possible I2S example bug SDk15
I'm looking at the SDK15 I2S example project using DMA. My dev set up is 52840/Keil.
The project is under: \nRF5_SDK_15.0.0_a53641a\examples\peripheral\i2s
In the callback function which is called when DMA completes and the new buffer needs to be set, the data structure being set to i2s driver (nrf_drv_i2s_next_buffers_set) is not updated to use the alternating buffer but the same one. Lookes like DMA will keep using the same memory buffer every time. Is that a bug?
static void data_handler(nrf_drv_i2s_buffers_t const * p_released,
                         uint32_t                      status)
    // 'nrf_drv_i2s_next_buffers_set' is called directly from the handler
    // each time next buffers are requested, so data corruption is not
    // expected.
    ASSERT(p_released);
    // When the handler is called after the transfer has been stopped
    // (no next buffers are needed, only the used buffers are to be
    // released), there is nothing to do.
    if (!(status & NRFX_I2S_STATUS_NEXT_BUFFERS_NEEDED))
        return;
    // First call of this handler occurs right after the transfer is started.
    // No data has been transferred yet at this point, so there is nothing to
    // check. Only the buffers for the next part of the transfer should be
    // provided.
    if (!p_released->p_rx_buffer)
        nrf_drv_i2s_buffers_t const next_buffers = {
            .p_rx_buffer = m_buffer_rx[1],
            .p_tx_buffer = m_buffer_tx[1],
        APP_ERROR_CHECK(nrf_drv_i2s_next_buffers_set(&next_buffers));
        mp_block_to_fill = m_buffer_tx[1];
        mp_block_to_check = p_released->p_rx_buffer;
        // The driver has just finished accessing the buffers pointed by
        // 'p_released'. They can be used for the next part of the transfer
        // that will be scheduled now.
        APP_ERROR_CHECK(nrf_drv_i2s_next_buffers_set(p_released));
        // The pointer needs to be typecasted here, so that it is possible to
        // modify the content it is pointing to (it is marked in the structure
        // as pointing to constant data because the driver is not supposed to
        // modify the provided data).
        mp_block_to_fill = (uint32_t *)p_released->p_tx_buffer;
