/ble_ancs_c \
      $(SDK_ROOT)/components/ble/ble_services/ble_ias_c \
      $(SDK_ROOT)/components/libraries/pwm \
      $(SDK_ROOT)/components/softdevice/s132/headers/nrf52 \
      $(SDK_ROOT)/components/libraries/usbd/class/cdc/acm \
      $(SDK_ROOT)/components/libraries/usbd/class/hid/generic \
      $(SDK_ROOT)/components/libraries/usbd/class/msc \
      $(SDK_ROOT)/components/libraries/usbd/class/hid \
      $(SDK_ROOT)/modules/nrfx/hal \
      $(SDK_ROOT)/components/libraries/experimental_log \
      $(SDK_ROOT)/components/ble/ble_services/ble_gls \
      $(SDK_ROOT)/components/libraries/fstorage \
      $(SDK_ROOT)/components/nfc/ndef/text \
      $(SDK_ROOT)/components/libraries/mutex \
      $(SDK_ROOT)/components/libraries/gpiote \
      $(SDK_ROOT)/components/libraries/experimental_log/src \
      $(SDK_ROOT)/components/libraries/bootloader/ble_dfu \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/common \
      $(SDK_ROOT)/components/boards \
      $(SDK_ROOT)/components/nfc/ndef/generic/record \
      $(SDK_ROOT)/components/libraries/experimental_memobj \
      $(SDK_ROOT)/components/nfc/t4t_parser/cc_file \
      $(SDK_ROOT)/components/ble/ble_advertising \
      $(SDK_ROOT)/components/ble/ble_services/ble_bas_c \
      $(SDK_ROOT)/modules/nrfx/drivers/include \
      $(SDK_ROOT)/components/libraries/experimental_task_manager \
      $(SDK_ROOT)/components/ble/ble_services/ble_hrs_c \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/le_oob_rec \
      $(SDK_ROOT)/components/libraries/queue \
      $(SDK_ROOT)/components/libraries/pwr_mgmt \
      $(SDK_ROOT)/components/ble/ble_dtm \
      $(SDK_ROOT)/components/toolchain/cmsis/include \
      $(SDK_ROOT)/components/ble/ble_services/ble_rscs_c \
      $(SDK_ROOT)/components/ble/common \
      $(SDK_ROOT)/components/ble/ble_services/ble_lls \
      $(SDK_ROOT)/components/libraries/bsp \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/ac_rec \
      $(SDK_ROOT)/components/ble/ble_services/ble_bas \
      $(SDK_ROOT)/components/libraries/experimental_section_vars \
      $(SDK_ROOT)/components/softdevice/s132/headers \
      $(SDK_ROOT)/components/ble/ble_services/ble_ans_c \
      $(SDK_ROOT)/components/libraries/slip \
      $(SDK_ROOT)/components/libraries/delay \
      $(SDK_ROOT)/components/libraries/experimental_mpu \
      $(SDK_ROOT)/components/libraries/mem_manager \
      $(SDK_ROOT)/components/libraries/csense_drv \
      $(SDK_ROOT)/components/ble/ble_services/ble_nus_c \
      $(SDK_ROOT)/components/libraries/usbd/config \
      $(SDK_ROOT)/components/softdevice/common \
      $(SDK_ROOT)/components/ble/ble_services/ble_ias \
      $(SDK_ROOT)/components/libraries/usbd/class/hid/mouse \
      $(SDK_ROOT)/components/libraries/low_power_pwm \
      $(SDK_ROOT)/components/nfc/ndef/conn_hand_parser/ble_oob_advdata_parser \
      $(SDK_ROOT)/components/ble/ble_services/ble_dfu \
      $(SDK_ROOT)/external/fprintf \
      $(SDK_ROOT)/components/libraries/atomic \
      $(SDK_ROOT)/components \
      $(SDK_ROOT)/components/libraries/scheduler \
      $(SDK_ROOT)/components/libraries/cli \
      $(SDK_ROOT)/components/ble/ble_services/ble_lbs \
      $(SDK_ROOT)/components/ble/ble_services/ble_hts \
      $(SDK_ROOT)/components/libraries/crc16 \
      $(SDK_ROOT)/components/nfc/t4t_parser/apdu \
      $(SDK_ROOT)/components/libraries/util \
      ../config \
      $(SDK_ROOT)/components/libraries/usbd/class/cdc \
