Default contents in flash of nrf52840
Hi all,
What are the default preflashed contents in the out of box nrf52840 flash?
I assume that bootloader is not present. If my assumption is correct how preflashed blinky application is executed?
Please answer. Thanks a lot.
Sridhar
Parents Reply
  • All Cortex-M series maps as follow
    Addr 0: contains the address of the top of the stack. SP will be loaded with this value on reset
    Addr 4: contains the address of the reset function. PC will be loaded with this value on reset, then reset function will be executed.
    Starting at address 8 is the interrupt vector.  See this startup vector table source code and the reset function
    When using softdevice.  softdevice will be the main application and your firmware is a kind of plugin so after softdevice is initialized, it will jump to your app.  Which means your firmware must be located at a certain location depending on the version of softdevice used.
    If softdevice is not used, your firmware is the main app.
    I hope this clears up the confusion
