buttonless DFU integration in BLE app uart example: compiling problem
I'm trying to integrate buttonless DFU in BLE app uart example. I added the file: ble_dfu.c, ble_dfu_bonded.c, ble_dfu_unbonded.c in the project. I added the following folder:
C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\libraries\svc
C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\libraries\bootloader\dfu
C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_dfu
C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\libraries\bootloader\ble_dfu
in Preprocessor->User include Directories (in Options of the project). I'm using segger embedded studio.
I've got several compilation errors:
2> C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_dfu\ble_dfu_unbonded.c:61:55: error: unknown type name 'nrf_dfu_set_adv_name_svci_async_t'
2> C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_dfu\ble_dfu_unbonded.c:61:77: error: unknown type name 'nrf_dfu_adv_name_t'
2> c:\nordic_semi\nrf5_sdk_15.0.0_a53641a\components\libraries\svc\nrf_svci_async_function.h:174:35: error: request for member 'sys_evt_handler' in something not a structure or union
2> c:\nordic_semi\nrf5_sdk_15.0.0_a53641a\components\libraries\svc\nrf_svci_async_function.h:174:85: error: request for member 'state' in something not a structure or union
2> c:\nordic_semi\nrf5_sdk_15.0.0_a53641a\components\libraries\svc\nrf_svci_async_function.h:179:36: error: request for member 'async_func' in something not a structure or union
2> c:\nordic_semi\nrf5_sdk_15.0.0_a53641a\components\libraries\svc\nrf_svci_async_function.h:180:32: error: request for member 'sys_evt_handler' in something not a structure or union
2> C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_dfu\ble_dfu_unbonded.c:67:8: error: unknown type name 'nrf_dfu_adv_name_t'
2> C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_dfu\ble_dfu_unbonded.c:78:30: error: unknown type name 'nrf_dfu_adv_name_t'
2> C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_dfu\ble_dfu_unbonded.c:283:34: error: request for member 'name' in something not a structure or union
2> C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_dfu\ble_dfu_unbonded.c:284:27: error: request for member 'len' in something not a structure or union
Build failed
There is a guide or an application note that explains the several steps needed to integrate buttonless DFU to a custom application???
  • I solved the compilation problems. I'll try the functionality in the next days.
    There are news regarding official documentation about integration of buttonless DFU to a custom application?
  • I solved the compilation problems. I changed the function "services_init(void)" of project app_uart_example in:
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        ble_dfu_buttonless_init_t dfus_init = {0};
        // Initialize NUS.
    //***** buttonless DFU *****
        // Initialize the async SVCI interface to bootloader.
        err_code = ble_dfu_buttonless_async_svci_init();
        dfus_init.evt_handler = ble_dfu_evt_handler;
        err_code = ble_dfu_buttonless_init(&dfus_init);
    but in executio I've got error " NRF_BREAKPOINT_COND;" in function "__WEAK void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)"
  • Just in case someone else runs into the same compilation issues:
    As stated by you have to add the following files to the project
    ble_dfu.c
    ble_dfu_bonded.c
    ble_dfu_unbonded.c
    nrf_dfu_svci.c
    You have to add the following paths to Preprocessor->User include Directories  the Common build configuration
    ../../../../../../components/libraries/bootloader
    ../../../../../../components/libraries/bootloader/ble_dfu
    ../../../../../../components/libraries/bootloader/dfu
    ../../../../../../components/libraries/svc
    and lastly you need to add the following Preprocessor Defines
    BL_SETTINGS_ACCESS_ONLY
    NRF_DFU_SVCI_ENABLED
    NRF_DFU_TRANSPORT_BLE=1
  • : We do not have an official guide on how to add the DFU service to a custom application.
    If you're entering the app_error_fault_handler function then there is probably a APP_ERROR_CHECK(err_code) check that is asserting. Could you place a breakpoint in app_error_handler_bare() in app_error.c and take a look at the call stack to see which function that caused the assert?
    Bjørn
  • I can't place a breakpoint app_error_handler_bare(), the IDE tell me "no code for breakpoint".
    In debugging I've got "NRF_ERROR_NO_MEM" form function "sd_ble_uuid_vs_add(&nordic_base_uuid, &m_dfu.uuid_type);" in "uint32_t ble_dfu_buttonless_init(const ble_dfu_buttonless_init_t * p_dfu_init)"