      $(SDK_ROOT)/components/libraries/csense \
      $(SDK_ROOT)/components/libraries/balloc \
      $(SDK_ROOT)/components/libraries/ecc \
      $(SDK_ROOT)/components/libraries/hardfault \
      $(SDK_ROOT)/components/ble/ble_services/ble_cscs \
      $(SDK_ROOT)/components/libraries/hci \
      $(SDK_ROOT)/components/libraries/timer \
      $(SDK_ROOT)/integration/nrfx \
      $(SDK_ROOT)/components/nfc/t4t_parser/tlv \
      $(SDK_ROOT)/components/libraries/sortlist \
      $(SDK_ROOT)/components/libraries/spi_mngr \
      $(SDK_ROOT)/components/libraries/experimental_stack_guard \
      $(SDK_ROOT)/components/libraries/led_softblink \
      $(SDK_ROOT)/components/nfc/ndef/conn_hand_parser \
      $(SDK_ROOT)/components/libraries/sdcard \
      $(SDK_ROOT)/components/nfc/ndef/parser/record \
      $(SDK_ROOT)/modules/nrfx/mdk \
      $(SDK_ROOT)/components/ble/ble_services/ble_cts_c \
      $(SDK_ROOT)/components/nfc/ndef/conn_hand_parser/le_oob_rec_parser \
      $(SDK_ROOT)/components/ble/ble_services/ble_nus \
      $(SDK_ROOT)/components/libraries/twi_mngr \
      $(SDK_ROOT)/components/ble/ble_services/ble_hids \
      $(SDK_ROOT)/components/libraries/strerror \
      $(SDK_ROOT)/components/libraries/crc32 \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/ble_oob_advdata \
      $(SDK_ROOT)/components/nfc/t2t_parser \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/ble_pair_msg \
      $(SDK_ROOT)/components/libraries/usbd/class/audio \
      $(SDK_ROOT)/components/nfc/t4t_lib/hal_t4t \
      $(SDK_ROOT)/components/libraries/sensorsim \
      $(SDK_ROOT)/components/nfc/t4t_lib \
      $(SDK_ROOT)/components/ble/peer_manager \
      $(SDK_ROOT)/components/drivers_nrf/usbd \
      $(SDK_ROOT)/components/ble/ble_services/ble_tps \
      $(SDK_ROOT)/components/nfc/ndef/parser/message \
      $(SDK_ROOT)/components/ble/ble_services/ble_dis \
      $(SDK_ROOT)/components/nfc/ndef/uri \
      $(SDK_ROOT)/components/ble/nrf_ble_gatt \
      $(SDK_ROOT)/components/ble/nrf_ble_qwr \
      $(SDK_ROOT)/components/libraries/gfx \
      $(SDK_ROOT)/components/libraries/button \
      $(SDK_ROOT)/modules/nrfx \
      $(SDK_ROOT)/components/libraries/twi_sensor \
      $(SDK_ROOT)/integration/nrfx/legacy \
      $(SDK_ROOT)/components/libraries/usbd/class/hid/kbd \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/ep_oob_rec \
      $(SDK_ROOT)/external/segger_rtt \
      $(SDK_ROOT)/components/libraries/atomic_fifo \
      $(SDK_ROOT)/components/libraries/experimental_ringbuf \
      $(SDK_ROOT)/components/ble/ble_services/ble_lbs_c \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/ble_pair_lib \
      $(SDK_ROOT)/components/libraries/crypto \
      $(SDK_ROOT)/components/ble/ble_racp \
      $(SDK_ROOT)/components/libraries/fds \
      $(SDK_ROOT)/components/nfc/ndef/launchapp \
      $(SDK_ROOT)/components/libraries/atomic_flags \
      $(SDK_ROOT)/components/ble/ble_services/ble_rscs \
      $(SDK_ROOT)/components/nfc/ndef/connection_handover/hs_rec \
      $(SDK_ROOT)/components/nfc/t2t_lib/hal_t2t \
      $(SDK_ROOT)/components/libraries/usbd \
      $(SDK_ROOT)/components/nfc/ndef/conn_hand_parser/ac_rec_parser \
      $(UHMS_ROOT)/sensor_library/bmi160/driver \
      $(UHMS_ROOT)/sensor_library/bmi160/ble \
      $(UHMS_ROOT)/sensor_library/max30001/driver \
      $(UHMS_ROOT)/sensor_library/max30001/ble \
    # Libraries common to all targets
    LIB_FILES += \
    # Optimization flags
    OPT = -O3 -g3
