What is the error of "nRF51 SDK Wizard ended prematurely"
Hi, This error happend when I tried to install nRF51 SDK(nrf51_sdk_v4_3_0_27417.msi). The step is that. First of all I installed keil-MDK4.72 and than I installed JlinkARM4.74, after than I'm to going to install nRF51SDK, than there the prompt of "nRF51 SDK Wizard ended prematurely" is showed on screen. I trid several times, the result is the same. What is wrong with it? Who can tell me ? thank ....
  • Which Windows version do you run? If you have anything else than Windows 7, you may have to install .NET framework version 3.5 manually, available here.
    If this does not solve it, could you please run the installer with logging enabled, and upload the log here? Logging is enabled as follows:
    nrf51-sdk-version-number.msi /log logfile.txt
  • thank ole Morten You are right, My windows system has no .NET framework 3.5. Now It works after .NET framework 3.5 being installed.
  • After installing .NET 3.5 the same error. Log file
    === Logging started: 01/10/2013 10:53:34 === Action 10:53:34: INSTALL. Action start 10:53:34: INSTALL. Action 10:53:34: FindRelatedProducts. Searching for related applications Action start 10:53:34: FindRelatedProducts. Action ended 10:53:34: FindRelatedProducts. Return value 1. Action 10:53:34: PrepareDlg. Action start 10:53:34: PrepareDlg. Info 2898. For WixUI_Font_Normal textstyle, the system created a 'Tahoma' font, in 0 character set, of 13 pixels height. Info 2898. For WixUI_Font_Bigger textstyle, the system created a 'Tahoma' font, in 0 character set, of 19 pixels height. Action 10:53:34: PrepareDlg. Dialog created Action ended 10:53:34: PrepareDlg. Return value 1. Action 10:53:34: AppSearch. Searching for installed applications Action start 10:53:34: AppSearch. AppSearch: Property: KEILTOOLDIRHKCU, Signature: KeilRegistryCU AppSearch: Property: KEILTOOLDIR, Signature: KeilRegistryLM AppSearch: Property: OLDVERSION, Signature: OldVersionRegistry AppSearch: Property: NRF51422OLDCUSTOMINSTALLPATH, Signature: NRF51422OldCustomInstallPathRegistry AppSearch: Property: NRF51822OLDCUSTOMINSTALLPATH, Signature: NRF51822OldCustomInstallPathRegistry Action ended 10:53:34: AppSearch. Return value 1. Action 10:53:34: Setnrf51422_CustomDeviceFolder. Action start 10:53:34: Setnrf51422_CustomDeviceFolder. Action ended 10:53:34: Setnrf51422_CustomDeviceFolder. Return value 1. Action 10:53:34: Setnrf51422_CustomExamplesFolder. Action start 10:53:34: Setnrf51422_CustomExamplesFolder. Action ended 10:53:34: Setnrf51422_CustomExamplesFolder. Return value 1. Action 10:53:34: Setnrf51422_KeilDeviceFolder. Action start 10:53:34: Setnrf51422_KeilDeviceFolder. Action ended 10:53:34: Setnrf51422_KeilDeviceFolder. Return value 1. Action 10:53:34: Setnrf51422_KeilDeviceFolderWithBackslash. Action start 10:53:34: Setnrf51422_KeilDeviceFolderWithBackslash. Action ended 10:53:34: Setnrf51422_KeilDeviceFolderWithBackslash. Return value 1. Action 10:53:34: Setnrf51422_KeilExamplesFolder. Action start 10:53:34: Setnrf51422_KeilExamplesFolder. Action ended 10:53:34: Setnrf51422_KeilExamplesFolder. Return value 1. Action 10:53:34: Setnrf51822_CustomDeviceFolder. Action start 10:53:34: Setnrf51822_CustomDeviceFolder. Action ended 10:53:34: Setnrf51822_CustomDeviceFolder. Return value 1. Action 10:53:34: Setnrf51822_CustomExamplesFolder. Action start 10:53:34: Setnrf51822_CustomExamplesFolder. Action ended 10:53:34: Setnrf51822_CustomExamplesFolder. Return value 1. Action 10:53:34: Setnrf51822_KeilDeviceFolder. Action start 10:53:34: Setnrf51822_KeilDeviceFolder. Action ended 10:53:34: Setnrf51822_KeilDeviceFolder. Return value 1. Action 10:53:34: Setnrf51822_KeilDeviceFolderWithBackslash. Action start 10:53:34: Setnrf51822_KeilDeviceFolderWithBackslash. Action ended 10:53:34: Setnrf51822_KeilDeviceFolderWithBackslash. Return value 1. Action 10:53:34: Setnrf51822_KeilExamplesFolder. Action start 10:53:34: Setnrf51822_KeilExamplesFolder. Action ended 10:53:34: Setnrf51822_KeilExamplesFolder. Return value 1. Action 10:53:34: ValidateProductID. Action start 10:53:34: ValidateProductID. Action ended 10:53:34: ValidateProductID. Return value 1. Action 10:53:34: CostInitialize. Computing space requirements Action start 10:53:34: CostInitialize. Action ended 10:53:34: CostInitialize. Return value 1. Action 10:53:34: FileCost. Computing space requirements Action start 10:53:34: FileCost. Action ended 10:53:34: FileCost. Return value 1. Action 10:53:34: CostFinalize. Computing space requirements Action start 10:53:34: CostFinalize. Action ended 10:53:34: CostFinalize. Return value 1. Action 10:53:34: MigrateFeatureStates. Migrating feature states from related applications Action start 10:53:34: MigrateFeatureStates. Action ended 10:53:34: MigrateFeatureStates. Return value 0. Action 10:53:34: WelcomeDlg. Action start 10:53:34: WelcomeDlg. Action 10:53:34: WelcomeDlg. Dialog created Info 2898. For WixUI_Font_Title textstyle, the system created a 'Tahoma' font, in 0 character set, of 14 pixels height. Action 10:53:35: LicenseAgreementDlg. Dialog created Action 10:53:37: CustomizeDlg. Dialog created Action 10:53:39: VerifyReadyDlg. Dialog created Action ended 10:53:40: WelcomeDlg. Return value 1. Action 10:53:40: ProgressDlg. Action start 10:53:40: ProgressDlg. Action 10:53:40: ProgressDlg. Dialog created Action ended 10:53:40: ProgressDlg. Return value 1. Action 10:53:40: ExecuteAction. Action start 10:53:40: ExecuteAction. Action 10:53:41: INSTALL. Action start 10:53:41: INSTALL. Action 10:53:41: FindRelatedProducts. Searching for related applications Action start 10:53:41: FindRelatedProducts. Action ended 10:53:41: FindRelatedProducts. Return value 0. Action 10:53:41: AppSearch. Searching for installed applications Action start 10:53:41: AppSearch. Action ended 10:53:41: AppSearch. Return value 0. Action 10:53:41: GetDirectory. Action start 10:53:41: GetDirectory. SFXCA: Extracting custom action to temporary directory: C:\WINDOWS\Installer\MSI6817.tmp-
    SFXCA: Binding to CLR version v2.0.50727 Calling custom action CustomAction!CustomAction.CustomActions.FindKeilRoot Begin search for Registry Key "SOFTWARE\Keil\Products\MDK". Searching in HKLM... Registry Key not found in HKLM. Searching in HKCU... Registry Key not found in HKCU. Keil Registry Key not found, using default installation location (C:\Keil\ARM). KeilRoot Directory not found. Returning error. Action ended 10:53:41: GetDirectory. Return value 3. Action ended 10:53:41: INSTALL. Return value 3. Property(S): UpgradeCode = {44E6DFA7-38DC-4E3F-AA78-00264D6ED66E} Property(S): KEILTOOLDIR = C:
    Property(S): TARGETDIR = C:
    Property(S): KEILROOTDIR = C:
    Property(S): WixUIRMOption = UseRM Property(S): ROOTDRIVE = C:
    Property(S): WindowsFolder = C:\WINDOWS
    Property(S): ProgramFilesFolder = C:\Archivos de programa
    Property(S): ProgramMenuFolder = C:\Documents and Settings\Jordi\Menú Inicio\Programas
    Property(S): CONFIGURABLE_CUSTOM_SOFTWAREARCHIVE_DIR = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827
    Property(S): DIR.NORDIC = C:\Nordic Semiconductor
    Property(S): WINDOWSVOLUME = C:
    Property(S): Manufacturer = Nordic Semiconductor Property(S): ProductCode = {6911FA46-635F-4F43-982E-541B30238E41} Property(S): ProductLanguage = 1033 Property(S): ProductName = nRF51 SDK Property(S): ProductVersion = 4.4.1.31827 Property(S): ARPPRODUCTICON = Nordic_N_Hi.ico Property(S): DefaultUIFont = WixUI_Font_Normal Property(S): WixUI_Mode = FeatureTree Property(S): ErrorDialog = ErrorDlg Property(S): SecureCustomProperties = WIX_UPGRADE_DETECTED Property(S): MsiLogFileLocation = C:\Nordic\logfile.txt Property(S): PackageCode = {DB49B65C-56CA-4918-BCA1-DE18B4A323F8} Property(S): ProductState = -1 Property(S): PackagecodeChanging = 1 Property(S): CURRENTDIRECTORY = C:\Nordic Property(S): CLIENTUILEVEL = 0 Property(S): CLIENTPROCESSID = 9508 Property(S): USERNAME = Jordi Property(S): COMPANYNAME = Solid Property(S): VersionDatabase = 300 Property(S): ACTION = INSTALL Property(S): EXECUTEACTION = INSTALL Property(S): SECONDSEQUENCE = 1 Property(S): INSTALLLEVEL = 1 Property(S): ADDLOCAL = Feature.nrf51422.SoftwareArchive,Feature.nrf51822.SoftwareArchive,Feature.Keil.DeviceSupport,Feature.Interactive,Feature.SoftwareArchive,Feature.CommonShortcutsCustom,Feature.Tools,Feature.KeilIDE.Support,Feature.WriteCommonRegistryKeys,Feature.JlinkCDCLauncher Property(S): MsiSystemRebootPending = 1 Property(S): VersionMsi = 4.05 Property(S): VersionNT = 501 Property(S): WindowsBuild = 2600 Property(S): ServicePackLevel = 3 Property(S): ServicePackLevelMinor = 0 Property(S): MsiNTProductType = 1 Property(S): WindowsVolume = C:
    Property(S): SystemFolder = C:\WINDOWS\system32
    Property(S): System16Folder = C:\WINDOWS\system
    Property(S): RemoteAdminTS = 1 Property(S): TempFolder = C:\DOCUME~1\Jordi\CONFIG~1\Temp
    Property(S): CommonFilesFolder = C:\Archivos de programa\Archivos comunes
    Property(S): AppDataFolder = C:\Documents and Settings\Jordi\Datos de programa
    Property(S): FavoritesFolder = C:\Documents and Settings\Jordi\Favoritos
    Property(S): NetHoodFolder = C:\Documents and Settings\Jordi\Entorno de red
    Property(S): PersonalFolder = C:\Documents and Settings\Jordi\Mis documentos
    Property(S): PrintHoodFolder = C:\Documents and Settings\Jordi\Impresoras
    Property(S): RecentFolder = C:\Documents and Settings\Jordi\Reciente
    Property(S): SendToFolder = C:\Documents and Settings\Jordi\SendTo
    Property(S): TemplateFolder = C:\Documents and Settings\Jordi\Plantillas
    Property(S): CommonAppDataFolder = C:\Documents and Settings\All Users\Datos de programa
    Property(S): LocalAppDataFolder = C:\Documents and Settings\Jordi\Configuración local\Datos de programa
    Property(S): MyPicturesFolder = C:\Documents and Settings\Jordi\Mis documentos\Mis imágenes
    Property(S): AdminToolsFolder = C:\Documents and Settings\Jordi\Menú Inicio\Programas\Herramientas administrativas
    Property(S): StartupFolder = C:\Documents and Settings\Jordi\Menú Inicio\Programas\Inicio
    Property(S): StartMenuFolder = C:\Documents and Settings\Jordi\Menú Inicio
    Property(S): DesktopFolder = C:\Documents and Settings\Jordi\Escritorio
    Property(S): FontsFolder = C:\WINDOWS\Fonts
    Property(S): GPTSupport = 1 Property(S): OLEAdvtSupport = 1 Property(S): ShellAdvtSupport = 1 Property(S): Intel = 16 Property(S): PhysicalMemory = 3327 Property(S): VirtualMemory = 2390 Property(S): AdminUser = 1 Property(S): LogonUser = Jordi Property(S): UserSID = S-1-5-21-1957994488-562591055-725345543-1003 Property(S): UserLanguageID = 3082 Property(S): ComputerName = SOLID-01 Property(S): SystemLanguageID = 3082 Property(S): ScreenX = 1680 Property(S): ScreenY = 1050 Property(S): CaptionHeight = 26 Property(S): BorderTop = 1 Property(S): BorderSide = 1 Property(S): TextHeight = 16 Property(S): TextInternalLeading = 3 Property(S): ColorBits = 32 Property(S): TTCSupport = 1 Property(S): Time = 10:53:41 Property(S): Date = 01/10/2013 Property(S): MsiNetAssemblySupport = 4.0.30319.1 Property(S): MsiWin32AssemblySupport = 5.1.2600.5512 Property(S): RedirectedDllSupport = 2 Property(S): Privileged = 1 Property(S): DATABASE = C:\WINDOWS\Installer\623518fe.msi Property(S): OriginalDatabase = C:\Nordic\nrf51_sdk_v4_4_1_31827.msi Property(S): UILevel = 5 Property(S): Preselected = 1 Action ended 10:53:41: ExecuteAction. Return value 3. Action 10:53:41: FatalError. Action start 10:53:41: FatalError. Action 10:53:41: FatalError. Dialog created Action ended 10:53:43: FatalError. Return value 2. Action ended 10:53:43: INSTALL. Return value 3. Property(C): UpgradeCode = {44E6DFA7-38DC-4E3F-AA78-00264D6ED66E} Property(C): KEILTOOLDIR = C:
    Property(C): LicenseAccepted = 1 Property(C): TARGETDIR = C:
    Property(C): DIR.ProductMenuDir = C:\Documents and Settings\Jordi\Menú Inicio\Programas\Nordic Semiconductor\nRF51 SDK
    Property(C): Dir.ProgramFiles.nrf51.bin = C:\Archivos de programa\Nordic Semiconductor\nrf51\bin
    Property(C): dirB132E7D7FA32EE0C75EFEE78040D46DD = C:\Device\Nordic\Documentation
    Property(C): dirF49F5487F542A8C5635137327F64D8C5 = C:\Device\Nordic\Documentation\html
    Property(C): dirB35AA9CE325FDD18F10D735218046D3A = C:\Device\Nordic\Documentation\html\search
    Property(C): dir7447585906C596EA8AE2CB5D20CB195E = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_comb_spd_cad\sensor
    Property(C): dir9DC3EC86795CE5235F49886B8CE924BF = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_comb_spd_cad\sensor\arm
    Property(C): dirDE3DB7C6D08EDE9B95C205BDED37FC18 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_comb_spd_cad\sensor\include
    Property(C): dir9595BBD53132FA467680D267A0FEB572 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_pwr\bicycle_power_minium_receiver
    Property(C): dirB751240AEABC48BD2B3EB046B7DCA886 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_pwr\bicycle_power_minium_receiver\arm
    Property(C): dirE08E06ABFEC146348F6195040721AC63 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_pwr\bicycle_power_minium_receiver\include
    Property(C): dirF196143E918114F3BF841D669FE2A37C = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_pwr\bicycle_power_only_sensor
    Property(C): dir1CB05D9F4482A29A3075E964A2F7050F = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_pwr\bicycle_power_only_sensor\arm
    Property(C): dir348655FAAFFFB90221FF3ABD99E09161 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_pwr\bicycle_power_only_sensor\include
    Property(C): dir2F1DD2B63F88B7B520326BE40159FE63 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_broadcast\broadcast_rx
    Property(C): dir859FB50BA691760E744682ACBDE5E98F = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_broadcast\broadcast_rx\arm
