flashing problem with some nrf52832 shields using the DK-nrf52
Hello
i just bought my DK-nrf52 to move to BLE after playing few months with arduino. I have connected various nrf52832 shields from China (from Holyiot 17095, which is very small).
after learning the basics from Keil and your board. i finally compile and flashed correctly the blinky example using the s132.
first i have to report this has been a very long time consuming because i might not have found the community to help for that. is there any links that you might share from people doing simple tutorials? the one i have seen from you are very generic and doesnt go far enough for beginers like me.
saying so. i do have problem flashing more complexe example on my nrf52832, for instance the proximity_ble example compiles and is flashed on the device without any error on Keil. but no phone can detect this device?
i have also noticed, that sometimes, flashing from Keil is mentionning that the content is flashed successfully as well as the program is running, while (either on the DKnr52 board or the external devices, the former program is still running.
Sorry for asking all my questions in the same message. but i try to move fast because i noticed that the nrf52832 seems having a low distance of fonctionning (few meters) the proximity app on my phone is mentionning that the signal is lost after few meters. Is that normal? if so, i might have to come back to my arduino and HC06 Bluetooth. I hope i misunderstood something about that.
thanks a lot
Philoppe
  • Hi Philippe,
    Please use the app referred to in the example documentation.
    On the Android side you can either use "nRF Connect" or "nRF Toolbox".
    On the PC side you can use your prefered serial terminal. (I like to use "termite")
  • Hi Martin, this is the kind of information that are very helpful for a beginner. thanks. I use termite and configure as mentionned on the example documentation. i connected with nRF Connect or nRF Toolbox on my android phone.  It connects perfectly. I have differencies with the documentation though. if write 30 31 32 33 ... either in nRF Connect or nRF Toolbox, i see the same text appearing in Termite (running on my PC). it is said i should read 123 ...
    Then, the text i wrote into termite never appeared on my nRFconnect or nRF Toolbox. is there a specific set up to get the communication bi-directional? thank you
    One more question: (on the top of  all above working perfectly: bi-directional text), the only thing i would need to do is a similar app to the nRF UARTv2.0 for Android and IOS.. Does it exist a documentation on this app? What IDE is used to write such an app? is there  a source code somewhere or information?
    Sorry for so many questions. I wish there was low level video tutorial for people like me. ;-(
  • Hi Philippe,
    Your experience is expected. The nRF Connect app has been updated after the "testing" text in the documentation.
    Before you could send hex, but now if you send "01234" you would get "01234" on the other side. So the documentation is outdated.
    If you swipe right, you should get up the "terminal" log window in 'nrf Connect' app, so you can see what you send from your computer to the device.
    (so it works both ways)
    similar to this:
    For your last question:
    You have the UART app in the nRF Toolbox app which you can use instead of the deprecated "nRF UARTv2.0".
    The source code and documentation can be found here:
  • Dear Martin
    Thanks again for your help.
    I am glad if my questions have been helpful to point out something to correct into the documentation.
    Regarding the two ways communication. Unfortunately it doesnt look like working on my side . please find three pictures here:
    1/ the termite's terminal showing the type of message send from the phone and message sent from my computer
    2/   2 screenshots regarding the information available on my phone.
    Thanks for the links regarding the code from the app. this will be very useful.
    Warm regards
    Philippe
  • oh sorry i forgot to comment your advise :"You have the UART app in the nRF Toolbox app which you can use instead of the deprecated "nRF UARTv2.0"."
    actually i do have the UART app in the nRF Toolbox app, but it really doesnt look like a terminal