    # Uncomment the line below to enable link time optimization
    #OPT += -flto
    # C flags common to all targets
    CFLAGS += $(OPT)
    CFLAGS += -DBLE_STACK_SUPPORT_REQD
    CFLAGS += -DBOARD_PCA10040
    CFLAGS += -DCONFIG_GPIO_AS_PINRESET
    CFLAGS += -DFLOAT_ABI_HARD
    CFLAGS += -DNRF52
    CFLAGS += -DNRF52832_XXAA
    CFLAGS += -DNRF52_PAN_74
    CFLAGS += -DNRF_SD_BLE_API_VERSION=6
    CFLAGS += -DS132
    CFLAGS += -DSOFTDEVICE_PRESENT
    CFLAGS += -DSWI_DISABLE0
    CFLAGS += -mcpu=cortex-m4
    CFLAGS += -mthumb -mabi=aapcs
    CFLAGS += -Wall -Werror
    CFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # keep every function in a separate section, this allows linker to discard unused ones
    CFLAGS += -ffunction-sections -fdata-sections -fno-strict-aliasing
    CFLAGS += -fno-builtin -fshort-enums
    # C++ flags common to all targets
    CXXFLAGS += $(OPT)
    # Assembler flags common to all targets
    ASMFLAGS += -g3
    ASMFLAGS += -mcpu=cortex-m4
    ASMFLAGS += -mthumb -mabi=aapcs
    ASMFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    ASMFLAGS += -DBLE_STACK_SUPPORT_REQD
    ASMFLAGS += -DBOARD_PCA10040
    ASMFLAGS += -DCONFIG_GPIO_AS_PINRESET
    ASMFLAGS += -DFLOAT_ABI_HARD
    ASMFLAGS += -DNRF52
    ASMFLAGS += -DNRF52832_XXAA
    ASMFLAGS += -DNRF52_PAN_74
    ASMFLAGS += -DNRF_SD_BLE_API_VERSION=6
    ASMFLAGS += -DS132
    ASMFLAGS += -DSOFTDEVICE_PRESENT
    ASMFLAGS += -DSWI_DISABLE0
    # Linker flags
    LDFLAGS += $(OPT)
    LDFLAGS += -mthumb -mabi=aapcs -L$(SDK_ROOT)/modules/nrfx/mdk -T$(LINKER_SCRIPT)
    LDFLAGS += -mcpu=cortex-m4
    LDFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # let linker dump unused sections
    LDFLAGS += -Wl,--gc-sections
    # use newlib in nano version
    LDFLAGS += --specs=nano.specs
    nrf52832_xxaa: CFLAGS += -D__HEAP_SIZE=8192
    nrf52832_xxaa: CFLAGS += -D__STACK_SIZE=8192
    nrf52832_xxaa: ASMFLAGS += -D__HEAP_SIZE=8192
    nrf52832_xxaa: ASMFLAGS += -D__STACK_SIZE=8192
    # Add standard libraries at the very end of the linker input, after all objects
    # that may need symbols provided by these libraries.
    LIB_FILES += -lc -lnosys -lm
    .PHONY: default help
    # Default target - first one defined
    default: nrf52832_xxaa
    # Print all targets that can be built
    help:
    	@echo following targets are available:
    	@echo		nrf52832_xxaa
    	@echo		flash_softdevice
    	@echo		sdk_config - starting external tool for editing sdk_config.h
    	@echo		flash      - flashing binary
    TEMPLATE_PATH := $(SDK_ROOT)/components/toolchain/gcc
    include $(TEMPLATE_PATH)/Makefile.common
    $(foreach target, $(TARGETS), $(call define_target, $(target)))
    .PHONY: flash flash_softdevice erase
    # Flash the program
    flash: $(OUTPUT_DIRECTORY)/nrf52832_xxaa.hex
    	@echo Flashing: $<
    	nrfjprog -f nrf52 --program $< --sectorerase
    	nrfjprog -f nrf52 --reset
    # Flash softdevice
    flash_softdevice:
    	@echo Flashing: s132_nrf52_6.0.0_softdevice.hex
    	nrfjprog -f nrf52 --program $(SDK_ROOT)/components/softdevice/s132/hex/s132_nrf52_6.0.0_softdevice.hex --sectorerase
    erase:
    	nrfjprog -f nrf52 --eraseall
    SDK_CONFIG_FILE := ../config/sdk_config.h
    CMSIS_CONFIG_TOOL := $(SDK_ROOT)/external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar
    sdk_config:
    	java -jar $(CMSIS_CONFIG_TOOL) $(SDK_CONFIG_FILE)
    I am also not sure if there were modifications I needed to make on my id file.