    Property(C): dirD8B3638605D862E72B5CF28FEBA5B0DC = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_broadcast\broadcast_tx
    Property(C): dir850FFEED901C3577EC4724270446EDDF = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_broadcast\broadcast_tx\arm
    Property(C): dir8595E8D6B8F28C2B8A044A33A1C0DEEF = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_fs\client
    Property(C): dir13E0366168FE0162DFA43CEEDAB4A4AB = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_fs\client\arm
    Property(C): dir611CF033092D4F207D624AC4A6A9DF87 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_fs\client\include
    Property(C): dir0A28235E00CF8AA4A6C905EF10561EBF = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_rx
    Property(C): dir2F6F154BE68C1FC1C5A7AC55FB88DA1C = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_rx\arm
    Property(C): dirE3EAB49334DA7BD4C519CD992E26E19F = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_rx\include
    Property(C): dirD10192463BEDC0FCE09097B372BA15DC = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_tx
    Property(C): dirE5BBD0B30B052713B0C25E4FEC2F855B = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_tx\arm
    Property(C): dirF9AD032DC85321CE7E556A104B890854 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_tx\include
    Property(C): dirF15CB939F86961E50D3D9BF185028264 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_tx_buttons
    Property(C): dirEA934410BB60EC83FAB5B6943B07A3AE = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_tx_buttons\arm
    Property(C): dirA5789FBFE819BB15E380AB30CCA4856D = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_tx_buttons\include
    Property(C): dirA31A0D782507A94D008654B0E67BF860 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_sdm\sdm_rx
    Property(C): dir98247098417DE50929B391E5292BADE8 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_sdm\sdm_rx\arm
    Property(C): dir48B5E66074C8A779CCBB1CD0FA152AD0 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_sdm\sdm_rx\include
    Property(C): dir60FDBF1C3FACD84119ADD972EB202626 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_sdm\sdm_tx
    Property(C): dirFC0464277B9CA8555BB5FE470DA9D922 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_sdm\sdm_tx\arm
    Property(C): dir3AF98B6EEE7A2F2F736A5412B1F0C15D = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_sdm\sdm_tx\include
    Property(C): dir5BA07241EC4CDC2E77877E4A6207DD6F = C:\Device\Nordic\nrf51422\Board\nrf6310\blinky_example
    Property(C): dir4CD6125638CA4F458F85E59E269A806C = C:\Device\Nordic\nrf51422\Board\nrf6310\blinky_example\arm
    Property(C): dirFAC4FD83D93EB0188707C0E1CB0E076A = C:\Device\Nordic\nrf51422\Board\nrf6310\debouncer_example
    Property(C): dir06678A49392ED02C622195DEA62AFCCB = C:\Device\Nordic\nrf51422\Board\nrf6310\debouncer_example\arm
    Property(C): dir7BED8F6587B473C56A65D3989621D955 = C:\Device\Nordic\nrf51422\Board\nrf6310\ext_sensors\adns2080_example
    Property(C): dir9532DF589419E31647A8AE6B24C97E34 = C:\Device\Nordic\nrf51422\Board\nrf6310\ext_sensors\adns2080_example\arm
    Property(C): dir3518CBA329809A0ED0007BF763C594F8 = C:\Device\Nordic\nrf51422\Board\nrf6310\ext_sensors\cherry8x16_example
    Property(C): dir66FE84BEFE50FD401E5C0DA06E0828F9 = C:\Device\Nordic\nrf51422\Board\nrf6310\ext_sensors\cherry8x16_example\arm
    Property(C): dir4E424C465C17ADE01F0C7DBDE5883EEE = C:\Device\Nordic\nrf51422\Board\nrf6310\flashwrite_example
    Property(C): dir27FEA27D4691676901DD638D6680A12B = C:\Device\Nordic\nrf51422\Board\nrf6310\flashwrite_example\arm
    Property(C): dirA2E0F4C5010629022178086B2557A33D = C:\Device\Nordic\nrf51422\Board\nrf6310\gpiote_example
    Property(C): dirFD3F3AC86010A68725C7D4805711D407 = C:\Device\Nordic\nrf51422\Board\nrf6310\gpiote_example\arm
    Property(C): dir7E9025F7540882E1C6416CCC9D1299C8 = C:\Device\Nordic\nrf51422\Board\nrf6310\nRF6350_radio_configuration_example
    Property(C): dir8E97AE572C58898E5F98A9ED12CED178 = C:\Device\Nordic\nrf51422\Board\nrf6310\nRF6350_radio_configuration_example\arm
    Property(C): dir1EF5AFC2FCFAE529186E1A4D7D21C8A6 = C:\Device\Nordic\nrf51422\Board\nrf6310\pin_change_int_example
    Property(C): dirDD7E74D5A959A7A48255D353AD53D69F = C:\Device\Nordic\nrf51422\Board\nrf6310\pin_change_int_example\arm
    Property(C): dir3CE80BC4D4D3E8D69362F0EED7D13ECF = C:\Device\Nordic\nrf51422\Board\nrf6310\ppi_example
    Property(C): dir0F034D6CB2B91E0D3AAA98154709522C = C:\Device\Nordic\nrf51422\Board\nrf6310\ppi_example\arm
    Property(C): dir15A6956646AB5CFCA1F3EFE1FD8DA5A6 = C:\Device\Nordic\nrf51422\Board\nrf6310\pwm_analyzer
    Property(C): dir677DA341DF92D50D982C0ABABA60F306 = C:\Device\Nordic\nrf51422\Board\nrf6310\pwm_analyzer\arm
    Property(C): dir0993A2B48038ADB66898A8A678188C7B = C:\Device\Nordic\nrf51422\Board\nrf6310\pwm_example
    Property(C): dirA0888AC47A424B958640BE48C7D70DD1 = C:\Device\Nordic\nrf51422\Board\nrf6310\pwm_example\arm
    Property(C): dirED9B1A5C6138E1ABE3F1C02C8B0CC4C3 = C:\Device\Nordic\nrf51422\Board\nrf6310\radio_example
    Property(C): dir6B2A430AF72DC5B347DB9D1801422F6C = C:\Device\Nordic\nrf51422\Board\nrf6310\radio_example\arm
    Property(C): dir844C267FA0AE06646E2ADBEE81775659 = C:\Device\Nordic\nrf51422\Board\nrf6310\radio_test_example
    Property(C): dir135B0F9BCBA77EE9C65C31B2B535D271 = C:\Device\Nordic\nrf51422\Board\nrf6310\radio_test_example\arm
    Property(C): dirE4FA9FABBD2DF961C786F8AEE9FCD6E0 = C:\Device\Nordic\nrf51422\Board\nrf6310\ram_retention_example
    Property(C): dir723F00F818240A5714E1CC12C70FFBB1 = C:\Device\Nordic\nrf51422\Board\nrf6310\ram_retention_example\arm
    Property(C): dirB93A26BD37AAE869F800AD62FA89EAFF = C:\Device\Nordic\nrf51422\Board\nrf6310\rng_example
    Property(C): dir9E182D9827BB0AF31A65F5C26FDB06A2 = C:\Device\Nordic\nrf51422\Board\nrf6310\rng_example\arm
    Property(C): dir22CFC888191F115FDC5190D1D3D43EA0 = C:\Device\Nordic\nrf51422\Board\nrf6310\rtc_example
    Property(C): dir4BE7EAA6EDD90DBA89576F310FB36E7B = C:\Device\Nordic\nrf51422\Board\nrf6310\rtc_example\arm
    Property(C): dir61A66157E2A21BC938DF97D78D509FAA = C:\Device\Nordic\nrf51422\Board\nrf6310\simple_pwm_motor_control_example
    Property(C): dir8175B09C8F011409C908B50E15F47443 = C:\Device\Nordic\nrf51422\Board\nrf6310\simple_pwm_motor_control_example\arm
    Property(C): dirAE8E62F1740D819A93C463D787CE2BB3 = C:\Device\Nordic\nrf51422\Board\nrf6310\spi_master_example
    Property(C): dir0EBF0FE6B5B2BA3CA91DD62D728496F0 = C:\Device\Nordic\nrf51422\Board\nrf6310\spi_master_example\arm
    Property(C): dirD73553F530C545D5574533A7BD5BE437 = C:\Device\Nordic\nrf51422\Board\nrf6310\temperature_example
    Property(C): dir6D5A801E59D6278D7702038CE9271E4E = C:\Device\Nordic\nrf51422\Board\nrf6310\temperature_example\arm
    Property(C): dir05903FBF324F29852AA1482429E96AD8 = C:\Device\Nordic\nrf51422\Board\nrf6310\template_project
    Property(C): dir95695188213DBE338A7017B2866CFE51 = C:\Device\Nordic\nrf51422\Board\nrf6310\template_project\arm
    Property(C): dirAABB473AD197A265A59880956F9CCC67 = C:\Device\Nordic\nrf51422\Board\nrf6310\timer_example
    Property(C): dirBFE5693DFADDF4E9F91B79F3435F552E = C:\Device\Nordic\nrf51422\Board\nrf6310\timer_example\arm
    Property(C): dir7F8246AC511B99008743E67AD8974D5F = C:\Device\Nordic\nrf51422\Board\nrf6310\twi_sw_master_example
    Property(C): dir6DECCF3CC3919EE050A8E0117E89454F = C:\Device\Nordic\nrf51422\Board\nrf6310\twi_sw_master_example\arm
    Property(C): dir0F797FFE063428D08E581E764FF58B5A = C:\Device\Nordic\nrf51422\Board\nrf6310\uart_example
    Property(C): dirA3B8DE67CD0F4F2E0589EBEB883499F4 = C:\Device\Nordic\nrf51422\Board\nrf6310\uart_example\arm
    Property(C): dir0EB38667AB8CF31F3CB0C639F1FF0F72 = C:\Device\Nordic\nrf51422\Board\nrf6310\uicr_config_example
    Property(C): dir22F6DF3603B9C877CE1AA1F0C7625F75 = C:\Device\Nordic\nrf51422\Board\nrf6310\uicr_config_example\arm
    Property(C): dir817CCB7E42071FB3F46EF1A4FB26375B = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_comb_spd_cad\sensor
    Property(C): dir789C56049B517AAFC1206AC3BDA3056D = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_comb_spd_cad\sensor\arm
    Property(C): dir8872902A74B76F4408EF843FB22B83E8 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_comb_spd_cad\sensor\include
    Property(C): dir4CD83C5C41DB7556445C28BCC1E9A8A6 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_pwr\bicycle_power_minium_receiver
    Property(C): dirDBAAF2721856D0106EFD21CC44CFDBF3 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_pwr\bicycle_power_minium_receiver\arm
    Property(C): dir74355F0FC08D45A6C96BD9C61BF721D7 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_pwr\bicycle_power_minium_receiver\include
    Property(C): dir3A189D56000486113117B7D1376C05FC = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_pwr\bicycle_power_only_sensor
    Property(C): dir7BC30FC5B6DC2D3A9EB27D56FA4FE06C = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_pwr\bicycle_power_only_sensor\arm
    Property(C): dir7A73B270281C56A18B71AAB22B34D05C = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_pwr\bicycle_power_only_sensor\include
    Property(C): dirA8E116E07CEC1919EEDF360F6070739E = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_broadcast\broadcast_rx
    Property(C): dirD39C92103B81E845543896D3EA691BD3 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_broadcast\broadcast_rx\arm
    Property(C): dir2D57F2059F4817550E74CA6E8F45B10D = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_broadcast\broadcast_tx
    Property(C): dirE4ED39EBEB168DABB5CE8E8CA7386EB7 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_broadcast\broadcast_tx\arm
    Property(C): dirB680EBBDA5D246BC57B3F556155363CC = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_fs\client
    Property(C): dir6CBB0FAB0786DAE556384A81FD2497E8 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_fs\client\arm
    Property(C): dir54AC29AA6312AFB620F4EC120BB9FCF9 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_fs\client\include
    Property(C): dirB080620426A5F289AF447110E6645897 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_rx
    Property(C): dir9719F87019D991309063B5324C47F70C = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_rx\arm
    Property(C): dir12642834710B6FC43B9771C6C971A555 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_rx\include
    Property(C): dir1454759F3C200C3634BFDFC80BD552D3 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_tx
    Property(C): dir88529CE01A07B5AA86AA5DCF53E0E957 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_tx\arm
    Property(C): dirC78CD0954E51587657AB7A798DAFADE3 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_tx\include
    Property(C): dir735D454A4BC08E30FAD4418FC76C17BC = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_tx_buttons
    Property(C): dir04C512350C4CCBC40DA296E5EF7EA17A = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_tx_buttons\arm
    Property(C): dir63C23F9CA8284F420C24C32E421CECC1 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_tx_buttons\include
    Property(C): dir3AB32B55F91E9494FB14D9E98B2769EC = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_sdm\sdm_rx
    Property(C): dir17DD8134D43D93080A03789EFCD8D38C = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_sdm\sdm_rx\arm
    Property(C): dir1EAD7234B49639C7F52415B66112EE45 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_sdm\sdm_rx\include
    Property(C): dirBF87BFD60167A0702CD84BE65B1B5B3C = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_sdm\sdm_tx
    Property(C): dirD42A14820238A796156E6AFF0359AD1D = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_sdm\sdm_tx\arm
    Property(C): dirA41E0A1CB99200755F03259D2B726ED1 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_sdm\sdm_tx\include
    Property(C): dir34AACBD7A17781BE16D4E931BB29393F = C:\Device\Nordic\nrf51422\Board\pca10003\blinky_example
    Property(C): dir4B1EE7D89F7721865373E089673441F7 = C:\Device\Nordic\nrf51422\Board\pca10003\blinky_example\arm
    Property(C): dir8957C65E50779463C209FEBDFF261440 = C:\Device\Nordic\nrf51422\Board\pca10003\uart_example
    Property(C): dirF2C9AE29AE4491A98C038457339FA13A = C:\Device\Nordic\nrf51422\Board\pca10003\uart_example\arm
    Property(C): dirEC5AE5A0ABDB03EF409EB277CBF4783F = C:\Device\Nordic\nrf51422\Board\pca10003\uicr_config_example
    Property(C): dir93EF89A0D9853D3615BE91769C19688F = C:\Device\Nordic\nrf51422\Board\pca10003\uicr_config_example\arm
    Property(C): dirC26825AFAFBC594314F38491194C2F70 = C:\Device\Nordic\nrf51422\Include
    Property(C): dirE0A7901E2FBA13844B5DF500E2CC4906 = C:\Device\Nordic\nrf51422\Include\ant\softdevice
    Property(C): dir5F10C295F7FF3F5DC8945B9E24AC0B46 = C:\Device\Nordic\nrf51422\Include\app_common
    Property(C): dir87B2841F1ED86309750FCFFB13EC00C7 = C:\Device\Nordic\nrf51422\Include\boards
    Property(C): dir129ADE04502D4C0A69CC4D085F07D496 = C:\Device\Nordic\nrf51422\Include\ext_sensors
    Property(C): dirCD657AF353B6A667791A1E1431493AB7 = C:\Device\Nordic\nrf51422\Source
    Property(C): dir70FE927BA38CBFF5089FAE028925A86A = C:\Device\Nordic\nrf51422\Source\app_common
    Property(C): dir7B9A1744E657A91C37B5110BAEBACEC3 = C:\Device\Nordic\nrf51422\Source\console
    Property(C): dir90D57A08FF7D665C14B50F42C7D45F10 = C:\Device\Nordic\nrf51422\Source\ext_sensors\adns2080
    Property(C): dir7AB140BB7265959ABBE25384D1407FEF = C:\Device\Nordic\nrf51422\Source\ext_sensors\cherry8x16
    Property(C): dir5FECA153F0EBB7CCFCE32A2B51D07F85 = C:\Device\Nordic\nrf51422\Source\ext_sensors\ds1624
    Property(C): dir78AD8086BC152EA624AD625612D52A47 = C:\Device\Nordic\nrf51422\Source\ext_sensors\mpu6050
    Property(C): dirA0862D4EB5E7296B1093F1BCD0F06A77 = C:\Device\Nordic\nrf51422\Source\ext_sensors\nRF6350
