Help with Thingy Program Development
I'm looking for someone to hire to make a Thingy program for me.
I'd like to program the Thingy so it picks up ANT+ MO2 data or other ANT+ data from multiple sensors and then sends it out over a serial port so I can read it into Matlab easily.
I'm thinking we could set it up with 8 channels. We could send a serial command to the Thingy to setup each channel with the sensor type and sensor number. Something like:
Setup(Ch1, MO2, 123)
Setup(Ch2, HR, 456)
Then we could send the Thingy a start command.
Then every second, the Thingy would send out a string over the serial port with all 8 channels of data.
I have a lot of researchers using our Moxy Monitors looking for something like this.
Please message me if you'd be interested in doing a project like this.
  • Hi Roger,
    We are working on expanding Devzone so that it will be possible to ask for freelancing help in the future. I will let you know when this site is up & running, as devzone is used if you are a developer & want some tips about a problem you are having.
    Kind Regards,
    Bjørn