    I am attaching that too just in case
    /* Linker script to configure memory regions. */
    SEARCH_DIR(.)
    GROUP(-lgcc -lc -lnosys)
    MEMORY
      FLASH (rx) : ORIGIN = 0x26000, LENGTH = 0x5a000
      RAM (rwx) :  ORIGIN = 0x20002b90, LENGTH = 0xd470
    SECTIONS
    SECTIONS
      . = ALIGN(4);
      .mem_section_dummy_ram :
      .log_dynamic_data :
        PROVIDE(__start_log_dynamic_data = .);
        KEEP(*(SORT(.log_dynamic_data*)))
        PROVIDE(__stop_log_dynamic_data = .);
      } > RAM
      .fs_data :
        PROVIDE(__start_fs_data = .);
        KEEP(*(.fs_data))
        PROVIDE(__stop_fs_data = .);
      } > RAM
      .cli_sorted_cmd_ptrs :
        PROVIDE(__start_cli_sorted_cmd_ptrs = .);
        KEEP(*(.cli_sorted_cmd_ptrs))
        PROVIDE(__stop_cli_sorted_cmd_ptrs = .);
      } > RAM
    } INSERT AFTER .data;
    SECTIONS
      .mem_section_dummy_rom :
      .sdh_soc_observers :
        PROVIDE(__start_sdh_soc_observers = .);
        KEEP(*(SORT(.sdh_soc_observers*)))
        PROVIDE(__stop_sdh_soc_observers = .);
      } > FLASH
      .sdh_ble_observers :
        PROVIDE(__start_sdh_ble_observers = .);
        KEEP(*(SORT(.sdh_ble_observers*)))
        PROVIDE(__stop_sdh_ble_observers = .);
      } > FLASH
      .pwr_mgmt_data :
        PROVIDE(__start_pwr_mgmt_data = .);
        KEEP(*(SORT(.pwr_mgmt_data*)))
        PROVIDE(__stop_pwr_mgmt_data = .);
      } > FLASH
      .log_const_data :
        PROVIDE(__start_log_const_data = .);
        KEEP(*(SORT(.log_const_data*)))
        PROVIDE(__stop_log_const_data = .);
      } > FLASH
        .nrf_balloc :
        PROVIDE(__start_nrf_balloc = .);
        KEEP(*(.nrf_balloc))
        PROVIDE(__stop_nrf_balloc = .);
      } > FLASH
      .sdh_state_observers :
        PROVIDE(__start_sdh_state_observers = .);
        KEEP(*(SORT(.sdh_state_observers*)))
        PROVIDE(__stop_sdh_state_observers = .);
      } > FLASH
      .sdh_stack_observers :
        PROVIDE(__start_sdh_stack_observers = .);
        KEEP(*(SORT(.sdh_stack_observers*)))
        PROVIDE(__stop_sdh_stack_observers = .);
      } > FLASH
      .sdh_req_observers :
        PROVIDE(__start_sdh_req_observers = .);
        KEEP(*(SORT(.sdh_req_observers*)))
        PROVIDE(__stop_sdh_req_observers = .);
      } > FLASH
        .nrf_queue :
        PROVIDE(__start_nrf_queue = .);
        KEEP(*(.nrf_queue))
        PROVIDE(__stop_nrf_queue = .);
      } > FLASH
        .cli_command :
        PROVIDE(__start_cli_command = .);
        KEEP(*(.cli_command))
        PROVIDE(__stop_cli_command = .);
      } > FLASH
      .crypto_data :
        PROVIDE(__start_crypto_data = .);
        KEEP(*(SORT(.crypto_data*)))
        PROVIDE(__stop_crypto_data = .);
      } > FLASH
    } INSERT AFTER .text
    INCLUDE "nrf_common.ld"
    Can you zip your whole project ? I want to see the main.c file.