    Property(C): dir2E8FD353A87942D045101143E17B44A6 = C:\Device\Nordic\nrf51422\Source\ext_sensors\sdio
    Property(C): dir2E5AAD2DAECE72AA27C678AD242CC7E2 = C:\Device\Nordic\nrf51422\Source\ext_sensors\synaptics_touchpad
    Property(C): dir202AD3BF0EB38CC1B7149CA461407DB2 = C:\Device\Nordic\nrf51422\Source\nrf_assert
    Property(C): dir0DB088AC5A0C652E9F679A883F3F52C9 = C:\Device\Nordic\nrf51422\Source\nrf_delay
    Property(C): dir3CE2720F87F71BF7CF31B06E6A769EB3 = C:\Device\Nordic\nrf51422\Source\nrf_ecb
    Property(C): dir845E70C6EDF7EED0315816E656C62BD6 = C:\Device\Nordic\nrf51422\Source\nrf_nvmc
    Property(C): dirE89896A251C06B1D144936766C4C9223 = C:\Device\Nordic\nrf51422\Source\simple_uart
    Property(C): dir0DA2DE23A0A7311227757B1AA52BB74E = C:\Device\Nordic\nrf51422\Source\spi_master
    Property(C): dirDDA01AA571D47E86384365750C7244E5 = C:\Device\Nordic\nrf51422\Source\templates
    Property(C): dir10D330F3177CD553F6519739F7AE43A8 = C:\Device\Nordic\nrf51422\Source\templates\arm
    Property(C): dirD12CA3354C5202F71701DD07A649A298 = C:\Device\Nordic\nrf51422\Source\twi_master
    Property(C): dirEA5AD236030EF11280D73DC456E3A11D = C:\Device\Nordic\nrf51422\SVD
    Property(C): dir15C9C354921DC563BFCE82E0023EC706 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_alert_notification
    Property(C): dir861DCD7DDC5503B3349C4B58B19720BC = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_alert_notification\arm
    Property(C): dirD39A2ACEC9B637B838112684F018BDC6 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_bps
    Property(C): dirC16F380DC4DCF6FA77312A0B33FB9BE2 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_bps\arm
    Property(C): dir5353D7B7118E8C690D79DA8C0BD862E2 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_cscs
    Property(C): dir9686262C4A1C58FD764FA69F94974A81 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_cscs\arm
    Property(C): dir7CF04FCAE6E8D1740ACE75AD8DE8598F = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_dtm
    Property(C): dirD11F77F3E67DC9905D24C076799C08AB = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_dtm\arm
    Property(C): dir66AC396680C932DE8E9802A70EBDC7C2 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_gls
    Property(C): dirD69046DE48ADEE5978F5EEECA5BFB968 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_gls\arm
    Property(C): dir15A94E99C18AADBD6A79531B0A744946 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_gzll
    Property(C): dir2E03D33210FBBA2BE41A716F8C8AC7A4 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_gzll\arm
    Property(C): dirDF8DA8DE8B0C013FA082018FF36E565B = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hids_keyboard
    Property(C): dir441D0C3D594B9D8AD0D42D8008DFF127 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hids_keyboard\arm
    Property(C): dir88B4E7545183A5A1117919BBBDDD980C = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hids_mouse
    Property(C): dir40EAA8DCC4C201020FCDB883B60CE6DA = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hids_mouse\arm
    Property(C): dirD3CF8393CC202EC93D8A59A7D3C2DD6B = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hrs
    Property(C): dir6FFFD2E7F824FD277ECD90CCE2401850 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hrs\arm
    Property(C): dir1DE3D21BCC9E41222C82716D2ADDDD09 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hts
    Property(C): dir1D573F3B287340E30E1EC95237AC565F = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hts\arm
    Property(C): dir547EA279567F4F07FE2F883F87F77379 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_proximity
    Property(C): dirD1D20F6BDA3F94E27CD1E6522BA3179E = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_proximity\arm
    Property(C): dirCCFC517339B081C9A6183898B8D17163 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_pwr_profiling
    Property(C): dirB4657319ADE011316831D02E578EBD0B = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_pwr_profiling\arm
    Property(C): dirA25EC58E3B4523BB7EA26C8C63F03418 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_rscs
    Property(C): dirA854ACFE0CB6D4FF00A9EF6E2FA8A8EA = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_rscs\arm
    Property(C): dirCD5A66B37C19A36A4E6D73A0F333AEDD = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_template
    Property(C): dir891C9AD84D97C4E1CFC2D70411D3006F = C:\Device\Nordic\nrf51822\Board\nrf6310\ble\ble_app_template\arm
    Property(C): dirB5BD483ACB3427CBCD6FB8A14C3AED23 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble_s110_serialization\ble_app_advertising
    Property(C): dir6431ED8E8F514090767441A818B18301 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble_s110_serialization\ble_app_advertising\arm
    Property(C): dir9E80EBA12BE84EB8CE11ED05C38E5551 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble_s110_serialization\ble_app_connectivity
    Property(C): dir2A9D720C2FE5B3F45D59DD4EF9A8478B = C:\Device\Nordic\nrf51822\Board\nrf6310\ble_s110_serialization\ble_app_connectivity\arm
    Property(C): dir421E83128C2D4459967C57D19B124AA8 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble_s110_serialization\ble_app_hrs
    Property(C): dir89F13AAD3382367CB43EFDDDA30C12A2 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble_s110_serialization\ble_app_hrs\arm
    Property(C): dirC824B68DFF126200300E344C0855FE3F = C:\Device\Nordic\nrf51822\Board\nrf6310\blinky_example
    Property(C): dir7510D9046AEA6888C05DBA470853F209 = C:\Device\Nordic\nrf51822\Board\nrf6310\blinky_example\arm
    Property(C): dir39FD7401F11B282E45242AEAC7E97CCB = C:\Device\Nordic\nrf51822\Board\nrf6310\debouncer_example
    Property(C): dir8EA8F5BB400AF6A6AEC6E4E9BA04DACA = C:\Device\Nordic\nrf51822\Board\nrf6310\debouncer_example\arm
    Property(C): dir359BBE5D0CF84D0D7A24258C26E23E7F = C:\Device\Nordic\nrf51822\Board\nrf6310\device_firmware_updates\bootloader
    Property(C): dir23FB5AA415F9F7CFE71F7ACF930005B9 = C:\Device\Nordic\nrf51822\Board\nrf6310\device_firmware_updates\bootloader\arm
    Property(C): dir340915646C61A48676BA740D9AEBE4F1 = C:\Device\Nordic\nrf51822\Board\nrf6310\device_firmware_updates\bootloader\include
    Property(C): dir4A82C75BBB3FBBF2AB654E40E3CD0832 = C:\Device\Nordic\nrf51822\Board\nrf6310\device_firmware_updates\experimental\ble_dfu_send_hex
    Property(C): dir3F35D0B3BDE8C91449472FCEF4445A97 = C:\Device\Nordic\nrf51822\Board\nrf6310\device_firmware_updates\experimental\ble_dfu_send_hex\dfu
    Property(C): dirEF172FAD7BE98235F5088FCCA04324E7 = C:\Device\Nordic\nrf51822\Board\nrf6310\device_firmware_updates\experimental\hci_dfu_send_hex
    Property(C): dir4461CB9079A3EE890BA21B0A78725A0F = C:\Device\Nordic\nrf51822\Board\nrf6310\esb\esb_ptx_prx
    Property(C): dirDDFA403247D2CC6246F33BA1F56329F3 = C:\Device\Nordic\nrf51822\Board\nrf6310\esb\esb_ptx_prx\arm
    Property(C): dir16EB12A13B73B67459A1C7850ED49773 = C:\Device\Nordic\nrf51822\Board\nrf6310\ext_sensors\adns2080_example
    Property(C): dir0D9F80887D842AA04A19975BF0C79BCE = C:\Device\Nordic\nrf51822\Board\nrf6310\ext_sensors\adns2080_example\arm
    Property(C): dirDA94C9C02B0F6342ABB436913DA702CB = C:\Device\Nordic\nrf51822\Board\nrf6310\ext_sensors\cherry8x16_example
    Property(C): dirC4EDF6BF75F36A3A0D8FAC33CC5A5AB5 = C:\Device\Nordic\nrf51822\Board\nrf6310\ext_sensors\cherry8x16_example\arm
    Property(C): dir8A626E50773C90CB8399E9876E300A78 = C:\Device\Nordic\nrf51822\Board\nrf6310\flashwrite_example
    Property(C): dirB3ED7B61FD03B79202310A7C8D310648 = C:\Device\Nordic\nrf51822\Board\nrf6310\flashwrite_example\arm
    Property(C): dirC22D0E32A0EDB45FF2A3C1715F54E973 = C:\Device\Nordic\nrf51822\Board\nrf6310\gpiote_example
    Property(C): dirEF067533C443021B60C573D51DD79CA6 = C:\Device\Nordic\nrf51822\Board\nrf6310\gpiote_example\arm
    Property(C): dir1D242A0E04BEB73C279AE376699816F0 = C:\Device\Nordic\nrf51822\Board\nrf6310\gzll\gzll_ack_payload
    Property(C): dirB97CF03E2F4CE679B99C394A34650B6B = C:\Device\Nordic\nrf51822\Board\nrf6310\gzll\gzll_ack_payload\arm
    Property(C): dirD9A777EFF0E94F22F99ACA12256B81CB = C:\Device\Nordic\nrf51822\Board\nrf6310\gzll\gzll_ack_payload\gcc_device
    Property(C): dir890570E2F7C89AB02B6E9E88E9346DC0 = C:\Device\Nordic\nrf51822\Board\nrf6310\gzll\gzll_ack_payload\gcc_host
    Property(C): dir6B9DC843B96E4261A89B8F5737CAB911 = C:\Device\Nordic\nrf51822\Board\nrf6310\gzll\gzp_desktop_emulator
    Property(C): dir40440CF459942F60C542A11299C01E41 = C:\Device\Nordic\nrf51822\Board\nrf6310\gzll\gzp_desktop_emulator\arm
    Property(C): dir5C7A5AB9B65BB8463FD0AB4A1F6795C1 = C:\Device\Nordic\nrf51822\Board\nrf6310\gzll\gzp_dynamic_pairing
    Property(C): dir48BDD94F118C8FF4ACFB9E334A9D0B71 = C:\Device\Nordic\nrf51822\Board\nrf6310\gzll\gzp_dynamic_pairing\arm
    Property(C): dir824A2A3251B41CDE167C0EFAF08432CC = C:\Device\Nordic\nrf51822\Board\nrf6310\nRF6350_radio_configuration_example
    Property(C): dir41CE73E735B5DA228036363169236200 = C:\Device\Nordic\nrf51822\Board\nrf6310\nRF6350_radio_configuration_example\arm
    Property(C): dirB56EC3040C8B73F90A0A8B4F539D3FF6 = C:\Device\Nordic\nrf51822\Board\nrf6310\pin_change_int_example
    Property(C): dir0C35DEA0109DA451858D65D4F2CEF599 = C:\Device\Nordic\nrf51822\Board\nrf6310\pin_change_int_example\arm
    Property(C): dirD474E8FFD9056B4BF36D181B3C7879B1 = C:\Device\Nordic\nrf51822\Board\nrf6310\ppi_example
    Property(C): dir13ABFBA29D784D83505CDAA5EE52C678 = C:\Device\Nordic\nrf51822\Board\nrf6310\ppi_example\arm
    Property(C): dir67A4C48075160DB983598366F13952C5 = C:\Device\Nordic\nrf51822\Board\nrf6310\pwm_analyzer
    Property(C): dir112358C58D194F8C29D715ADF4C8A27F = C:\Device\Nordic\nrf51822\Board\nrf6310\pwm_analyzer\arm
    Property(C): dir798C6753777B8A4D1161234BE036B822 = C:\Device\Nordic\nrf51822\Board\nrf6310\pwm_example
    Property(C): dir7D5712EE1EB622F288FBC75BBA37ADEC = C:\Device\Nordic\nrf51822\Board\nrf6310\pwm_example\arm
    Property(C): dirEF75C71F9AAA9F86476CA82E45DD73C2 = C:\Device\Nordic\nrf51822\Board\nrf6310\radio_example
    Property(C): dir80A27ADF934FDCA8002C313EDC4A3F2C = C:\Device\Nordic\nrf51822\Board\nrf6310\radio_example\arm
    Property(C): dir0F6AC9D891F4E51E9FDEA3A586E25D00 = C:\Device\Nordic\nrf51822\Board\nrf6310\radio_test_example
    Property(C): dir86545FAEEC6295AC896498EB2157BDED = C:\Device\Nordic\nrf51822\Board\nrf6310\radio_test_example\arm
    Property(C): dir23BC22DEE1C93B937B04BEB8FBB630D1 = C:\Device\Nordic\nrf51822\Board\nrf6310\ram_retention_example
    Property(C): dir7844720680DE0C6B35B00AE9F8FDAFF2 = C:\Device\Nordic\nrf51822\Board\nrf6310\ram_retention_example\arm
    Property(C): dirE1836A794B6BC1EA9DFBB70FBC7732E7 = C:\Device\Nordic\nrf51822\Board\nrf6310\rng_example
    Property(C): dir97628D1761B722B51FA81D9E6F45352F = C:\Device\Nordic\nrf51822\Board\nrf6310\rng_example\arm
    Property(C): dir22A28CD7526DB2C594A1F5AEE508E007 = C:\Device\Nordic\nrf51822\Board\nrf6310\rtc_example
    Property(C): dirD09BF9E1D1936E469A06A52BE3AA6FEF = C:\Device\Nordic\nrf51822\Board\nrf6310\rtc_example\arm
    Property(C): dir64257CD2EC2FDE5034F168E9A5D6ADF8 = C:\Device\Nordic\nrf51822\Board\nrf6310\simple_pwm_motor_control_example
    Property(C): dir16945A02FE269DBF1DE6ADF4F1E24861 = C:\Device\Nordic\nrf51822\Board\nrf6310\simple_pwm_motor_control_example\arm
    Property(C): dir1D28D6DD95B435D0958F5412CEF85155 = C:\Device\Nordic\nrf51822\Board\nrf6310\spi_master_example
    Property(C): dirCBC067B33DEF863827640B264AFF6E00 = C:\Device\Nordic\nrf51822\Board\nrf6310\spi_master_example\arm
    Property(C): dir69523F8331992817FC291B577EE0C1E5 = C:\Device\Nordic\nrf51822\Board\nrf6310\temperature_example
    Property(C): dir1285932F900A0B0D90574FC593FFFD3C = C:\Device\Nordic\nrf51822\Board\nrf6310\temperature_example\arm
    Property(C): dir789C3F5A217012D017DE80932AA8BFCC = C:\Device\Nordic\nrf51822\Board\nrf6310\template_project
    Property(C): dirC9E82F7231B091DAEC308807D3053C61 = C:\Device\Nordic\nrf51822\Board\nrf6310\template_project\arm
    Property(C): dirC14A5853DD238196EBB08880E85AAECF = C:\Device\Nordic\nrf51822\Board\nrf6310\timer_example
    Property(C): dir8A8429A2CDB4D9FDDE0E4A777C212E91 = C:\Device\Nordic\nrf51822\Board\nrf6310\timer_example\arm
    Property(C): dirD4DF8FAD3E39FA441D84D0071AA5BC85 = C:\Device\Nordic\nrf51822\Board\nrf6310\twi_sw_master_example
    Property(C): dirC60A5B80FB2D0A54C919469EB3FBD93B = C:\Device\Nordic\nrf51822\Board\nrf6310\twi_sw_master_example\arm
    Property(C): dir5E555B4C03D43698FDBEFC0330A63749 = C:\Device\Nordic\nrf51822\Board\nrf6310\uart_example
    Property(C): dir434B40DB6085939773A29D02681F7FB3 = C:\Device\Nordic\nrf51822\Board\nrf6310\uart_example\arm
    Property(C): dirD7FA14D0A353C508A8217844896004AC = C:\Device\Nordic\nrf51822\Board\nrf6310\uicr_config_example
    Property(C): dir994437A564D0455AD58101C906407343 = C:\Device\Nordic\nrf51822\Board\nrf6310\uicr_config_example\arm
    Property(C): dirAC47840D716865B8432B481D358063B8 = C:\Device\Nordic\nrf51822\Board\pca10000\button_radio_example
    Property(C): dirB4FDC8AA33A27B65C81DC4A71FF6722C = C:\Device\Nordic\nrf51822\Board\pca10000\button_radio_example\arm
    Property(C): dir75AF121A109898615475FB48D8D108F0 = C:\Device\Nordic\nrf51822\Board\pca10000\led_radio_example
    Property(C): dirFD23E4D5F8AD614B59EB12C9FA366F40 = C:\Device\Nordic\nrf51822\Board\pca10000\led_radio_example\arm
    Property(C): dirEA8BD35CF43D07B12E82195D8F9506F3 = C:\Device\Nordic\nrf51822\Board\pca10000\uart_example
    Property(C): dirA95F2C4006A85A9C5AE537E620B81A35 = C:\Device\Nordic\nrf51822\Board\pca10000\uart_example\arm
    Property(C): dirD230A134607C4CDB45724E1FCA7E5B8F = C:\Device\Nordic\nrf51822\Board\pca10000\uicr_config_example
    Property(C): dirA2B4F93046AAAAE938AD3FFC4B345315 = C:\Device\Nordic\nrf51822\Board\pca10000\uicr_config_example\arm
