BLE 4.2 Support in the BLE Mesh SDK
We want that any bulb or any devices (Server device) of BLE 4.2 should be able to work with BLE Mesh SDK(Client). We are using the nrf52832 with SDK  BLE_2.0.1 for the mesh. My questions are as per below,
1)Is it possible to operate any BLE 4.2  device with this SDK?
2)Any Extra things required to work with BLE 4.2 like Proxy client or server?
3)If it is possible then Please provide us example code or document then to implement BLE 4.2 with SDK  BLE_2.0.1.
4) Is it possible to enable both the things BLE 5.0 mesh and BLE 4.2 in this same SDK?
  • 1) You need to use a proxy node to communicate between Mesh & regular BLE.
    2) Do you mean communicate between the mesh sdk & regular sdk for example?
    3) Take a look at the nrf mesh app for iOS. You will be able to provision a mesh network using your smartphone. Also take a look at the mesh sdk examples, like the light switch demo. We also have a proxy client & proxy server example inside the light switch demo.
    4) Bluetooth Mesh is not based on Bluetooth 5. My guess is you want something like this?
  • Thanks, Bjørn Kvaale for the quick reply,
    2) You understand correctly that I want to communicate mesh SDK & regular SDK. For example, mesh SDK of the server is NRF SDK and regular SDK does not belong to NRF SDK then is it possible to communicate with each other? For example, one side I have Nordic SDK and another side I have regular BLE 4.2 another company SDK like TI, Silicon Lab or any Other then it will work or not with Nordic SDK?
    4)Yes, I want to work simultaneously on BLE 5.0 mesh and BLE 4.2 then it is possible? If yes then how we can do that? We have to integrate proxy and mesh example code?
    Apart from it, I have another question regarding DFU bootloader, I want to do changes for firmware upgrade and it is as per below,
    I need DFU UART for our application but unfortunately, it is not available in current BLE mesh SDK so we have decided to implement our own UART DFU support so my query is as per below,
    5)Is it possible to implement DFU UART in this SDK? I want to upgrade hex file over the UART from the host controller for NRF52.
    6)Is there any document for DFU? It would be great if you can give us any documents for DFU UART also and bootloader related things where we should be able to start development of DFU UART.
  • 2) It might work to use Nordic SDK on one side & then use another sdk from another company, but I cannot fully guarantee this will work. I would recommend using Nordic SDK on both sides.
    3) Bluetooth mesh does not use Bluetooth 5.0. Take a look at the proxy example if you want to combine Bluetooth Mesh & BLE.
    5) not sure how easy it is to implement your own dfu. This link might be helpful.
    6) Take a look at the Nordic Infocenter for more info related to dfu (e.g. this link or this link).
  • Thanks,  for your quick reply and support.Appreciated it
