building background :
SDK : 15.0
Development Kit: nrf52832 DK
IDE: Keil C
Softdevice: S132
Problem Description:
When NUS is added to blinky project , I could find the UART service and characteristics on nRF_connect interface.
But , When I sent message to DK, there is something wrong....
Actions:
As title, I'd like to add NUS to ble_app_blinky. So, I took actions below :
1.Add ble_nus.c , include related paths and enable related sdk_configs.
2.Copy " part of " ble_app_uart / main.c code to blinky project.
Copy part is shown below:
Header file and define part:
#include "ble_nus.h" #include "app_uart.h" #include "app_util_platform.h" #include "ble_advertising.h" #include "nrf_uart.h" #if defined (UARTE_PRESENT) #include "nrf_uarte.h" #endif
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */ #define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */ #define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */ BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< Context for the Queued Write module.*/ //BLE_ADVERTISING_DEF(m_advertising); static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */ static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */ { {BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE} };
uart init / uart Handler / gatt handler / nus handler part:
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
* @param[in] p_evt Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
uint32_t err_code;
for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
do
err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
} while (err_code == NRF_ERROR_BUSY);
if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
while (app_uart_put('\n') == NRF_ERROR_BUSY);
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
/**@brief Function for handling app_uart events.
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
static uint8_t index = 0;
uint32_t err_code;
switch (p_event->evt_type)
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
do
if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) &&
(err_code != NRF_ERROR_NOT_FOUND) )
index = 0;
case APP_UART_FIFO_ERROR:
/**@brief Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
uint32_t err_code;
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
#if defined (UART_PRESENT)
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
service_init() part:
ret_code_t err_code;
ble_lbs_init_t init = {0};
//MEM ERR
// Initialize LBS.
// init.led_write_handler = led_write_handler;
// err_code = ble_lbs_init(&m_lbs, &init);
// APP_ERROR_CHECK(err_code);
/*UART PART*/
// Initialize NUS.
ble_nus_init_t nus_init;
/*UART PART END*/
Also, I set the NRF_SDH_BLE_GATT_MAX_MTU_SIZE to 247 , just like ble_app_uart project:
// <o> NRF_SDH_BLE_GATT_MAX_MTU_SIZE - Static maximum MTU size. #ifndef NRF_SDH_BLE_GATT_MAX_MTU_SIZE //#define NRF_SDH_BLE_GATT_MAX_MTU_SIZE 23 #define NRF_SDH_BLE_GATT_MAX_MTU_SIZE 247
I have surveyed on Nordic-devZone for a while, but got nothing.
I will be appreciate if someone could give me a hand .
UPDATE 2018/06/08 PM 9:00
I have tried using RTT viewer for recording logs. Here shows the result.
I sent "eee" strings to DK but only the first "e" showed up .
UPDATE 2018/06/09 PM 5:00
Uploaded my test project - ble_app_blinky_add_NUS.rar
