Thread border router 1.0.0
I am following the Thread Border Router example and have successfully loaded RaspPi_OT_Border_Router_Demo_v1.0.0-1.alpha.img onto the RaspberryPi 3B+.
I have loaded the NCP example onto a Nordic Semi nRF52840 development board, and connected it the the Raspberry Pi.  I have loaded the CLI example onto another development board.
I can successfully ping between the two Thread nodes, but not outside to my PC or to google as described in the example.
I am using nRF_SDK_for_Thread_and_Zigbee_v1.0.0
Rasp Pi:  border_router.conf
# Thread Network Configuration
thread_network_key="00112233445566778899AABBCCDDEEFF"
thread_channel="11"
thread_panid="0xABCD"
thread_xpanid="DEAD00BEEF00CAFE"
thread_network_name="NordicOpenThread"
thread_pskc="E00F739803E92CB42DAA7CCE1D2A394D"
thread_on_mesh_prefix="fd11:22::"
Rasp Pi: ifconfig:
pi@raspberrypi:/etc $ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.72  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 2600:XXXX:XXXX:96c0:ba27:ebff:fe94:7933  prefixlen 64  scopeid 0x0<global>
        inet6 fe80::ba27:ebff:fe94:7933  prefixlen 64  scopeid 0x20<link>
        inet6 2600:xxxx:xxxx:96c0::5c5  prefixlen 128  scopeid 0x0<global>
        ether b8:27:eb:94:79:33  txqueuelen 1000  (Ethernet)
        RX packets 6104  bytes 545078 (532.3 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 5457  bytes 1174736 (1.1 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
nat64: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1500
        inet 192.168.255.1  netmask 255.255.255.255  destination 192.168.255.1
        inet6 fdaa:bb:1::1  prefixlen 128  scopeid 0x0<global>
        inet6 fe80::73b8:21d2:47dc:cf7  prefixlen 64  scopeid 0x20<link>
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 500  (UNSPEC)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 4  bytes 304 (304.0 B)
wpan0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1280
        inet6 fd11:22::540c:ed30:4494:6a9c  prefixlen 64  scopeid 0x0<global>
        inet6 fe80::540c:ed30:4494:6a9c  prefixlen 64  scopeid 0x20<link>
        inet6 fe80::3bdd:44c5:d59c:102e  prefixlen 64  scopeid 0x20<link>
        inet6 fdde:ad00:beef:0:a610:e28d:369:454e  prefixlen 64  scopeid 0x0<global>
        inet6 2600:XXXX:XXXX:96c9:1000::1  prefixlen 68  scopeid 0x0<global>
        RX packets 1  bytes 56 (56.0 B)
        TX packets 10  bytes 1371 (1.3 KiB)
CLI node:
>ipaddr
2600:XXXX:XXXX:96c9:ee61:43f6:eb74:b3e8
fd11:22:0:0:29e0:308e:1b41:a566
fdde:ad00:beef:0:0:ff:fe00:fc00
fdde:ad00:beef:0:0:ff:fe00:6800
fe80:0:0:0:8803:5bb9:52c6:1591
fdde:add0:beef:0:35da:1ab0:72b9:2919
The suggested command on the CLI node to test
>ping 64:ff9b::0808:0808
returns nothing
The following (and many other combinations) also return nothing:
>ping 2600::XXXX:XXXX:96c9::0808:0808
>ping fdde:ad00:beef::0808:0808
But this one succeeds
>ping fd11:22::540c:ed30:4494:6a9c
returns "8 bytes from fd11:22:0:0:540c:ed30:4494:6a9c: icmp_seq=5 hlim=64 time=74ms"
The ipv6 prefixes do not seem to match on the Raspberry Pi and the CLI node:
RaspPi eth0:      inet6 2600::XXXX:XXXX:96c0:ba27:ebff:fe94:7933  prefixlen 64  scopeid 0x0<global>
RaspPi wpan0:  inet6 2600::XXXX:XXXX:96c9:1000::1 prefixlen 68 scopeid 0x0<global>
Is this correct?  If not, how to fix it?
Mary
  • Hi Mary,
    At the first glance it looks fine.
    Let's start from checking connectivity at the RPi.
    1. Can you 'ping 8.8.8.8' from the Raspberry?
    I see that you have global IPv6 connectivity.
    2. Can you 'ping6 2001:4860:4860::8888' from the Raspberry?
    3. In case of CLI we can also try 'ping 2001:4860:4860::8888'?
    Please let me know what is output of these three commands.
    What provides network connection to the Raspberry? Is it the same as for your PC?
    Kind Regards,
    Piotr Szkotak
  • 1.  Yes, I can ping 8.8.8.8 from Raspberry Pi
    pi@raspberrypi:~ $ ping 8.8.8.8
    PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
    64 bytes from 8.8.8.8: icmp_seq=1 ttl=58 time=31.3 ms
    64 bytes from 8.8.8.8: icmp_seq=2 ttl=58 time=32.3 ms
    64 bytes from 8.8.8.8: icmp_seq=3 ttl=58 time=36.1 ms
    64 bytes from 8.8.8.8: icmp_seq=4 ttl=58 time=30.5 ms
    2. Yes, I can ping6 from Raspberry Pi
    pi@raspberrypi:~ $ ping6 2001:4860:4860::8888
    PING 2001:4860:4860::8888(2001:4860:4860::8888) 56 data bytes
    64 bytes from 2001:4860:4860::8888: icmp_seq=1 ttl=58 time=31.5 ms
    64 bytes from 2001:4860:4860::8888: icmp_seq=2 ttl=58 time=32.3 ms
    64 bytes from 2001:4860:4860::8888: icmp_seq=3 ttl=58 time=30.5 ms
    64 bytes from 2001:4860:4860::8888: icmp_seq=4 ttl=58 time=31.6 ms
    3. ping from CLI returned nothing
    Raspberry Pi is connected to our office network via Ethernet cable, through a switch to our router.
    Raspberry Pi network configuration as reported by the router:
    My PC is connected in similar fashion, though the same switch to the same router.
    Mary
  • OK, just to confirm.
    You are able to ping from the CLI address returned by 'sudo wpanctl getprop IPv6:MeshLocalAddress' on the Raspberry, right?
    Are you able to 'ping 2600:xxxx:xxxx:xxxx::5c5' from the CLI?
    While performing these tests it would be good to sniff a bit on wpan0 and eth0 on the Raspberry.
    'sudo tcpdump -i wpan0 ip6' will show you traffic if packets are correctly passed from the NCP to the Raspberry.
    It may be worth to reflash all boards with the --chiperase option to make sure that no persistent data stayed on flash as a last resort.
    Piotr
  • On the CLI:
    > ping fdde:ad00:beef:0:a610:e28d:369:454e
    > 8 bytes from fdde:ad00:beef:0:a610:e28d:369:454e: icmp_seq=1 hlim=64 time=33ms
    > ping 2600:xxxx:xxxx:96c0::5c5
    pi@raspberrypi:~ $ sudo tcpdump -i wpan0 ip6
    sudo: tcpdump: command not found
    I reflashed both the CLI and NCP projects. Same results.
    How do I get tcpdump?
  • sudo apt-get update && sudo apt-get install tcpdump
    We see that packet does not even reach the eth0 interface, that is interesting.
