I work on a ANT proximity search project using SDK12.2.0 and softdevice S332v2.0.1 on nRF52832.
I have a ANT sensor which is 5cm apart from the Nordic 52832. And the search timeout and low priority search timeout are set as follow.
ret = sd_ant_channel_rx_search_timeout_set( channel, 2);
ret = sd_ant_channel_low_priority_rx_search_timeout_set( channel, 10);
A success return code can be received after executing both of the above settings.
Then start the ANT proximity search,
case 1) When executing "ret = sd_ant_prox_search_set( channel, 4, 0);", the return code of "ret" is 0( success) and nRF52832 can not search the ANT sensor
case 2) After 10s, executing "ret = sd_ant_prox_search_set( channel, 7, 0);", the return code of "ret" is 0( success) and nRF52832 still can not search the ANT sensor
case 3) then after 10s, executing "ret = sd_ant_prox_search_set( channel, 0, 0);", the return code of "ret" is 0( success) and nRF52832 can search the ANT sensor
Can you share an idea why the ANT sensor can not be received in case 1 and case 2?
Thanks
dtt
