High power consumption of softdevice
Hello!
I am working on firmware for device that has freertos in the base and implements BLE beacon and 1 service with 7 characteristics. Everything works. But power consumption is too high.
After plenty of tests on final HW, I've created playground based on ble_app_hrs_freertos_pca10040_s132 sample project and switched to sparkfun board.
When have just FreeRTOS with no user-defined tasks, consumption is about 1uA.
After I call  ble_stack_init with code below, I got about 500uA. It is without advertising at all.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
When beacon is enabled I have cca 650uA.
When GATT and beacon are working I have cca 750uA.
I measure with multimeter.
Results seems fine for me except for those 500uA after stack is initialized. Why is it so high? What can I do to lower it?
  • SDK v 15.0
  • NRF_LOG_ENABLED is 0
  • Using RELEASE configuration.
  • Tried S132 and S140 - result is the same
  • Hi Elias,
    What are the clock configurations you are using? When you enable the softdevice, it will start RTC0 as a house keeping timer. This needs LFCLK.
  • Hi Aryan,
    I use defaults from ble_app_hrs_freertos_pca10040_s132 example.
    // <e> NRFX_RTC_ENABLED - nrfx_rtc - RTC peripheral driver
    #ifndef NRFX_RTC_ENABLED
    #define NRFX_RTC_ENABLED 0
    // <q> NRFX_RTC0_ENABLED  - Enable RTC0 instance
    #ifndef NRFX_RTC0_ENABLED
    #define NRFX_RTC0_ENABLED 0
    // <q> NRFX_RTC1_ENABLED  - Enable RTC1 instance
    #ifndef NRFX_RTC1_ENABLED
    #define NRFX_RTC1_ENABLED 0
    // <q> NRFX_RTC2_ENABLED  - Enable RTC2 instance
    #ifndef NRFX_RTC2_ENABLED
    #define NRFX_RTC2_ENABLED 0
    // <o> NRFX_RTC_MAXIMUM_LATENCY_US - Maximum possible time[us] in highest priority interrupt
    #ifndef NRFX_RTC_MAXIMUM_LATENCY_US
    #define NRFX_RTC_MAXIMUM_LATENCY_US 2000
    // <o> NRFX_RTC_DEFAULT_CONFIG_FREQUENCY - Frequency  <16-32768>
    #ifndef NRFX_RTC_DEFAULT_CONFIG_FREQUENCY
    #define NRFX_RTC_DEFAULT_CONFIG_FREQUENCY 32768
    // <q> NRFX_RTC_DEFAULT_CONFIG_RELIABLE  - Ensures safe compare event triggering
    #ifndef NRFX_RTC_DEFAULT_CONFIG_RELIABLE
    #define NRFX_RTC_DEFAULT_CONFIG_RELIABLE 0
    // <o> NRFX_RTC_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    // <4=> 4
    // <5=> 5
    // <6=> 6
    // <7=> 7
    #ifndef NRFX_RTC_DEFAULT_CONFIG_IRQ_PRIORITY
    #define NRFX_RTC_DEFAULT_CONFIG_IRQ_PRIORITY 7
    // <e> NRFX_RTC_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRFX_RTC_CONFIG_LOG_ENABLED
    #define NRFX_RTC_CONFIG_LOG_ENABLED 0
    // <o> NRFX_RTC_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRFX_RTC_CONFIG_LOG_LEVEL
    #define NRFX_RTC_CONFIG_LOG_LEVEL 3
    // <o> NRFX_RTC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRFX_RTC_CONFIG_INFO_COLOR
    #define NRFX_RTC_CONFIG_INFO_COLOR 0
    // <o> NRFX_RTC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRFX_RTC_CONFIG_DEBUG_COLOR
    #define NRFX_RTC_CONFIG_DEBUG_COLOR 0
    Anything else I can provide?
  • ah., good observation, I did not realize that hrs example with and without freertos are behaving differently at ble_stack_init power consumption wise. I can reproduce this now. I will try to find why this is happening. Will get back to you soon. Until then you can go ahead in your project development and we can come to some workaround for this when i have an answer
  • Thank you very much, Aryan! Looking forward for solution. If I will have some new information regarding issue, I will also let you know.
  • I had similar issue, but after setting NRF_LOG_ENABLED  and NRF_LOG_UART_BACKEND_ENABLED  to 0 in sdk_config.h, my current consumption dropped exactly by 500ua after full recompilation. Maybe this would help someone.
    UPD: I found out that running some TASKS_START with some peripherals causes to significantly increase current consumption of softdevice. It's beyond my understanding, but, as an example, executing this:
    NRF_QDEC ->TASKS_START = 1;
    nrf_delay_ms(1000);
    NRF_QDEC ->TASKS_STOP = 1;
    results in increased power consumption. Also, some other peripherals trigger this behavior, but current increase dosen't stack.
    UPD2: My falut. adding NRF_QDEC -> ENABLE= 1; allows QDEC to stop, but i still cant get QDEC running with less that 500ua
