initialize();
execution_start(start);
for (;;)
(void)sd_app_evt_wait();
can you explain me the execution of code flow in the main with these APIs?
initialize();
for (;;)
Your code will do some initialization, then start execution of something, then enters a endless loop. sd_app_evt_wait will put the device into system on sleep mode. If you have initialized and started something that generates interrupts, your code will wake and handle events whenever they occur.
Thank you jorgen, so in the light switch example, is pressing a button on the kit producing an interrupt that wakes up my processor? If that is correct, then what do i do to continuously send the sensor data at a fixed interval and do not trigger it with any interrupt, like pressing a button.
Yes, that is correct.
I'm not sure I understand your question. What sensor data are you sending, and how/where are you sending it? If you want to send data at a fixed interval, you need to setup a timer that sample the sensor and send the data. The timer will generate interrupts. If you don't want to use interrupts, you need to constancly pull the sensor data, and stall the CPU to generate delays. This is bad practise, and is not something I would recommend. If you want something to happen on a button press, you either need interrupts or you need to constantly check the state of the button/GPIO.
I am using a simple DHT11 temp and humidity sensor data and want the node to send this data after every 30 seconds to a far placed node which could then send the data to my mobile application. So, the best way would be to setup a timer that generates an interrupt after every 30 seconds and then place a few relay nodes in between my sensor node and the final destination node. is that correct? If this sounds right to you, can you please refer me to some good links to follow, in order to generate timer based interrupts and also how to relay the data through the in between placed nodes? Thank you
Yes, using a timer sounds like the best approach. I'm assuming your are talking about sending the data wirelessly? With BLE or some proprietary protocol?
For such long delays, I would recommend that you use the application timer library for creating timers. This use the RTC peripheral, which is lower power than TIMER peripherals. There is a tutorial available, but note that this is written for an old SDK version.
For relaying data using BLE, this example could be usefull. You can also use proprietary protocols like ANT, or higher level protocols like Bluetooth Mesh. It is hard to say what is the best solution for your application, this is something you need to figure out yourself.
