This is somewhat of a continuation of this topic:
What does APP_BLE_CONN_CFG_TAG do?
Softdevice 132, header: ble.h:
SVCALL(SD_BLE_CFG_SET, uint32_t, sd_ble_cfg_set(uint32_t cfg_id, ble_cfg_t const * p_cfg, uint32_t app_ram_base));
1. I do not like the fact that the ability to set the GATT Service changed characteristic 0x2A05 is combined with setting the app_ram_base address.
I will merely register my complaint here: Poor separation of functionality. This is fundamentally a characteristic of 2 x 16 bits and an associated descriptor being associated with the entire softdevice start up declaration of RAM address. The call this function I have to go ask my start up code "how much memory did you allocate to the softdevice again?".
Can you imagine doing that when any other service/characteristic were being set?
2. There is this cfg_id parameter which seems suspiciously similar to the advertising parameter conn_cfg_tag.
SVCALL(SD_BLE_GAP_ADV_START, uint32_t, sd_ble_gap_adv_start(ble_gap_adv_params_t const *p_adv_params, uint8_t conn_cfg_tag));
Are they associated, these 2 tags?
If so, there some documentation that describes how these to items are tied together.
Apparently there is linkage, if not between the advertising tag but other tags based on the comments:
see @ref BLE_CONN_CFGS, @ref BLE_COMMON_CFGS, @ref BLE_GAP_CFGS or @ref BLE_GATTS_CFGS
That is a lot of linkage. Is there a document describing what is intended here?
OK, I just noticed this comment in the advertising function header (ble_gap.h):
conn_cfg_tag Tag identifying a configuration set by @ref sd_ble_cfg_set
Would someone please document these contextual tags, how they are intended to be used and the effects of their usage?
An application note would be helpful.
Thank you.
