QSPI and w25q64fv flash
Hi all. I try to configure QSPI example to work with w25q64fv flash. I connected all pins from flash to same pins on nRF as on PCA10056 DK board. After all i have "Data inconsistent" message.  I looked in to data array from flash and in it every element was equal to 0x88. I have a couple questions about how to configure driver to work with my flash and how to configure nrfx_qspi_cinstr_xfer function configuration structure.
static void configure_memory()
    uint8_t temporary[2] = {0x00, 0x02};
		uint8_t rx_buf[3];
    uint32_t err_code;
    nrf_qspi_cinstr_conf_t cinstr_cfg = {
        .opcode    = QSPI_STD_CMD_RSTEN,
        .length    = NRF_QSPI_CINSTR_LEN_1B,
        .io2_level = true,
        .io3_level = true,
        .wipwait   = true,
        .wren      = true
    // Send reset enable
    err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL, NULL);
    // Send reset command
    cinstr_cfg.opcode = QSPI_STD_CMD_RST;
		cinstr_cfg.opcode =	QSPI_STD_CMD_JID;
		cinstr_cfg.length = NRF_QSPI_CINSTR_LEN_4B;
		err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL, rx_buf);
		SEGGER_RTT_printf(0, "ID = %x%x%x\r\n", rx_buf[0], rx_buf[1], rx_buf[2]);
//    // Switch to qspi mode
    cinstr_cfg.opcode = QSPI_STD_CMD_WRSR;
    cinstr_cfg.length = NRF_QSPI_CINSTR_LEN_3B;
    err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, temporary, NULL);
If i connect logic analyzer to IO0 pin i always get NRFX_ERROR_TIMEOUT err code.
