Hi everyone,
I changed the example ble_app_beacon from sdk 15.0.0 sd132 to be able to scan beacon besides transmit. It works well to scan beacons and I can get their UUID's. But I need to read the tx power reference at 1 meter sended by the Smartphone that I believe is the tx_power from p_gap_evt->params.adv_report.tx_power. I tryied to change this value even in nRF Connect app, but the value is fixed at 0x7F.
I found this from ble_gap.h:
at line 232:
/** @brief Invalid power level. */
#define BLE_GAP_POWER_LEVEL_INVALID 127
at line 1260:
int8_t tx_power /**< TX Power reported by the advertiser in the last packet header received. This field is set to @ref BLE_GAP_POWER_LEVEL_INVALID if the last received packet did not contain the Tx Power field. @note TX Power is only included in extended advertising packets. */
I know that the value is being sended because I already tested in other hardware from other manufacturer many times. So I think I forgot some configuration in my code.
I attached my code to help you help me ;)
Any help will be appreciate.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "bsp.h"
#include "nrf_soc.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "ble_advdata.h"
#include "app_timer.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "ble_conn_state.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
static ble_gap_adv_params_t m_adv_params; /**< Parameters to be passed to the stack when starting advertising. */
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded advertising set. */
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
.adv_data =
.p_data = m_enc_advdata,
.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
.scan_rsp_data =
.p_data = NULL,
.len = 0
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] = /**< Information advertised by the Beacon. */
APP_DEVICE_TYPE, // Manufacturer specific information. Specifies the device type in this
// implementation.
APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
// manufacturer specific data in this implementation.
APP_BEACON_UUID, // 128 bit UUID value.
APP_MAJOR_VALUE, // Major arbitrary value that can be used to distinguish between Beacons.
APP_MINOR_VALUE, // Minor arbitrary value that can be used to distinguish between Beacons.
APP_MEASURED_RSSI // Manufacturer specific information. The Beacon's measured TX power in
// this implementation.
/**@brief Parameters used when scanning. */
static ble_gap_scan_params_t const m_scan_params =
.extended = 1,
.active = 0,
.interval = SCAN_INTERVAL,
.window = SCAN_WINDOW,
.timeout = SCAN_DURATION,
.scan_phys = BLE_GAP_PHY_1MBPS,
.filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_EXTENDED_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
/**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
static ble_data_t m_scan_buffer =
m_scan_buffer_data,
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
* @details Encodes the required advertising data and passes it to the stack.
* Also builds a structure to be passed to the stack when starting advertising.
uint32_t err_code;
ble_advdata_t advdata;
uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
ble_advdata_manuf_data_t manuf_specific_data;
manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH;
// Build and set advertising data.
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_NO_NAME;
advdata.flags = flags;
advdata.p_manuf_specific_data = &manuf_specific_data;
// Initialize advertising parameters (used when starting advertising).
memset(&m_adv_params, 0, sizeof(m_adv_params));
m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
m_adv_params.p_peer_addr = NULL; // Undirected advertisement.
m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
m_adv_params.duration = 0; // Never time out.
err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
ret_code_t err_code;
err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
static void advertising_stop(void)
err_code = sd_ble_gap_adv_stop(m_adv_handle);
/**@brief Function for initiating scanning.
static void scan_start(void)
(void) sd_ble_gap_scan_stop();
err_code = sd_ble_gap_scan_start(&m_scan_params, &m_scan_buffer);
// It is okay to ignore this error since we are stopping the scan anyway.
static void scan_stop(void)
err_code = sd_ble_gap_scan_stop();
/**@brief Function for handling BLE events from central applications.
* @details This function parses scanning reports and initiates a connection to peripherals when a
* target UUID is found. It updates the status of LEDs used to report central applications
* activity.
* @param[in] p_ble_evt Bluetooth stack event.
static void on_ble_central_evt(ble_evt_t const * p_ble_evt)
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
uint8_t uuid[26];
// Upon connection, check which peripheral has connected (HR or RSC), initiate DB
// discovery, update LEDs status and resume scanning if necessary.
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Central connected");
} break; // BLE_GAP_EVT_CONNECTED
NRF_LOG_INFO("Central disconnected");
} break; // BLE_GAP_EVT_DISCONNECTED
case BLE_GAP_EVT_ADV_REPORT:
NRF_LOG_INFO("Advertise received");
scan_start();
nrf_gpio_pin_toggle(LED1_PIN);
memmove(uuid, p_gap_evt->params.adv_report.data.p_data, p_gap_evt->params.adv_report.data.len);
NRF_LOG_INFO("UUID: %02x%02x%02x%02x%02x%02x", uuid[0], uuid[1], uuid[2], uuid[3], uuid[4], uuid[5]);
NRF_LOG_INFO("TX_POWER: %02x", p_gap_evt->params.adv_report.tx_power);
NRF_LOG_INFO("RSSI: %02x", p_gap_evt->params.adv_report.rssi);
} break; // BLE_GAP_ADV_REPORT
// No implementation needed.
* @param[in] p_context Unused.
uint16_t conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
uint16_t role = ble_conn_state_role(conn_handle);
if ((role == BLE_GAP_ROLE_CENTRAL) || (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT))
on_ble_central_evt(p_ble_evt);
uint32_t ram_start = 0;
// Enable BLE stack.
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
gap_conn_params.min_conn_interval = MIN_CONNECTION_INTERVAL;
gap_conn_params.max_conn_interval = MAX_CONNECTION_INTERVAL;
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = SUPERVISION_TIMEOUT;
/**@brief Function for initializing logging. */
static void log_init(void)
/**@brief Function for initializing timers. */
static void timers_init(void)
nrf_pwr_mgmt_run();
* @brief Function for application main entry.
/* Configure board. */
nrf_gpio_cfg_output(LED1_PIN);
nrf_gpio_cfg_output(LED2_PIN);
// Initialize.
log_init();
timers_init();
power_management_init();
nrf_gpio_pin_set(LED1_PIN);
nrf_gpio_pin_set(LED2_PIN);
ble_stack_init();
gap_params_init();
advertising_init();
scan_start();
sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_SCAN_INIT, BLE_GAP_TX_POWER_ROLE_ADV, 4);
NRF_LOG_INFO("Beacon example started.");
// Enter main loop.
while(true)
idle_state_handle();