    Property(C): dir9A37478E1266586DAC62065019D3FB0E = C:\Device\Nordic\nrf51822\Board\pca10001\ble\ble_app_hrs
    Property(C): dirCBC912AB94899A3D5FC3053C6ABF552D = C:\Device\Nordic\nrf51822\Board\pca10001\ble\ble_app_hrs\arm
    Property(C): dir5AE0F81433121FE615562E76768D732C = C:\Device\Nordic\nrf51822\Board\pca10001\ble\ble_app_proximity
    Property(C): dir126FF34F7CFE77CBB38A045905DF9489 = C:\Device\Nordic\nrf51822\Board\pca10001\ble\ble_app_proximity\arm
    Property(C): dir64B844CEBE552B20037F67D1E793A599 = C:\Device\Nordic\nrf51822\Board\pca10001\blinky_example
    Property(C): dirAD0DB943234BC2483DADE61642F615AF = C:\Device\Nordic\nrf51822\Board\pca10001\blinky_example\arm
    Property(C): dirD639E12263F7C3AA4F868212282C335B = C:\Device\Nordic\nrf51822\Board\pca10001\button_radio_example
    Property(C): dir270016D11F9FA243DBCFFDC9EFF4F048 = C:\Device\Nordic\nrf51822\Board\pca10001\button_radio_example\arm
    Property(C): dirD90E458E5FB7C6F4235D460A3BEAEE0F = C:\Device\Nordic\nrf51822\Board\pca10001\led_radio_example
    Property(C): dir3405BBFC445496385A9F12A8ECE15677 = C:\Device\Nordic\nrf51822\Board\pca10001\led_radio_example\arm
    Property(C): dir1392A99DB4669768C947126A1FB860CC = C:\Device\Nordic\nrf51822\Board\pca10001\uart_example
    Property(C): dirA62FF0B4AB77B5D1A8D4CA7028113EDE = C:\Device\Nordic\nrf51822\Board\pca10001\uart_example\arm
    Property(C): dir845382B51AE89F584D02DF607F9F1222 = C:\Device\Nordic\nrf51822\Board\pca10001\uicr_config_example
    Property(C): dirC650F7B3FE5A2D0B9A9E90453D036CD1 = C:\Device\Nordic\nrf51822\Board\pca10001\uicr_config_example\arm
    Property(C): dir90C1AEE27F56A87DAB60072B9F8F189B = C:\Device\Nordic\nrf51822\Include
    Property(C): dir113FC27AD9FBB052A496BE32952EEDA4 = C:\Device\Nordic\nrf51822\Include\app_common
    Property(C): dir6D980FFE2A81A29C0E0FDBC806FED17A = C:\Device\Nordic\nrf51822\Include\ble
    Property(C): dirD54796D7BE7865869217C60BDDFA9F40 = C:\Device\Nordic\nrf51822\Include\ble\ble_services
    Property(C): dirB909C8CA931D25682E0B4A6866B756C5 = C:\Device\Nordic\nrf51822\Include\ble\rpc
    Property(C): dir35F55640B46B811B268AF7533BE94568 = C:\Device\Nordic\nrf51822\Include\ble\softdevice
    Property(C): dirBDC67E555D00C84BDDBDB2D592CB0E2B = C:\Device\Nordic\nrf51822\Include\boards
    Property(C): dirDAA33ABFEF29FA2D18B46AEFE20C1D48 = C:\Device\Nordic\nrf51822\Include\esb
    Property(C): dir73E56F074003FC168D349B510ABD9F18 = C:\Device\Nordic\nrf51822\Include\ext_sensors
    Property(C): dir9DDC0DC49CCA6993BD9C867E191D7BD7 = C:\Device\Nordic\nrf51822\Include\gzll
    Property(C): dirD6E9D7FFE569F8A9BD0368ED36B5610B = C:\Device\Nordic\nrf51822\Include\gzp
    Property(C): dir79D557DA06385AFDC44D1F59BAF8094D = C:\Device\Nordic\nrf51822\Lib\esb\arm
    Property(C): dir4D7E91D9580FFFE1DAD366D5EFDEAD5A = C:\Device\Nordic\nrf51822\Lib\gzll\arm
    Property(C): dirCFFB6894F20F01747676E28066085A9D = C:\Device\Nordic\nrf51822\Source
    Property(C): dir35BA21B35A3DD5B50DBF15D6A23E4D86 = C:\Device\Nordic\nrf51822\Source\app_common
    Property(C): dirA179538A3033803AE7F1383B1DD246F1 = C:\Device\Nordic\nrf51822\Source\ble
    Property(C): dir1CE946493A390B3EBDA4E7B50D7FF62C = C:\Device\Nordic\nrf51822\Source\ble\ble_services
    Property(C): dir988F0843BA927FEAC2968D53D21F852E = C:\Device\Nordic\nrf51822\Source\ble\rpc
    Property(C): dir27F93FC8CE0149A688E8D637D4732DEE = C:\Device\Nordic\nrf51822\Source\console
    Property(C): dir4B4B92499D25BE31E621199CEEF4E8AE = C:\Device\Nordic\nrf51822\Source\ext_sensors\adns2080
    Property(C): dir91A09C5047049513A01CDB19A2D1D0E5 = C:\Device\Nordic\nrf51822\Source\ext_sensors\cherry8x16
    Property(C): dirCBDED7C80123E09099CD0A4C5B2C0037 = C:\Device\Nordic\nrf51822\Source\ext_sensors\ds1624
    Property(C): dir0563269137A1A651D5F5846BAC4EB5E2 = C:\Device\Nordic\nrf51822\Source\ext_sensors\mpu6050
    Property(C): dirEF88C622246A73D06D1911D640E5C438 = C:\Device\Nordic\nrf51822\Source\ext_sensors\nRF6350
    Property(C): dir6374D7345F9512C7E52CFF72CCEB237B = C:\Device\Nordic\nrf51822\Source\ext_sensors\sdio
    Property(C): dir67EE247308A3552619B1D920FCF688FE = C:\Device\Nordic\nrf51822\Source\ext_sensors\synaptics_touchpad
    Property(C): dir7709471BBB723930AEF767C7402F1E57 = C:\Device\Nordic\nrf51822\Source\gzp
    Property(C): dir0C838E52F9773F3EF72062EA6BBB6C86 = C:\Device\Nordic\nrf51822\Source\nrf_assert
    Property(C): dir59C8072A6A4CFF4A1773C48D8A924FFA = C:\Device\Nordic\nrf51822\Source\nrf_delay
    Property(C): dir066F27CB713F99E0D8345576D2850500 = C:\Device\Nordic\nrf51822\Source\nrf_ecb
    Property(C): dir246C7AFF5A8C9CFE2CCBBBB4835DFF54 = C:\Device\Nordic\nrf51822\Source\nrf_nvmc
    Property(C): dirA83FBDFD50DF8C07FB76DE721C900146 = C:\Device\Nordic\nrf51822\Source\simple_uart
    Property(C): dir60174089E1D3D42F5D8C9480AABC80E5 = C:\Device\Nordic\nrf51822\Source\spi_master
    Property(C): dirA196647F9D22C2F62A5AEB7BCEA540A8 = C:\Device\Nordic\nrf51822\Source\templates
    Property(C): dirB289E4B7A68A2571A512484906B7F327 = C:\Device\Nordic\nrf51822\Source\templates\arm
    Property(C): dir2438049B10BF97A7949F34A019882285 = C:\Device\Nordic\nrf51822\Source\twi_master
    Property(C): dir8420B9EBF656186077C0C0DA7B1F77A9 = C:\Device\Nordic\nrf51822\SVD
    Property(C): KEILROOTDIR = C:
    Property(C): Dir.Keil.UV4 = C:\UV4
    Property(C): Dir.Keil.Flash = C:\ARM\Flash
    Property(C): Dir.Keil.SFD.nRF51 = C:\ARM\SFD\Nordic\nRF51
    Property(C): dir26B7AE0AB0874B6017E39183FAACFBCB = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\Documentation
    Property(C): dir9F6248BA3749589DC0D64B6275D3D5C5 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\Documentation\html
    Property(C): dir0074CB394F13F88CBAB786052814129F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\Documentation\html\search
    Property(C): dir959645BDFAA3B3C2C9E63E49A32F85F1 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_comb_spd_cad\sensor
    Property(C): dir59969D91FA98EBEDC7ADB50E3E162610 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_comb_spd_cad\sensor\arm
    Property(C): dirA05B1A92E75B08A8119925EBD5BBCCD7 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_comb_spd_cad\sensor\include
    Property(C): dir59112FFF39B90556D403754ABD3F716F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_pwr\bicycle_power_minium_receiver
    Property(C): dir2C1A7691F9FE8C151CE518250BD58C19 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_pwr\bicycle_power_minium_receiver\arm
    Property(C): dirDC1071766F89ED9826915E2E5FE35188 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_pwr\bicycle_power_minium_receiver\include
    Property(C): dirD3B0F9AB66FA478A25059B1BEA678BB0 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_pwr\bicycle_power_only_sensor
    Property(C): dirD7E9F5AD51E493A95FC2FEBFF16646DA = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_pwr\bicycle_power_only_sensor\arm
    Property(C): dir9BA35CFF6FD48426A9A30E4D8ADE98DB = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_pwr\bicycle_power_only_sensor\include
    Property(C): dir8A654C4A4B402DABFACB5F75FDEF446A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_broadcast\broadcast_rx
    Property(C): dir254DFFE5204225C8141DC9C51F9F6CE4 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_broadcast\broadcast_rx\arm
    Property(C): dir459DDC4F46271AAE22519BE3A54D11C9 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_broadcast\broadcast_tx
    Property(C): dir894CE029F8FA1656A785F7095A6E9554 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_broadcast\broadcast_tx\arm
    Property(C): dir41BE0C3378EE9967213AF52D42CFF2CC = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_fs\client
    Property(C): dir07421F92E42792DD6B57EA8809C7E818 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_fs\client\arm
    Property(C): dir2D50128BADA207486071CC870D136151 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_fs\client\include
    Property(C): dir2F6CADE9ECE2B1943E3D7817DA66ADF0 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_rx
    Property(C): dir5D2AB684B1E024CB21BBF12E21FBF43C = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_rx\arm
    Property(C): dir8BF3D1EB3F826BE231B38C1467CC8973 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_rx\include
    Property(C): dirF99A3F9602FD5C23217FA3174CD06812 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_tx
    Property(C): dirFD975CF52F213FD735CA37F6D49BD3D3 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_tx\arm
    Property(C): dir5D1B4377C0A21A9260BC154A5CCD07A5 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_tx\include
    Property(C): dir73E81BF1E923D25F897415FBF795001E = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_tx_buttons
    Property(C): dir139D6E39B66AC501D94FFBA1CE5333CD = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_tx_buttons\arm
    Property(C): dirCBED6F3F72A002443A9EB2FA14D48851 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm\hrm_tx_buttons\include
    Property(C): dir00B61F6EF1C0200C89390212698FC238 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_sdm\sdm_rx
    Property(C): dir83585506B745CDEA2BFCB07E6F015AA9 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_sdm\sdm_rx\arm
    Property(C): dir916D329C45131D3C33A8FF6BC295CCEB = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_sdm\sdm_rx\include
    Property(C): dirB04B317828FD845F2CAC15C277C3E743 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_sdm\sdm_tx
    Property(C): dirF835F175DB6B44A85AAAE5AC0C4D99CA = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_sdm\sdm_tx\arm
    Property(C): dir54CAEDDACA73CDCB1A2DCEB0ED3A4D2E = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_sdm\sdm_tx\include
    Property(C): dirFED6030AAF4A44667CA81EFA0F8F48F9 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\blinky_example
    Property(C): dir26A04450F071EA1FCD90666D69BE86D0 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\blinky_example\arm
    Property(C): dir00DD68302A5AEBF37A2C54BD88D19F43 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\blinky_example\gcc
    Property(C): dir1C8D73C0988CE774A8A3CCD90CB02FC9 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\blinky_example\iar
    Property(C): dir0462C611979A9507ADFD63D47B2CE93A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\debouncer_example
    Property(C): dirE8445EDD0226C6F9DC635576FA19FDB7 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\debouncer_example\arm
    Property(C): dir9FB3033FA6657171A5F082FB7EA97679 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\debouncer_example\gcc
    Property(C): dirE2EDA5129C247E195808EC82DC67D07C = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ext_sensors\adns2080_example
    Property(C): dir24C16CE00316A3318A1F347CBC7460EB = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ext_sensors\adns2080_example\arm
    Property(C): dirFCCA409265E7F715FC1ED572D6F5342A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ext_sensors\adns2080_example\gcc
    Property(C): dir79AEEB9960F341A6C661B4A50D44AE3B = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ext_sensors\cherry8x16_example
    Property(C): dir9BA0E0A1699112965D1B7D8146753A85 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ext_sensors\cherry8x16_example\arm
    Property(C): dir03B2E6D27BBCFD1569D8BAD705BCD71A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ext_sensors\cherry8x16_example\gcc
    Property(C): dir0DEAB65A6A70CE1A8089F4E79DA82B93 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\flashwrite_example
    Property(C): dirF07349A6E5E184E92EE9530800F1A27D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\flashwrite_example\arm
    Property(C): dirFDA3FED91E917CC5E43BD09D60F7EB1B = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\flashwrite_example\gcc
    Property(C): dir2B123F8B286C096EFB80FE68737836BF = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\gpiote_example
    Property(C): dir2D97F0FF892B4A8CE0B67EDAA42FB934 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\gpiote_example\arm
    Property(C): dir56649E88FF643C83E8C73319BE374619 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\gpiote_example\gcc
    Property(C): dirB94D38BE2A95B002A02EDB3B6114214E = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\nRF6350_radio_configuration_example
    Property(C): dir1C1E0805BFD3BC6FF77F6068B6D968CF = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\nRF6350_radio_configuration_example\arm
    Property(C): dir2B16AAD0B21CDE34EAEFE707D47F7319 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\nRF6350_radio_configuration_example\gcc
    Property(C): dirD9017BEB45EC160C6D4461170E00850A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\pin_change_int_example
    Property(C): dir15B27F47B383DDF319A6C02B60C2E724 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\pin_change_int_example\arm
    Property(C): dirEEA25B786ABDA16C9EDBB8C8FE35E69A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\pin_change_int_example\gcc
    Property(C): dir86BE8AC21F1A53C3E4A7515AEFE8F6F8 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ppi_example
    Property(C): dir2D08726A2A2141A32FCF4B5BB743B915 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ppi_example\arm
    Property(C): dirA83C80FBBB72E53B1C7B533A87F5DA0F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ppi_example\gcc
    Property(C): dirA5CB52FD58E855358E0805FAD74939C6 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\pwm_analyzer
    Property(C): dirC9CC67305774DBFD6840B9895ECACCBC = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\pwm_analyzer\arm
    Property(C): dir2895DB1D0440BF3868947971BEE6DC84 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\pwm_analyzer\gcc
    Property(C): dirDF4AA7BE6E5853363FB2BBA3B8098B42 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\pwm_example
