initialize();
execution_start(start);
for (;;)
(void)sd_app_evt_wait();
can you explain me the execution of code flow in the main with these APIs?
initialize();
for (;;)
I forgot to mention, i am using ble mesh for my project. And am using nrf5 SDK v 2.0.1. According to my research, the server example in light switch demo does work as a relay. So, would i just flash the as it is example code to my nrf52832 kit and put them in between to relay my data?? And the application timer library tutorial wont work with this new SDK version? Can you provide me with updated tutorials or any documentation? Thank you
I see, yes in mesh the nodes will work as relays. The timer library should work with with Mesh SDK, but it is not included. Please have a look at the getting started guide for details on integration with nRF5x SDK 15.0.0. I did link you to the documentation for SDK 15.0.0 application timer library. Please make sure you follow the section "Migration note", otherwise the library should work as described in the tutorial.
okay, i should do a further research on this. Also, yesterday Bjorn, left me unattended. I was having trouble in building the example project using my SES environment. i am getting the following error.
I have mentioned the path to my board files.
Ca you help me with this? Thank you
Unfortunately, we do not get notified by new replies if you have marked the case as "Verified Answer", please create a new case when you have more issues.
Your include paths are not correct, It looks like you have copied this from a GCC makefile. You should remove '$(SDK_ROOT:' part of the path. Did you place SDK 15 directory inside root of Mesh SDK folder?
Okay, that might be the case then. i have the SDK 15 directory inside the same folder as of Mesh , shown in picture below:
is this not a correct place for the folder?
