Can't read "accread" value without enabling reportpr event,
Hi, I have nrf52832 and using QDEC driver. In my application I want to use values accumulated in the acc/accread register for a time of the order of seconds. Since max value for REPORTPER register is 280 samples so for sample rate of 128uS, the time of reporting is around 280*128uS ~= 36mS. Which is too short for my application. And also on every REPORTPER event the acc register is cleared. So I disabled the REPORTPER event and started using nrf_drv_qdec_accumulators_read() function to read values of accread register in a while loop in main function. Following is the code I'm using.
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
uint32_t err_code;
err_code = NRF_LOG_INIT(NULL);
NRF_LOG_INFO("fmfbvzfmn");
NRF_LOG_FLUSH();
// Initialize hardware
nrf_drv_qdec_config_t p_config;
p_config.reportper = (nrf_qdec_reportper_t)NRF_QDEC_REPORTPER_DISABLED;
p_config.sampleper = (nrf_qdec_sampleper_t)QDEC_CONFIG_SAMPLEPER;
p_config.psela = QDEC_CONFIG_PIO_A;
p_config.pselb = QDEC_CONFIG_PIO_B;
p_config.pselled = QDEC_CONFIG_PIO_LED;
p_config.ledpre = QDEC_CONFIG_LEDPRE;
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
The result of this code is that mostly the value of "acc" variable is 0, and sometimes it gives 1. I'm unable to explain this behavior. I'm using following code to generate the Encoder signal.
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
void writePin1(bool val)
{ nrf_gpio_pin_write(30,(uint32_t)val);
nrf_gpio_pin_write(17,(uint32_t)val);
void writePin2(bool val)
{ nrf_gpio_pin_write(31,(uint32_t)val);
nrf_gpio_pin_write(19,(uint32_t)val);
uint32_t err_code;
nrf_gpio_cfg_output(17);
pin 17 and 19 are LEDs, while 30 and 31 are the signals connected to the other DK running the QDEC code.
Under same scenario, if I enable the REPORTPER event then the outputs are correct but they get reset at every REPORTPER event, which is the behaviour I don't want.
So how to read values from acc/accread registers without enabling the REPORTPER evnt ?
Also, I can see that the ACC register is 32-bit but in the datasheet it says that value range is -1024 to 1023. why does it mean ? the overflow occurs at -1024/1023 or at -2147483648/2147483647 ?