    However, I don't see in your make file you include :
    Files:
    $(SDK_ROOT)/components/libraries/bootloader/dfu/nrf_dfu_svci.c \
    $(SDK_ROOT)/components/ble/ble_services/ble_dfu/ble_dfu.c \
    $(SDK_ROOT)/components/ble/ble_services/ble_dfu/ble_dfu_unbonded.c \
    Path:
    Flag:
    CFLAGS += -DNRF_DFU_SVCI_ENABLED
    CFLAGS += -DNRF_DFU_TRANSPORT_BLE=1
    ASMFLAGS += -DNRF_DFU_SVCI_ENABLED
    ASMFLAGS += -DNRF_DFU_TRANSPORT_BLE=1
    In your main.c you need to initialize and add the dfu service in:
    And the handler:
    static void buttonless_dfu_sdh_state_observer(nrf_sdh_state_evt_t state, void * p_context)
        if (state == NRF_SDH_EVT_STATE_DISABLED)
            // Softdevice was disabled before going into reset. Inform bootloader to skip CRC on next boot.
            nrf_power_gpregret2_set(BOOTLOADER_DFU_SKIP_CRC);
            //Go to system off.
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
    /* nrf_sdh state observer. */
    NRF_SDH_STATE_OBSERVER(m_buttonless_dfu_state_obs, 0) =
        .handler = buttonless_dfu_sdh_state_observer,
    // YOUR_JOB: Update this code if you want to do anything given a DFU event (optional).
    /**@brief Function for handling dfu events from the Buttonless Secure DFU service
     * @param[in]   event   Event from the Buttonless Secure DFU service.
        switch (event)
            case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE:
                NRF_LOG_INFO("Device is preparing to enter bootloader mode.");
                // YOUR_JOB: Disconnect all bonded devices that currently are connected.
                //           This is required to receive a service changed indication
                //           on bootup after a successful (or aborted) Device Firmware Update.
            case BLE_DFU_EVT_BOOTLOADER_ENTER:
                // YOUR_JOB: Write app-specific unwritten data to FLASH, control finalization of this
                //           by delaying reset by reporting false in app_shutdown_handler
                NRF_LOG_INFO("Device will enter bootloader mode.");
            case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED:
                NRF_LOG_ERROR("Request to enter bootloader mode failed asynchroneously.");
                // YOUR_JOB: Take corrective measures to resolve the issue
                //           like calling APP_ERROR_CHECK to reset the device.
            case BLE_DFU_EVT_RESPONSE_SEND_ERROR:
                NRF_LOG_ERROR("Request to send a response to client failed.");
                APP_ERROR_CHECK(false);
                NRF_LOG_ERROR("Unknown event from ble_dfu_buttonless.");
    Have you referred to the ble_app_buttonless_dfu example ?
  • Hello Hung,
    Following your suggestions and changing the Memory config to
    MEMORY
      RAM (rwx) :  ORIGIN = 0x20002a98, LENGTH = 0xd568
    got my application working Slight smile
    Before we end this thread, I do have questions on how I am suppose to configure the ram for additional services.
    I read few articles, but am still confused on how to configure the ram. Particularly, RAM's ORIGIN and LENGTH.
    <warning> nrf_sdh_ble: Insufficient RAM allocated for the SoftDevice.
    <warning> nrf_sdh_ble: Change the RAM start location from 0x20002228 to 0x200022D8.
    <warning> nrf_sdh_ble: Maximum RAM size for application is 0xDD28.
    If I get messages like this,
    How do I handle this,
    In the case above, do I just change ORIGIN from 0x20002228 to 0x200022D8 and add the difference to LENGTH?
    Are there additinal restricitons or rule I should be awareable of? LIke how high the ORIGIN should be?
    I had to try various values to get it to work for me.
    Thanks in advance
    I'm glad that it worked.
    Regarding your question, you can just follow what suggested in the log: change the RAM ORIGIN to 0x200022D8 and LENGTH to 0xDD28