    Property(C): dir81D206017B75D26A41C1FEBB2CAD7D00 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\pwm_example\arm
    Property(C): dirC8D32AC40AE58DE0BC92A13DC7A424E1 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\pwm_example\gcc
    Property(C): dir0DDE2CEF484140603504B7FA4077732F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\radio_example
    Property(C): dir0E2FD2BC33C274A7078C20DDDA72CF05 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\radio_example\arm
    Property(C): dirBE95B115DF565AF9D7ECC82AB0CC9DC2 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\radio_example\gcc_rx
    Property(C): dir792E8DA4857E32C1C6DE68F6CB6A05EA = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\radio_example\gcc_tx
    Property(C): dirA96AFD47F2BA212FDF5A1CDB16CB5BF6 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\radio_example\iar
    Property(C): dir294B473FF9344851EC94C92FE66C76BB = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\radio_test_example
    Property(C): dir6C01409E87349CFA551020F73C559555 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\radio_test_example\arm
    Property(C): dir78FE78FFFBC7F5443630FCEA624F8E95 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\radio_test_example\gcc
    Property(C): dir698C7CCD1145050A96628D26CC6E8C09 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\radio_test_example\iar
    Property(C): dirABD53F192AE1AD3289C5777BC04D141A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ram_retention_example
    Property(C): dir0E3C531EAB055E90B81BCDDD5D679A27 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ram_retention_example\arm
    Property(C): dir33E7F33B57D28CFF852019113778AA47 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ram_retention_example\gcc
    Property(C): dir1CB8FAC209A44B38E04A0D975970AFB9 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\rng_example
    Property(C): dirE18AA4DEFC0294EFAB4D75189761AFE4 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\rng_example\arm
    Property(C): dir535D6C583F4BB38382253A1885134A66 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\rng_example\gcc
    Property(C): dirDA04605A0D948B97F184ED9E8915AFDB = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\rtc_example
    Property(C): dirDCC19F6DA77731B6413F1F2799628492 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\rtc_example\arm
    Property(C): dir6805BDC4894006A4FD0B210B255F4806 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\rtc_example\gcc
    Property(C): dir16D9D00B72CD6C21578F70F9308A2816 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\simple_pwm_motor_control_example
    Property(C): dir08B54234C0C0EACCBB39CE905A97422D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\simple_pwm_motor_control_example\arm
    Property(C): dir71E5A5868D019DE065CB8356D9855C0A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\simple_pwm_motor_control_example\gcc
    Property(C): dir7F0D320B2AAF6002E47625EB41FEFBEF = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\spi_master_example
    Property(C): dirC4D9C8C0852AD0960065B9C7BD986310 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\spi_master_example\arm
    Property(C): dir69C87FCC13855C7FB7CF0C854C60DB01 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\spi_master_example\gcc
    Property(C): dirFD3FF793340982F5DA9692BA8659004C = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\temperature_example
    Property(C): dirB378640A14065A5907C9885D45A9FCB8 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\temperature_example\arm
    Property(C): dirEB671325A1C3D717CF31823BF637B52B = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\temperature_example\gcc
    Property(C): dir357234FB870DFFC44A5B190E454A8197 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\temperature_example\iar
    Property(C): dir9E5B25A125F6F5BAEA4EED7DE776DA8D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\template_project
    Property(C): dirDF02256F18C811E7F142CC42C7288E52 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\template_project\arm
    Property(C): dirA3BBE7911E6E0FBAD4D27E075E831773 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\template_project\gcc
    Property(C): dir43BD307A5BDEFE5C812757D87940272F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\template_project\iar
    Property(C): dirB9A929069D7D2BE3E0499B67C1F34083 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\timer_example
    Property(C): dir07B36DCB5C96A75F349DE5849534392B = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\timer_example\arm
    Property(C): dir3DDFFE5CEEB2FC3F432C99D6BEDDBD22 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\timer_example\gcc
    Property(C): dir8358C7ABE46EEEA911036FFED0FD1E6B = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\twi_sw_master_example
    Property(C): dirB0F754300CEC77D5911E760FE4DC4825 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\twi_sw_master_example\arm
    Property(C): dirFDC468A10A515B0BD92F39375B07F180 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\twi_sw_master_example\gcc
    Property(C): dir42308AE2AD79E90518D4C8D0CC978D48 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\uart_example
    Property(C): dir039917925B1F127384B8C84F1BD5F51F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\uart_example\arm
    Property(C): dirE72E65A37805A151AB5335618A1B4A3E = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\uart_example\gcc
    Property(C): dir992AE1E06075731BACF638F64E88C7FD = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\uicr_config_example
    Property(C): dir6C55D40A95CA77CBEB624CC2432EA795 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\uicr_config_example\arm
    Property(C): dir375FF5EDFA6A490C438087D15264CF5D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_comb_spd_cad\sensor
    Property(C): dir94FD7081ECCEB5665F84DC878624025D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_comb_spd_cad\sensor\arm
    Property(C): dirE0635593BA3447F953C6A64351CAF86A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_comb_spd_cad\sensor\include
    Property(C): dir1D9341A8AF3AA62B1924E9D2C88AA102 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_pwr\bicycle_power_minium_receiver
    Property(C): dir8A1F5B2289D5ADF773E717229E12484A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_pwr\bicycle_power_minium_receiver\arm
    Property(C): dir5A9986616BA880B41E89A2A6567EE001 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_pwr\bicycle_power_minium_receiver\include
    Property(C): dir0EA55541E34960565F6141097FF29C31 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_pwr\bicycle_power_only_sensor
    Property(C): dirFCA97F81AF48693C019638AA612CE8CE = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_pwr\bicycle_power_only_sensor\arm
    Property(C): dir93CCDD49F2140B8E3B7CAC04465D575B = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_pwr\bicycle_power_only_sensor\include
    Property(C): dir59C3AA0CBA35FE7469F6FA83F53998F0 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_broadcast\broadcast_rx
    Property(C): dir6988B6346D6DE85CBD74A1598536C812 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_broadcast\broadcast_rx\arm
    Property(C): dir66A92921C45A5B85C78539BBE331671C = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_broadcast\broadcast_tx
    Property(C): dir62904362C804C7FE3DCF53699545EB09 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_broadcast\broadcast_tx\arm
    Property(C): dir22A57423A7BA1FC335AFC523CBA2A118 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_fs\client
    Property(C): dirF7D9BA99716260197A3BBD1A15C2B6A7 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_fs\client\arm
    Property(C): dir2CA1B98A1659079781A3E1C0A99AA1ED = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_fs\client\include
    Property(C): dir540EC84F138CF79120809AE2EE88CEE0 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_rx
    Property(C): dirD07A2BBF2AD392FBCE6BC3652B5EE247 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_rx\arm
    Property(C): dirB78D749C5EBB9CB154A6DA2EFE29D3AF = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_rx\include
    Property(C): dir34C05626842E694F3032E1CF166CD4E3 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_tx
    Property(C): dir2EF3BF4105D3607E576E2C818751900A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_tx\arm
    Property(C): dir5A7DF2F0177E4276BEB7E0F67AECF25B = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_tx\include
    Property(C): dir45213815FF87C5421E1FE10E1C67B716 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_tx_buttons
    Property(C): dirBBED40E709F2819CFEDB38BACE843F30 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_tx_buttons\arm
    Property(C): dir800BC06A7467649A6337AAF1E1244B62 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_hrm\hrm_tx_buttons\include
    Property(C): dir83B35D6749C26A4DE65248C60C37641C = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_sdm\sdm_rx
    Property(C): dirA0FD9F199A55650B018DF82C4EB0A352 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_sdm\sdm_rx\arm
    Property(C): dir9DE691BB41CE65EE66A0F01F63EF1A45 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_sdm\sdm_rx\include
    Property(C): dir6B5EFA99ACDA07501E3876C0412C3B7E = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_sdm\sdm_tx
    Property(C): dir6E276B33488247C099CE595828BED71A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_sdm\sdm_tx\arm
    Property(C): dirBB3942AABC79189E017D57612C6F8125 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_sdm\sdm_tx\include
    Property(C): dir89DAAD1DA9F18ACE5224B0C3A695204F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\blinky_example
    Property(C): dir439B2A52D18FA9C7663B4B7C5856AEC8 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\blinky_example\arm
    Property(C): dirFFEADFCE87B5B5A6375EF0298174ED0F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\blinky_example\gcc
    Property(C): dir85D13171837D6EB690DD43F9EBB9174A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\uart_example
    Property(C): dir2C981C8A38962872135F297F5932FFE6 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\uart_example\arm
    Property(C): dirF7A384F88821E3B681943B9F7C6E368D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\uart_example\gcc
    Property(C): dir9C41644B664E6E4C72A22FDEF48F4CFE = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\uicr_config_example
    Property(C): dir94AE2529EB0ED411EEE9AEB5E00E5F6D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\uicr_config_example\arm
    Property(C): dir07BC7425765670ED5006BC666D2CCBE4 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Include
    Property(C): dirFE7F0F15D2CE79F9EAFD703085C70C31 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Include\ant\softdevice
    Property(C): dir828C2112293EE325E98BE20F0200A3AB = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Include\app_common
    Property(C): dirA1D82925F982CF9D6764910E560E2EAD = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Include\boards
    Property(C): dirEAE6E7DFEE05CE0BD3FEC844E613B061 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Include\ext_sensors
    Property(C): dir965CF9ABE7D4D02C131C5AB147EC1E45 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Include\gcc
    Property(C): dir9365BB77AD75DF4F438702E8E2A9996D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source
    Property(C): dir544710AE8938DB9177818DA27490FDF0 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\app_common
    Property(C): dir321B91D7F1DF2A6C0EBDBCCA299A8328 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\console
    Property(C): dir242B90965B29A784C9E62CD7474F300D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\ext_sensors\adns2080
    Property(C): dir7FF012640F8704D6B16980773BDF74EE = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\ext_sensors\cherry8x16
    Property(C): dirC2922001A59061D20E7601EA4256F05D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\ext_sensors\ds1624
    Property(C): dirED95CB1F902A159AF88AAD1F9193AC6D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\ext_sensors\mpu6050
    Property(C): dirE35473DD2F7261060B4EE9636597A90A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\ext_sensors\nRF6350
    Property(C): dir155F9AA40D3E98A0B4F4236332F72F13 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\ext_sensors\sdio
    Property(C): dirA792F2DB0A18E551A76E3DC43FB44341 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\ext_sensors\synaptics_touchpad
    Property(C): dirCD6EFE1C0F09A42344240EDE3B6974B2 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\nrf_assert
    Property(C): dir4AB85A68B397200275B9FDF38A95389A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\nrf_delay
    Property(C): dir64668D17852009C7A01390388324F27B = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\nrf_ecb
    Property(C): dirB15861588173DC1CC1026C73B1129CEA = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\nrf_nvmc
    Property(C): dirE4508A0DFAC9B73524C30D807C53B1F7 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\simple_uart
    Property(C): dir52E60EE47641140736E03DF76354CCA9 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\spi_master
    Property(C): dir9853D50FFFEF0BFD98D1ECB6EBF56EE3 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\templates
    Property(C): dir3E10D84B44945E17AEB5956EF0EBEDD0 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\templates\arm
    Property(C): dirCC2A361D5E647FBE9EB61178A3A95F2A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\templates\gcc
    Property(C): dirE078C29A5AB113A21C94BF699A5417C3 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\templates\iar
