buttonless DFU integration in BLE app uart example: compiling problem
I'm trying to integrate buttonless DFU in BLE app uart example. I added the file: ble_dfu.c, ble_dfu_bonded.c, ble_dfu_unbonded.c in the project. I added the following folder:
C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\libraries\svc
C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\libraries\bootloader\dfu
C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_dfu
C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\libraries\bootloader\ble_dfu
in Preprocessor->User include Directories (in Options of the project). I'm using segger embedded studio.
I've got several compilation errors:
2> C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_dfu\ble_dfu_unbonded.c:61:55: error: unknown type name 'nrf_dfu_set_adv_name_svci_async_t'
2> C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_dfu\ble_dfu_unbonded.c:61:77: error: unknown type name 'nrf_dfu_adv_name_t'
2> c:\nordic_semi\nrf5_sdk_15.0.0_a53641a\components\libraries\svc\nrf_svci_async_function.h:174:35: error: request for member 'sys_evt_handler' in something not a structure or union
2> c:\nordic_semi\nrf5_sdk_15.0.0_a53641a\components\libraries\svc\nrf_svci_async_function.h:174:85: error: request for member 'state' in something not a structure or union
2> c:\nordic_semi\nrf5_sdk_15.0.0_a53641a\components\libraries\svc\nrf_svci_async_function.h:179:36: error: request for member 'async_func' in something not a structure or union
2> c:\nordic_semi\nrf5_sdk_15.0.0_a53641a\components\libraries\svc\nrf_svci_async_function.h:180:32: error: request for member 'sys_evt_handler' in something not a structure or union
2> C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_dfu\ble_dfu_unbonded.c:67:8: error: unknown type name 'nrf_dfu_adv_name_t'
2> C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_dfu\ble_dfu_unbonded.c:78:30: error: unknown type name 'nrf_dfu_adv_name_t'
2> C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_dfu\ble_dfu_unbonded.c:283:34: error: request for member 'name' in something not a structure or union
2> C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\components\ble\ble_services\ble_dfu\ble_dfu_unbonded.c:284:27: error: request for member 'len' in something not a structure or union
Build failed
There is a guide or an application note that explains the several steps needed to integrate buttonless DFU to a custom application???
  • I have increased memory and it seems to work. Wow! What a hard job! I suggest you to make a guide or an application note on how to add the DFU service to a custom application..
    Thanks for the support
    Best regards
  • Hi Mdido
    Can I have your integrated main.c and sdk_config.h  file?
    I have tried it so many times but still it is not working.
  • In main.c you have to add the service for buttonless dfu:
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        ble_dfu_buttonless_init_t dfus_init = {0};
        ble_dis_init_t     dis_init;
        // Initialize NUS.
    #if defined(NDEBUG)
    //***** buttonless DFU *****
        // Initialize the async SVCI interface to bootloader.
        err_code = ble_dfu_buttonless_async_svci_init();
        dfus_init.evt_handler = ble_dfu_evt_handler;
        err_code = ble_dfu_buttonless_init(&dfus_init);
    //************ Battery Service *********************
        ble_bas_init_t bas_init;
        memset(&bas_init, 0, sizeof(bas_init));
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.cccd_write_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&bas_init.battery_level_char_attr_md.write_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_report_read_perm);
        bas_init.evt_handler = NULL;
        bas_init.support_notification = true;
        bas_init.p_report_ref = NULL;
        bas_init.initial_batt_level = 100;
        err_code = ble_bas_init(&m_bas,&bas_init);
     //********** Initialize Device Information Service *************
        memset(&dis_init, 0, sizeof(dis_init));
        ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
        ble_srv_ascii_to_utf8(&dis_init.fw_rev_str, (char *)SW_REV);
        ble_srv_ascii_to_utf8(&dis_init.sw_rev_str, (char *)SW_REV);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&dis_init.dis_attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&dis_init.dis_attr_md.write_perm);
        err_code = ble_dis_init(&dis_init);
    What is the specific problem?
    Best regards
