Battery issue on nRF52840 PDK
If I connect supply from laptop using micro USB cable, battery on PDK also gets discharged?
Asking this because in the initial stages of testing PDK battery is working. After that I got to use power supply most of the times. I am surprised now that upon using battery chip is not running but working with external power supply(laptop).
Please let me know the reason.
Sridhar
  • Hello Jonnavittula,
      It is not optimal to have the battery in the board while connected to USB if you want to preserve the batteries life.
    Because of the diodes in the circuit the board will be powered by the source that has the highest voltage, which can be the battery.
    Most likely you have powered your board with the battery even if you have been connected with the USB.