    Property(C): dir581B2630CDB037A96B56A12C6E776616 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\twi_master
    Property(C): dir507DA339D2A8C0C279056CB87278B568 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\SVD
    Property(C): dir0FAC094C43C523CEA8FA85AEBBBB2F21 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_alert_notification
    Property(C): dir9C284612025C8ED7F405CF545B980091 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_alert_notification\arm
    Property(C): dir55FA21CEE8E940626A6D7E555A9E7420 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_bps
    Property(C): dir5CC045C34DDE50583E16BEBCD43A78F8 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_bps\arm
    Property(C): dirAEBCAFCFA7FBB30AACD6C92C0ED25152 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_cscs
    Property(C): dir81C20280669676ACCDE590233BA57E19 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_cscs\arm
    Property(C): dir454CCBE088E58DEC37F99D209BEA3EFF = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_dtm
    Property(C): dirF90F43D62A696E3738ADB62050F4A0C7 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_dtm\arm
    Property(C): dir865A783118BF701785A5C186AAFB8C1A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_gls
    Property(C): dirB455763A4AF60825D94F94A0CC407ECE = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_gls\arm
    Property(C): dir3D823CDF627409468C932208276CE141 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_gzll
    Property(C): dirF91EFE3EF4FE05D23BD7D3B06DFB503E = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_gzll\arm
    Property(C): dir83080E03B64FAB5F16A03C8499151E90 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hids_keyboard
    Property(C): dir29C228A6DD95F3C488071E75BBB29D6D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hids_keyboard\arm
    Property(C): dir4DAF94CF675B9B0C35E0E19A6B1B05AA = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hids_mouse
    Property(C): dirA5560319D1DB74DEAF830386E4F4C5C3 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hids_mouse\arm
    Property(C): dir1CBF8026BAE47A788D1FE859157285F9 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hrs
    Property(C): dirBFC93F5D932A0E8DC9223A27936D04BE = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hrs\arm
    Property(C): dir9F8C24E0DE3F1FCD322A36731CE82A2A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hrs\gcc
    Property(C): dirA8DF815B62EE87BE4C9C0FC80F839E59 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hrs\iar
    Property(C): dir8C3374F2AF8D5E9D3A3DF7A2CC1C3A8E = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hts
    Property(C): dirCC0AEACA09D54E1100F2F2DC1A87B550 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_hts\arm
    Property(C): dir4973A1928DAE7F1118FFA204E51D286D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_proximity
    Property(C): dir9846B8CAEA0270E387CA16E9551FF807 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_proximity\arm
    Property(C): dirBB903E391D4753CCD0CA75E8438C2A94 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_pwr_profiling
    Property(C): dir2745073D28FBB46B6718BDEF627455F5 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_pwr_profiling\arm
    Property(C): dirFCFA418C55E31A185AF73EEE6503FDD7 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_rscs
    Property(C): dir838239B43E90475722BD0F5F050D0EA1 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_rscs\arm
    Property(C): dirAE76AC78343405DB23A25647A06C7E1F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_template
    Property(C): dirE2F54B24ACE6356077962F881699D809 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble\ble_app_template\arm
    Property(C): dir8C82460FA4AA37BCC2951594BBC5C269 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble_s110_serialization\ble_app_advertising
    Property(C): dir9168887C9EFADBC7A0FD8F1C34CA4427 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble_s110_serialization\ble_app_advertising\arm
    Property(C): dir56B016D39B05A286571DD4CF0D979E7C = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble_s110_serialization\ble_app_connectivity
    Property(C): dirAD03C6504CB4E40263ACAF546280BEA2 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble_s110_serialization\ble_app_connectivity\arm
    Property(C): dir5CB78BC6081A00ADB321F633CBDDBD99 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble_s110_serialization\ble_app_hrs
    Property(C): dirF572BDE9DD2CB4511A306C98FC925A36 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble_s110_serialization\ble_app_hrs\arm
    Property(C): dir0393874B7E4F791F089271A6608D65F2 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\blinky_example
    Property(C): dirA7B5DFAA6B8A11F1753EE805A48CE307 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\blinky_example\arm
    Property(C): dir9102BF9ADD9A220C84B76D0F03096C85 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\blinky_example\gcc
    Property(C): dir61B93CEEEC8171CC90748516F89516C1 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\blinky_example\iar
    Property(C): dir5B5A4960965BE83678D53851A7F6F53D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\debouncer_example
    Property(C): dir43E2DABD12584C5F3389B32D35864B18 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\debouncer_example\arm
    Property(C): dir5F4A16BD092ED7036B47A0E623DF012A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\debouncer_example\gcc
    Property(C): dir809F74E355B7EBB5B7D8593F042BA589 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\device_firmware_updates\bootloader
    Property(C): dir45D487CCBFD395134990248C0ED60AFC = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\device_firmware_updates\bootloader\arm
    Property(C): dirF65DB39DDD260B2582C597E949A862DA = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\device_firmware_updates\bootloader\include
    Property(C): dir5173EA7A9E30CC654F5A1F1CA0B7B9CC = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\device_firmware_updates\experimental\ble_dfu_send_hex
    Property(C): dirDF3C2EDC8746B6EE90A23CFB77E1CBFF = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\device_firmware_updates\experimental\ble_dfu_send_hex\dfu
    Property(C): dir0BEAE931D39F52278708236F622F7E25 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\device_firmware_updates\experimental\hci_dfu_send_hex
    Property(C): dirF97A7F07E3F2444CC77316CA7F2444ED = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\esb\esb_ptx_prx
    Property(C): dirF367AEBCB84A820BACB2D532DC8D8DB2 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\esb\esb_ptx_prx\arm
    Property(C): dir7E384572D1F35C27390184DB63F5EC9F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\esb\esb_ptx_prx\gcc_rx
    Property(C): dirC08F1E4BF90501AB8AFC1304ADA08789 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\esb\esb_ptx_prx\gcc_tx
    Property(C): dirD43B9274B5F8D14B0246603EC0D413A9 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ext_sensors\adns2080_example
    Property(C): dir1023671125D685888346C28BBE79F2BE = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ext_sensors\adns2080_example\arm
    Property(C): dirAA0E9A307588660CBB5EE9A58141AB42 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ext_sensors\adns2080_example\gcc
    Property(C): dir17DBA7E7895B0A48B5D3FD74422A1F9F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ext_sensors\cherry8x16_example
    Property(C): dir2B3C00791CA57373558E8765275EF469 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ext_sensors\cherry8x16_example\arm
    Property(C): dir9340DF8B2CA505E5FB30A2F5617A066A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ext_sensors\cherry8x16_example\gcc
    Property(C): dir5AF94A15B794B0FE79F63AE9D942D650 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\flashwrite_example
    Property(C): dir6BFAD048329E8410355B0E3423A9156D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\flashwrite_example\arm
    Property(C): dir1716B5186F99C680F553F20B5E16924F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\flashwrite_example\gcc
    Property(C): dir8CA99C8C707B097731BBD14D37184309 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\gpiote_example
    Property(C): dirEC36E82DF19AD866495DAA31FEE04B52 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\gpiote_example\arm
    Property(C): dirC71675A31CAC8D5A702DC17E246C8A4C = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\gpiote_example\gcc
    Property(C): dirA31823B10CA3E860B921721B9D36C110 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\gzll\gzll_ack_payload
    Property(C): dir1F009A74C88AA080E917711368E5B634 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\gzll\gzll_ack_payload\arm
    Property(C): dirAC3DBD283D73B00588AE77620D6C9CAB = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\gzll\gzll_ack_payload\gcc_device
    Property(C): dir58AF5BFD5A475E9EE46DFF0DAC0495A7 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\gzll\gzll_ack_payload\gcc_host
    Property(C): dir59A63BC475CAE608089DE9130F0A478E = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\gzll\gzp_desktop_emulator
    Property(C): dir395205707986928CF5B41012291F5356 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\gzll\gzp_desktop_emulator\arm
    Property(C): dir413832EFBF55285D9BF81F3C1C24DE18 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\gzll\gzp_dynamic_pairing
    Property(C): dir49BBCE940493E421D824CFA7FA40455D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\gzll\gzp_dynamic_pairing\arm
    Property(C): dirB2ACF8654D1D3FBBACBBA961BD6F657C = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\nRF6350_radio_configuration_example
    Property(C): dir28065943328380C738E8CAC3F34B8D79 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\nRF6350_radio_configuration_example\arm
    Property(C): dirC87361369709A758560307342C5A46FA = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\nRF6350_radio_configuration_example\gcc
    Property(C): dir86C58AA2D4612E4934172146C2023563 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\pin_change_int_example
    Property(C): dir90E56767C3AA9D56DCE57B678FEED822 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\pin_change_int_example\arm
    Property(C): dir4A8BBD54997E5D94AF01EF17F4B93A99 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\pin_change_int_example\gcc
    Property(C): dir49D2660736662317A2EB392CD8730B54 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ppi_example
    Property(C): dir66E8D882D39A6D0012B3C865AF3A71E3 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ppi_example\arm
    Property(C): dirF1079DE3AC198D16DE970891130FC09D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ppi_example\gcc
    Property(C): dir3ECFDA6FF21BD0A6AE65A7687E542E92 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\pwm_analyzer
    Property(C): dirF2954A37FD83A5267278277FC28A45D1 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\pwm_analyzer\arm
    Property(C): dirDB41C5E569071F75E7C201266CC97B40 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\pwm_analyzer\gcc
    Property(C): dir0039C5E45321285E8FD82ED252285240 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\pwm_example
    Property(C): dir06A09313846CC0EC901E00355406E8E0 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\pwm_example\arm
    Property(C): dirAC16ED48896CADCAA04D63CE7BC3E10F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\pwm_example\gcc
    Property(C): dirAF825D6BBD88091740D497A98BB167A3 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\radio_example
    Property(C): dir275CFE14F37E85598AD64754A0BA3430 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\radio_example\arm
    Property(C): dir42E0A36A26AF4D6BDCCAB7AC00388A23 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\radio_example\gcc_rx
    Property(C): dirCBC56DA0918D6D05AB04F574BA8DBBB1 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\radio_example\gcc_tx
    Property(C): dirD8FF50C38D0B7CA0AC31022BAA2BF191 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\radio_example\iar
    Property(C): dir1D4CEF7B0515A048AF03C1D9609D00B2 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\radio_test_example
    Property(C): dir6544B5F91241E60B96A39B7D2AA5AEAE = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\radio_test_example\arm
    Property(C): dir74890D07835EAAC1A23D0AFB9B1B3759 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\radio_test_example\gcc
    Property(C): dir32EBDE92085E7E005AE1F1D3B37A3436 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\radio_test_example\iar
    Property(C): dir8C84703A6A9EE680D9DCA1FDF232923D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ram_retention_example
    Property(C): dirBEB7EF10D6F63322058272BA8C1E02B6 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ram_retention_example\arm
    Property(C): dir63D64C9CAEF943010D813CEA4C9295E7 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ram_retention_example\gcc
    Property(C): dir466C7234C02DCE4EECB4CC214B23C078 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\rng_example
    Property(C): dir9F55D17A969CA713F2424D8CA3433990 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\rng_example\arm
    Property(C): dir57F81AB5A8000F056DF36CBDCB070EAE = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\rng_example\gcc
    Property(C): dir9F9BCFBBDA111F029D40860F02AFBDD2 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\rtc_example
    Property(C): dirED05EFBE1727D7F283D45E9848D0FCCB = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\rtc_example\arm
    Property(C): dirB9DF1B0D6D8A62C3DFFDF7BD3DA27EEF = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\rtc_example\gcc
    Property(C): dirC428F11D5EF97550FD73309D2D1CD71B = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\simple_pwm_motor_control_example
