Analog data on Scan Rsp
Hi, Nordic.
I'm developing multiple peripheral and a central. Central is only scanning and Peripherals are only advertising.
I got Adv data and Scan rsp data successfully.
But, I have to get  some analog data like sensor. So, I have used rand() function and the result value put in scan rsp data.
However, this value does not change when read from the central.
I think that when the peripheral performs an advertisement, it sends an initial random value only once, and then continues to transmit that had setted format.
So, how can i do that analog value(random value) send to Central. should I use sd_radio_notification_cfg_set ??
If i have to use it, please let me know how to use it. If not, is there what kind of solution?
I using
  • SDK14.2
  • Central : ble_app_uart_c / peripheral : ble_app_beacon
  • PCA10056 (nRF52840)
I will wait for your answer. Thanks.
    To change the data in the advertising data or scan respone, it must be re-encoded. Are you calling these functions multiple times? I suspect you are just calling them the first time you start advertising.
    let's say you can call sd_ble_gap_adv_start(...) with a short advertising timeout. When you get the BLE_GAP_EVT_TIMEOUT from the softdevice (remember to check if the source is advertising timeout BLE_GAP_TIMEOUT_SRC_ADVERTISING) you can do ble_advdata_set(..) and sd_ble_gap_adv_start(...) again with a new random value.
  • Thanks for your answer Havard.
    My peripheral is advertising and there is no timeout. m_adv_params.timeout = 0;
    what you said, If i want to get analog data every 1 second, the timeout must be 1 sec and re advertising and encode every second???
    How can i do that? It should be performed peripheral? or does it have to command the peripheral from the central??
  • yes if you want to get analog data every 1 second, the timeout must be 1 sec and re-advertising and encode every second.
    It must be performed on the peripheral.
    You must act upon the events coming from the softdevice (BLE_GAP_EVT_TIMEOUT)
    To do this you must add a softdevice handler observer in the ble_stack_init (beacon does not do this but you can look at other peripheral examples and notice how they add it).
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    Now you can add ble_evt_handler()
            case BLE_GAP_EVT_TIMEOUT:
                //start advertising.
  • Thank you very much.
    It is very helpful for me. Thanks again
  • You are very welcome, good luck with your project :)
