current consumption differ than spec
I run a basic code on nRF52832 and measure the power consumption of the chip (using DVM). The current consumption is 400 uA which is a lot just for a single timer in my application.
The code initialize only the UART and a single timer, after initializing the system enter idle mode and every second it wakes up and increase a counter.
The card is a basic nRF52832 card and all the external peripherals are disabled.
I'm using nRF5_SDK_14.0.0
the voltage is 3.1V
I've set the timer frequency to 500 kHz and according to the data sheet the power consumption should be less then 9 uA (ITIMER_1M Run current with 1 MHz clock input (PCLK1M) 3 5 8 μA)
All power measurement made without JLink connection
The problem happens when I executing nrf_drv_timer_enable():
When  [//1.    DEBUG_StopSystem();] is enabled the code freeze and the measured current is 23uA
When  [//1.    DEBUG_StopSystem();] is disabled and [//2.    DEBUG_StopSystem();] is enabled the code freeze and the measured current is 398uA
uint8_t HandleLowPowerTimer(uint8_t Mode)
uint32_t time_ms = 1000; //Time(in miliseconds) between consecutive compare events.
uint32_t time_ticks;
uint32_t err_code = NRF_SUCCESS;
  if (Mode)
    //Configure TIMER_LED for generating a tick every second
    timer_cfg.frequency = 5; //Set to 500 kHz
    err_code = nrf_drv_timer_init(&LOW_POWER_TIMER, &timer_cfg, timer_event_handler);
    if (NRF_SUCCESS == err_code)
      time_ticks = nrf_drv_timer_ms_to_ticks(&LOW_POWER_TIMER, time_ms);
      nrf_drv_timer_extended_compare(
      &LOW_POWER_TIMER, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
      nrf_drv_timer_enable(&LOW_POWER_TIMER);
// 2.   DEBUG_StopSystem();
  return(err_code);
void DEBUG_StopSystem(void)
  InitGpio(1);  //disable all pins and shut down UART
  NRF_UART0->ENABLE = UART_ENABLE_ENABLE_Disabled;
  NRF_UART0->TASKS_STOPRX = 1;
  NRF_UART0->TASKS_STOPTX = 1;
  while (1)
    __WFI();
Please advice
Haim