    Property(C): dir0F1378FCF17A435BC73115C7AD1DB38F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\simple_pwm_motor_control_example\arm
    Property(C): dir749FC6D634FA75DCC0362D87EDB429C5 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\simple_pwm_motor_control_example\gcc
    Property(C): dirDCF32300C86D7959083C3C138E364DEA = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\spi_master_example
    Property(C): dirCF9E73F6643070BB1E343B65AE25D735 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\spi_master_example\arm
    Property(C): dir79416A3A913B28369BD4705BAA08497E = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\spi_master_example\gcc
    Property(C): dir345D3D3FBAC85E4FF2F81800A0D7A124 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\temperature_example
    Property(C): dir9382A81D1FE1DE9436E0903046F94F52 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\temperature_example\arm
    Property(C): dir1BA50DF0FABEE7116EFC4471A2A06778 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\temperature_example\gcc
    Property(C): dirF95F4EDBB8B68E419BFFE065C86AED21 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\temperature_example\iar
    Property(C): dirB3E91633E8F4EB92E837F54E635955E0 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\template_project
    Property(C): dir19E0D430596021A78C3A5D86DA87AA56 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\template_project\arm
    Property(C): dir15958A7206B29604EA95007D7A8119F1 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\template_project\gcc
    Property(C): dir62FD4381BC079D677A7817D8CF24D88F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\template_project\iar
    Property(C): dir74BA246E28BFBC6A0D83F1D965B576A2 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\timer_example
    Property(C): dir8075F982105FD0A6D9973E8007EEBDC0 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\timer_example\arm
    Property(C): dirA0F4FF01CE20102230C6C009DC8E5B88 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\timer_example\gcc
    Property(C): dirE41F8DE06F3FCC4A0A89401812E9B35A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\twi_sw_master_example
    Property(C): dir25A82E3A5306DC059769ACFF0DBC4A5F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\twi_sw_master_example\arm
    Property(C): dir71F7C30934943BEC02A066FF463D27F4 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\twi_sw_master_example\gcc
    Property(C): dir3913F725889BAB368C0C4A61E20BEC46 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\uart_example
    Property(C): dir377C1CADC4D1581DEC0246FB0D3C4840 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\uart_example\arm
    Property(C): dirA54AFF4C35B6FFC75952CD7C32E50FE4 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\uart_example\gcc
    Property(C): dirDCA7D6EA094BCC5E8A364725D7B566AD = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\uicr_config_example
    Property(C): dir8E55F8D6BEFC53A8EE98AF01FECD939E = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\uicr_config_example\arm
    Property(C): dirE5E558022897D265B7A7E5A88E4CE215 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10000\button_radio_example
    Property(C): dir7DD4C2813F5210942A3EE88473C160B0 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10000\button_radio_example\arm
    Property(C): dirE443263D9B1F4C8938ACC607A210FDA5 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10000\button_radio_example\gcc
    Property(C): dir76F3FAD72355671E443431C04ADF839B = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10000\led_radio_example
    Property(C): dirB7722498EEB002DE2F4E104FACB69B3C = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10000\led_radio_example\arm
    Property(C): dir2E6FD6C6E4283FFEC872596C9E3661E2 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10000\led_radio_example\gcc
    Property(C): dir8C2AC6590AAF1A7756A2954B7BAFEB5A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10000\uart_example
    Property(C): dirF12018FB11F55AE58E6D4E221DF5EFDB = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10000\uart_example\arm
    Property(C): dir26375B5340D100C140CE60C1FBBA9D6E = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10000\uart_example\gcc
    Property(C): dir9EB2A5B8D3E22ABCDED93B63202EB755 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10000\uicr_config_example
    Property(C): dirD9682843A20FDEED06FF0B062CB3553B = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10000\uicr_config_example\arm
    Property(C): dir007D94485A052117135DB2C605FD3AF0 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\ble\ble_app_hrs
    Property(C): dirE2C4C988DAE1F0DF311824F80F048459 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\ble\ble_app_hrs\arm
    Property(C): dir3909109D336BAFE8108B64FF8F991C82 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\ble\ble_app_proximity
    Property(C): dir1C2E6B4E58E58017CEDC906550D89E41 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\ble\ble_app_proximity\arm
    Property(C): dir88DF78D8684D4AA253FDEF4C17920FD6 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\blinky_example
    Property(C): dir595C0A0E956813CDABD924F3DDD7C660 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\blinky_example\arm
    Property(C): dir6896B2558352F7D7569F218580E87ECA = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\blinky_example\gcc
    Property(C): dir43DFC0A328BC63B2E21FB9634B0DB7F0 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\button_radio_example
    Property(C): dir952BF7DEE9E33FAF4322D9FD18A9B142 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\button_radio_example\arm
    Property(C): dirF3F545A34B90A2C6504E0225388C4357 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\button_radio_example\gcc
    Property(C): dir6C9034D38231F554ECD98299E6DA438A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\led_radio_example
    Property(C): dir3BEB771CA16838D9B62D7CA0533BA5B0 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\led_radio_example\arm
    Property(C): dir1974519A90DA1D2259D810B995D6823B = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\led_radio_example\gcc
    Property(C): dirF623C5CD7F1CBACA3BADD1EE1FB88570 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\uart_example
    Property(C): dir7D7314F1733E71B83CD050C5DA59B429 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\uart_example\arm
    Property(C): dir68C62BC398B9DCFDF21851196AF0B57D = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\uart_example\gcc
    Property(C): dir86D1527003D4A4B6EBC623681C993BA4 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\uicr_config_example
    Property(C): dir92F490053764A30C84DA84E1ABABC632 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\uicr_config_example\arm
    Property(C): dirB967F9FF38DB8A5040B9DF8B1CFC6110 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Include
    Property(C): dir4132214FBE7DA69DC3F947E253035689 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Include\app_common
    Property(C): dirC6A7670A8A0350939DEF0FFE0DD8D90B = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Include\ble
    Property(C): dir2F63F1A7F5CB77E2998D48802E8A3F25 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Include\ble\ble_services
    Property(C): dir1200B126DEF82A7FA65DDC0B3D563D33 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Include\ble\rpc
    Property(C): dir4C0C0DF44DF59D9225D42ACC5E3608EA = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Include\ble\softdevice
    Property(C): dirCC96297FF9C4674424D3496405704084 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Include\boards
    Property(C): dirAF9BA19F71FC60C41FE87C2CC41E701A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Include\esb
    Property(C): dirAA2E5D78C8AA290EC3266CFEDEA2491A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Include\ext_sensors
    Property(C): dir2B7009EF732C530BA7362593157505BB = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Include\gcc
    Property(C): dir82B3445007D12D5B629A090DA8ABC003 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Include\gzll
    Property(C): dirB99DF22B73242528BD414B4CBD626BE8 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Include\gzp
    Property(C): dirFB41ECC6FEC8B64C23AB5A35C1E8F585 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Lib\esb\arm
    Property(C): dir8A8EDFF70E11209A3622882E0DFD9687 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Lib\esb\gcc
    Property(C): dirDCDAA0E45383EA60D70B4C294D85C9FF = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Lib\gzll\arm
    Property(C): dirFD6C8077946EBB14C569A7B915E39EC9 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Lib\gzll\gcc
    Property(C): dir52F50175FFFDC54DF2D54288ADED3E7C = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source
    Property(C): dirA8C9C9731E310D31A48E3FEA798598AA = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\app_common
    Property(C): dir722B0BE2AFCA85265A7F273DA0AA5469 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\ble
    Property(C): dirA0EA4684FD384C3282837F1E36305B9E = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\ble\ble_services
    Property(C): dir8608353A4E8F5E501282707C2D45D980 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\ble\rpc
    Property(C): dir323F4D3C8FBDDBF99652A9FD760E17AF = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\console
    Property(C): dir5355DC3E47F5C0C5569EFB5008973E0A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\ext_sensors\adns2080
    Property(C): dir87D679FF3D67FED415BE4792087325CD = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\ext_sensors\cherry8x16
    Property(C): dir9685A35F20B140E3C2C6B12A4DDF03D6 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\ext_sensors\ds1624
    Property(C): dirB3604ABF6C78851AA6711498C961B137 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\ext_sensors\mpu6050
    Property(C): dir9E2B27E677989BBA668E8D5BFBB8A4D3 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\ext_sensors\nRF6350
    Property(C): dir4D183176417E483158B0704B4DFFF24A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\ext_sensors\sdio
    Property(C): dirD93C325A008130E8E7EA7E364F015B03 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\ext_sensors\synaptics_touchpad
    Property(C): dirDF4207C73FC38D665DE681C9FF006497 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\gzp
    Property(C): dir8E4E9179964CBBB2650E821D06926D23 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\nrf_assert
    Property(C): dir8A7FCCE3EDBC1DB02CF34EF8C6699C58 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\nrf_delay
    Property(C): dir30D8581C691E3449615E5CD14912320F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\nrf_ecb
    Property(C): dir81A5B8FDF7BDBEB621D842F344AA5850 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\nrf_nvmc
    Property(C): dir1742F0786182194C917CB6761ADB67CA = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\simple_uart
    Property(C): dir2B29AFBBBC75C391C6CC10C2CFFA3481 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\spi_master
    Property(C): dirF903EC5A8529F557DF73D13CDBDBAB73 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\templates
    Property(C): dirA36493DD90BEF18F99B18C85CA83AEA9 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\templates\arm
    Property(C): dir0165D04C79C323ED8E7E49C1339747D7 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\templates\gcc
    Property(C): dir8AE222DDCC910D9C14C6C1E4EE7A65D0 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\templates\iar
    Property(C): dir58B5F0CB235597BFDA65CAD41DCA4B41 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\twi_master
    Property(C): dir253328A2D2F7876C4ED835A96037886A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\SVD
    Property(C): WixUIRMOption = UseRM Property(C): DIR.Menu.Company = C:\Documents and Settings\Jordi\Menú Inicio\Programas\Nordic Semiconductor
    Property(C): ROOTDRIVE = C:
    Property(C): nrf51422_KeilDeviceFolder = Device\Nordic\nrf51422
    Property(C): nrf51422_KeilExamplesFolder = Device\Nordic\nrf51422\Board
    Property(C): nrf51422_KeilDeviceFolderWithBackslash = \Device\Nordic\nrf51422
    Property(C): nrf51822_KeilDeviceFolder = Device\Nordic\nrf51822
    Property(C): nrf51822_KeilExamplesFolder = Device\Nordic\nrf51822\Board
    Property(C): nrf51822_KeilDeviceFolderWithBackslash = \Device\Nordic\nrf51822
    Property(C): WindowsFolder = C:\WINDOWS
    Property(C): nrf51422_CustomDeviceFolder = Nordic\nrf51422
    Property(C): nrf51422_CustomExamplesFolder = Nordic\nrf51422\Board
    Property(C): nrf51822_CustomDeviceFolder = Nordic\nrf51822
    Property(C): nrf51822_CustomExamplesFolder = Nordic\nrf51822\Board
    Property(C): SourceDir = C:\Nordic
    Property(C): DIR.ProgramFiles.nrf51.bin = C:\Archivos de programa\Nordic Semiconductor\nrf51\bin
    Property(C): DIR.ProgramFiles.nrf51 = C:\Archivos de programa\Nordic Semiconductor\nrf51
    Property(C): DIR.ProgramFiles.Nordic = C:\Archivos de programa\Nordic Semiconductor
    Property(C): ProgramFilesFolder = C:\Archivos de programa
    Property(C): ProgramMenuFolder = C:\Documents and Settings\Jordi\Menú Inicio\Programas
    Property(C): DIR.Custom.SoftwareArchive = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827
    Property(C): CONFIGURABLE_CUSTOM_SOFTWAREARCHIVE_DIR = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827
    Property(C): DIR.NORDIC = C:\Nordic Semiconductor
    Property(C): WINDOWSVOLUME = C:
    Property(C): Dir.Keil.Device = C:\Device
    Property(C): Dir.ProgramFiles.nrf51 = C:\Archivos de programa\Nordic Semiconductor\nrf51
    Property(C): Dir.ProgramFiles.Nordic = C:\Archivos de programa\Nordic Semiconductor
