Problem with using FDS
My setup:
* nRF52 DK
* nRF5_SDK_15.0.0_a53641a
* s132_nrf52_6.0.0
* SES V3.34b 64-bit.
I am struggling to properly use FDS module. I am using multiperipheral example, just for a training I would like to make something like this:
* write data to flash after button being pressed
* read data from flash after getting disconnected from a device.
I have followed lib_fds_usage and my code looks like this:
main.c
globals:
static fds_record_desc_t record_desc;
function definitions:
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
    ret_code_t err_code;
    switch (pin_no)
        case LEDBUTTON_BUTTON:
            err_code = led_status_send_to_all(button_action);
            if (err_code == NRF_SUCCESS)
                NRF_LOG_INFO("Sent button state change to all connected centrals.");
                uint32_t const m_deadbeef = 0xDEADBEEF;
                static char const m_hello[]  = "Hello, world!";
                fds_record_t record;
                record.file_id = 0x0003;
                record.key = 0x3111;
                record.data.p_data = &m_deadbeef;
                record.data.length_words = 1; // jedno slowo to 4 bajty
                ret_code_t rc;
                rc = fds_record_write(&record_desc, &record);
                if(rc != FDS_SUCCESS)
                    NRF_LOG_INFO("write error");
/*   ----    */  //[pawel]
            APP_ERROR_HANDLER(pin_no);
static void on_disconnected(ble_gap_evt_t const * const p_gap_evt)
    uint32_t    periph_link_cnt = ble_conn_state_peripheral_conn_count(); // Number of peripheral links.
    NRF_LOG_INFO("Connection 0x%x has been disconnected. Reason: 0x%X",
                 p_gap_evt->conn_handle,
                 p_gap_evt->params.disconnected.reason);
    if (periph_link_cnt == 0)
        bsp_board_led_off(CONNECTED_LED);
        err_code = app_button_disable();
    if (periph_link_cnt == (NRF_SDH_BLE_PERIPHERAL_LINK_COUNT - 1))
        // Advertising is not running when all connections are taken, and must therefore be started.
        advertising_start();
    fds_flash_record_t  flash_record;
   // fds_record_desc_t   record_desc;
    fds_find_token_t    ftok;
    //uint32_t *content;
    uint32_t *content = (uint32_t *) malloc (sizeof(uint32_t));
    uint8_t iter = 0;
    /* It is required to zero the token before first use. */
    memset(&ftok, 0x00, sizeof(fds_find_token_t));
    /* Loop until all records with the given key and file ID have been found. */
    while (fds_record_find(0x0003, 0x3111, &record_desc, &ftok) == FDS_SUCCESS)
        iter++;
        if (fds_record_open(&record_desc, &flash_record) != FDS_SUCCESS)
            /* Handle error. */
            NRF_LOG_INFO("error opening");
        /* Access the record through the flash_record structure. */
        content = (uint32_t *)(flash_record.p_data);
        //memcpy(zawartosc, flash_record.p_data, sizeof(uint32_t*));
        /* Close the record when done. */
        if (fds_record_close(&record_desc) != FDS_SUCCESS)
            /* Handle error. */
            NRF_LOG_INFO("error closing");
    NRF_LOG_INFO("content %d %x" , iter, *(content));
I get no errors, my terminal log looks like this:
<info> app: Multiperipheral example started.
<info> app: Connection with link 0x0 established.
<info> app: Sent button state change to all connected centrals.
<info> app: Connection 0x0 has been disconnected. Reason: 0x13
<info> app: content 26 2000FEB8
Why is it 0x2000FEB8 instead of 0xDEADBEEF? Where do I make a mistake?
