I am using SDK 15 & Softdevice 6,
I am using NRF52840.
I have merged the USB CDC into a multi-link example.
I confirmed that it worked, and the project was successful.
But there was one problem.
I need debugging and I have activated the log as below.
I have disabled the logs and built and uploaded the logs for the clean operation of the program as below.
However, if you disable the log, USB CDC PORT will not be displayed. I am not sure if an error occurred during USB INIT.
The main sources are:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
static uint8_t rgLeRecvBuf[BT_RECVBUF_SIZE];
static bool bFirstScan = false;
static uint8_t u8LeRecvBufLen;
static int idx;
// CDC Code Start
#if CDC_Code
/* not use gpio -> Output Low setup */
not_used_gpio_init();
UICR_Init(); //jwcheon 1.8V -> 3.0V change
ret_code_t ret;
static const app_usbd_config_t usbd_config = {
.ev_state_proc = usbd_user_ev_handler
ret = NRF_LOG_INIT(NULL);
APP_ERROR_CHECK(ret);
ret = nrf_drv_clock_init();
Can you give me a clue as to why it does not work?
Thanks!