    Property(C): dirCC75806F7A400526CD5F925CE1864341 = C:\Device\Nordic
    Property(C): dir22266EDA12734C2112D1D5403332E8F8 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_comb_spd_cad
    Property(C): dir0B8ED1BEA6D7640246FA0EBCF2A1EA8B = C:\Device\Nordic\nrf51422\Board\nrf6310\ant
    Property(C): dirB805361C238483083F39AE80DC5C15CE = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_pwr
    Property(C): dirFDDC5378C78DA917190B06702CE4EDE5 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_broadcast
    Property(C): dir3ED5492C44594FD1D8725BD10002AA66 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_fs
    Property(C): dir7BF5DC798F47B379340C4475373313F6 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm
    Property(C): dirD0AD241D9D2E765FD4C6BA842A89C489 = C:\Device\Nordic\nrf51422\Board\nrf6310\ant\ant_sdm
    Property(C): dir57924EF5E705E2F690BDC6C7C1628931 = C:\Device\Nordic\nrf51422\Board\nrf6310
    Property(C): dirA379DC8C48BB4300B6A3334756DCE067 = C:\Device\Nordic\nrf51422\Board\nrf6310\ext_sensors
    Property(C): dir4EA7AC36A8A853A088BE29EDF169498C = C:\Device\Nordic\nrf51422\Board
    Property(C): dirF846AA093617207B7D7BAFF043303749 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_comb_spd_cad
    Property(C): dir5B7E4EA8DB4DBFE8DFA34D518E6D13C4 = C:\Device\Nordic\nrf51422\Board\pca10003\ant
    Property(C): dir8FEB15D67FA74727E4A76CB97D6F2205 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_pwr
    Property(C): dirC877BC22093667D70CBB69A9B0D0DBD2 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_broadcast
    Property(C): dirDB4F373C6E186C2F0DE3D156EAC67388 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_fs
    Property(C): dirBA04EB3CC837DFEBA6FCC22C63BEB1AA = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_hrm
    Property(C): dirB98D51F5BCE7FEF00B6913C6C11D49C0 = C:\Device\Nordic\nrf51422\Board\pca10003\ant\ant_sdm
    Property(C): dir8A1D6D9610BBB44F79EE9689495E9397 = C:\Device\Nordic\nrf51422\Board\pca10003
    Property(C): dirC36CBC33E8E4F0DEDD004EDD12D94DAA = C:\Device\Nordic\nrf51422
    Property(C): dir81E067C21C88E0400775364DE5968ABC = C:\Device\Nordic\nrf51422\Include\ant
    Property(C): dir4A28405BC3300E2FD307E61C9362F04E = C:\Device\Nordic\nrf51422\Source\ext_sensors
    Property(C): dirA61BBA5F1649F12E256A7CD9B91F1E7C = C:\Device\Nordic\nrf51822\Board\nrf6310\ble
    Property(C): dir146379DE61BC1324DF6EC4324F7DBE93 = C:\Device\Nordic\nrf51822\Board\nrf6310
    Property(C): dirBBE03EE5DC4E607EC8014A8CF23D83C5 = C:\Device\Nordic\nrf51822\Board\nrf6310\ble_s110_serialization
    Property(C): dir8616A70AE598738EFF661BBA951FD588 = C:\Device\Nordic\nrf51822\Board\nrf6310\device_firmware_updates
    Property(C): dir7606CECCE27F8B649929EE0D4FAF0CE8 = C:\Device\Nordic\nrf51822\Board\nrf6310\device_firmware_updates\experimental
    Property(C): dir575F7C428C5CD76924CC12F0F29C0FD5 = C:\Device\Nordic\nrf51822\Board\nrf6310\esb
    Property(C): dirCA1C53EF00A038BCA1FA78727053CA31 = C:\Device\Nordic\nrf51822\Board\nrf6310\ext_sensors
    Property(C): dirFDEF85800DFF394DB9F5CAF31F795A87 = C:\Device\Nordic\nrf51822\Board\nrf6310\gzll
    Property(C): dir8E9D2F6D155A3EFF0D330F2EDFEF9681 = C:\Device\Nordic\nrf51822\Board
    Property(C): dir4ECE9155B8F14E9E07811BF471D05911 = C:\Device\Nordic\nrf51822\Board\pca10000
    Property(C): dirFC950A82B3D56D4928762B95C3D137B0 = C:\Device\Nordic\nrf51822\Board\pca10001\ble
    Property(C): dirF776D02987302AC3D92703669FF85292 = C:\Device\Nordic\nrf51822\Board\pca10001
    Property(C): dirF7878C096D9A30B554D971A7CB3A029D = C:\Device\Nordic\nrf51822
    Property(C): dir9AB2F66647DE7302EA5B18F9BEF7B039 = C:\Device\Nordic\nrf51822\Lib\esb
    Property(C): dir440AFDB9C331D99DC534598A24FDAF2A = C:\Device\Nordic\nrf51822\Lib
    Property(C): dir14FDBA87659EB7F291A26121E8DB2E13 = C:\Device\Nordic\nrf51822\Lib\gzll
    Property(C): dir6A35309EDAC9756FA3D27F84B1A8D671 = C:\Device\Nordic\nrf51822\Source\ext_sensors
    Property(C): Dir.Keil.ARM = C:\ARM
    Property(C): Dir.Keil.SFD.Nordic = C:\ARM\SFD\Nordic
    Property(C): Dir.Keil.SFD = C:\ARM\SFD
    Property(C): dirD0FE92F465097108E112784A4B52AFA1 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic
    Property(C): dir3443C0EDE51CBC2EFD8511D1CF233AFB = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_comb_spd_cad
    Property(C): dirB2BAFBB51A1A33163286792828E836D4 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant
    Property(C): dirA703457F26C3ABD0008F11F45611639B = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_bicycle_pwr
    Property(C): dir04904D12037EDC0B7270D7DAA3E39EF3 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_broadcast
    Property(C): dir8601C17D158A21D50BC74568560D9511 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_fs
    Property(C): dir1F4CB384825BAA6A1E19A9532EF17F30 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_hrm
    Property(C): dirAA69E8AC178F964F6871564EDE39379B = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ant\ant_sdm
    Property(C): dir5E78C0AA01EBA0BB82B1A62C8554BB80 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310
    Property(C): dir9EECBED7CD4D1C975C40911966FBFD5C = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\nrf6310\ext_sensors
    Property(C): dirABEC501513CD4C4B28109A8B7C479FBB = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board
    Property(C): dir0ECC65036E6A00B053670472D773CA25 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_comb_spd_cad
    Property(C): dirA5C31A5AD15399ACB3A3A133E9ECF452 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant
    Property(C): dir74491020E87CC30039287DA9180AB573 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_bicycle_pwr
    Property(C): dir71DE12DBAEEB2B9CA4D77BCC8055920F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_broadcast
    Property(C): dir737D7373CD6DE3BABE3FB3294CB60964 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_fs
    Property(C): dir8C74E504DCDFF10EDBEC35E50E1ECA83 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_hrm
    Property(C): dirC2FCFFCA507A71400DFF295A3CE8DE32 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003\ant\ant_sdm
    Property(C): dirF84A960BC8FF56B80C9224DE25610196 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Board\pca10003
    Property(C): dir3E039C314FC18254B20A714E79732A29 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422
    Property(C): dir8827E609BBF67FC06BE0AFBE009F122B = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Include\ant
    Property(C): dir532069F006D6781DFF5E42D5F911CF17 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51422\Source\ext_sensors
    Property(C): dir9148F14E013439A72CF8981B47B2BFC1 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble
    Property(C): dirE328CB7D619E4271444A2D3BD8C21C90 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310
    Property(C): dir43EBAD87E4FDB28020558F4E00FA1F9A = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ble_s110_serialization
    Property(C): dir8BAE3CE2EADD2A8FC8B0A65849E4E050 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\device_firmware_updates
    Property(C): dirC623CC9EC14B2C70701C4B84D21637E7 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\device_firmware_updates\experimental
    Property(C): dirA8D1C1D128912A48BF2ED075A4AACC94 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\esb
    Property(C): dirD3D40E3C87C29891E49CDD252789116C = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\ext_sensors
    Property(C): dirF74B073E7ADA2DE41ED82A740D804814 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\nrf6310\gzll
    Property(C): dir6FCC86B2D6C5724014F789DED603A96F = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board
    Property(C): dir140FFF7242A87887670F9612AD68C115 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10000
    Property(C): dirBB10FD7B62C80E4BAE37B9CF8C1312D7 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001\ble
    Property(C): dir6BB2CB11E5B1A6C8452136F7D0C72195 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Board\pca10001
    Property(C): dir6AA611D399A8D868FE5457FD656E9CCF = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822
    Property(C): dir27E8C1CA5D073D4CF9740D0EA7E87505 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Lib\esb
    Property(C): dirE248E6F61A8F9935B0305867E80A3558 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Lib
    Property(C): dir48008EF22BA1FF2B152F53A0D27F3471 = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Lib\gzll
    Property(C): dir6C88C09B773CA014D3E121DB690C053C = C:\Nordic Semiconductor\nRF51 SDK_v4.4.1.31827\Nordic\nrf51822\Source\ext_sensors
    Property(C): Manufacturer = Nordic Semiconductor Property(C): ProductCode = {6911FA46-635F-4F43-982E-541B30238E41} Property(C): ProductLanguage = 1033 Property(C): ProductName = nRF51 SDK Property(C): ProductVersion = 4.4.1.31827 Property(C): ARPPRODUCTICON = Nordic_N_Hi.ico Property(C): DefaultUIFont = WixUI_Font_Normal Property(C): WixUI_Mode = FeatureTree Property(C): ErrorDialog = ErrorDlg Property(C): SecureCustomProperties = WIX_UPGRADE_DETECTED Property(C): MsiLogFileLocation = C:\Nordic\logfile.txt Property(C): PackageCode = {DB49B65C-56CA-4918-BCA1-DE18B4A323F8} Property(C): ProductState = -1 Property(C): PackagecodeChanging = 1 Property(C): CURRENTDIRECTORY = C:\Nordic Property(C): CLIENTUILEVEL = 0 Property(C): CLIENTPROCESSID = 9508 Property(C): MsiSystemRebootPending = 1 Property(C): VersionDatabase = 300 Property(C): VersionMsi = 4.05 Property(C): VersionNT = 501 Property(C): WindowsBuild = 2600 Property(C): ServicePackLevel = 3 Property(C): ServicePackLevelMinor = 0 Property(C): MsiNTProductType = 1 Property(C): WindowsVolume = C:
    Property(C): SystemFolder = C:\WINDOWS\system32
    Property(C): System16Folder = C:\WINDOWS\system
    Property(C): RemoteAdminTS = 1 Property(C): TempFolder = C:\DOCUME~1\Jordi\CONFIG~1\Temp
    Property(C): CommonFilesFolder = C:\Archivos de programa\Archivos comunes
    Property(C): AppDataFolder = C:\Documents and Settings\Jordi\Datos de programa
    Property(C): FavoritesFolder = C:\Documents and Settings\Jordi\Favoritos
    Property(C): NetHoodFolder = C:\Documents and Settings\Jordi\Entorno de red
    Property(C): PersonalFolder = C:\Documents and Settings\Jordi\Mis documentos
    Property(C): PrintHoodFolder = C:\Documents and Settings\Jordi\Impresoras
    Property(C): RecentFolder = C:\Documents and Settings\Jordi\Reciente
    Property(C): SendToFolder = C:\Documents and Settings\Jordi\SendTo
    Property(C): TemplateFolder = C:\Documents and Settings\Jordi\Plantillas
    Property(C): CommonAppDataFolder = C:\Documents and Settings\All Users\Datos de programa
    Property(C): LocalAppDataFolder = C:\Documents and Settings\Jordi\Configuración local\Datos de programa
    Property(C): MyPicturesFolder = C:\Documents and Settings\Jordi\Mis documentos\Mis imágenes
    Property(C): AdminToolsFolder = C:\Documents and Settings\Jordi\Menú Inicio\Programas\Herramientas administrativas
    Property(C): StartupFolder = C:\Documents and Settings\Jordi\Menú Inicio\Programas\Inicio
    Property(C): StartMenuFolder = C:\Documents and Settings\Jordi\Menú Inicio
    Property(C): DesktopFolder = C:\Documents and Settings\Jordi\Escritorio
    Property(C): FontsFolder = C:\WINDOWS\Fonts
    Property(C): GPTSupport = 1 Property(C): OLEAdvtSupport = 1 Property(C): ShellAdvtSupport = 1 Property(C): Intel = 16 Property(C): PhysicalMemory = 3327 Property(C): VirtualMemory = 2395 Property(C): AdminUser = 1 Property(C): LogonUser = Jordi Property(C): UserSID = S-1-5-21-1957994488-562591055-725345543-1003 Property(C): UserLanguageID = 3082 Property(C): ComputerName = SOLID-01 Property(C): SystemLanguageID = 3082 Property(C): ScreenX = 1680 Property(C): ScreenY = 1050 Property(C): CaptionHeight = 26 Property(C): BorderTop = 1 Property(C): BorderSide = 1 Property(C): TextHeight = 16 Property(C): TextInternalLeading = 3 Property(C): ColorBits = 32 Property(C): TTCSupport = 1 Property(C): Time = 10:53:43 Property(C): Date = 01/10/2013 Property(C): MsiNetAssemblySupport = 4.0.30319.1 Property(C): MsiWin32AssemblySupport = 5.1.2600.5512 Property(C): RedirectedDllSupport = 2 Property(C): Privileged = 1 Property(C): USERNAME = Jordi Property(C): COMPANYNAME = Solid Property(C): DATABASE = C:\DOCUME~1\Jordi\CONFIG~1\Temp\6236e77f.msi Property(C): OriginalDatabase = C:\Nordic\nrf51_sdk_v4_4_1_31827.msi Property(C): SOURCEDIR = C:\Nordic
    Property(C): VersionHandler = 4.05 Property(C): UILevel = 5 Property(C): ACTION = INSTALL Property(C): EXECUTEACTION = INSTALL Property(C): CostingComplete = 1 Property(C): OutOfDiskSpace = 0 Property(C): OutOfNoRbDiskSpace = 0 Property(C): PrimaryVolumeSpaceAvailable = 0 Property(C): PrimaryVolumeSpaceRequired = 0 Property(C): PrimaryVolumeSpaceRemaining = 0 Property(C): INSTALLLEVEL = 1 === Logging stopped: 01/10/2013 10:53:43 === MSI (c) (24:54) [10:53:43:269]: Product: nRF51 SDK -- Installation failed.
    MSI (c) (24:54) [10:53:43:284]: Windows Installer installed the product. Product Name: nRF51 SDK. Product Version: 4.4.1.31827. Product Language: 1033. Installation success or error status: 1603.
    Thank you
  • It seems you do not have Keil installed. Is that intentional? If you plan to use the SDK with Keil, you should make sure to install Keil first, and then the SDK.
    However, this shouldn't cause this error. Microsoft have some tips on what do to solve this problem here, which could be worth having a look on: http://support.microsoft.com/kb/834484
    I'd especially recommend you to make sure that you have administrator permissions when running this. If you run the installer from the command line, this can be done by making sure the Command Prompt window is run as Administrator.
  • Yes, the problem was that Keil is not installed.
    Thank you
1 2
