Thread border router 1.0.0
I am following the Thread Border Router example and have successfully loaded RaspPi_OT_Border_Router_Demo_v1.0.0-1.alpha.img onto the RaspberryPi 3B+.
I have loaded the NCP example onto a Nordic Semi nRF52840 development board, and connected it the the Raspberry Pi.  I have loaded the CLI example onto another development board.
I can successfully ping between the two Thread nodes, but not outside to my PC or to google as described in the example.
I am using nRF_SDK_for_Thread_and_Zigbee_v1.0.0
Rasp Pi:  border_router.conf
# Thread Network Configuration
thread_network_key="00112233445566778899AABBCCDDEEFF"
thread_channel="11"
thread_panid="0xABCD"
thread_xpanid="DEAD00BEEF00CAFE"
thread_network_name="NordicOpenThread"
thread_pskc="E00F739803E92CB42DAA7CCE1D2A394D"
thread_on_mesh_prefix="fd11:22::"
Rasp Pi: ifconfig:
pi@raspberrypi:/etc $ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.72  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 2600:XXXX:XXXX:96c0:ba27:ebff:fe94:7933  prefixlen 64  scopeid 0x0<global>
        inet6 fe80::ba27:ebff:fe94:7933  prefixlen 64  scopeid 0x20<link>
        inet6 2600:xxxx:xxxx:96c0::5c5  prefixlen 128  scopeid 0x0<global>
        ether b8:27:eb:94:79:33  txqueuelen 1000  (Ethernet)
        RX packets 6104  bytes 545078 (532.3 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 5457  bytes 1174736 (1.1 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
nat64: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1500
        inet 192.168.255.1  netmask 255.255.255.255  destination 192.168.255.1
        inet6 fdaa:bb:1::1  prefixlen 128  scopeid 0x0<global>
        inet6 fe80::73b8:21d2:47dc:cf7  prefixlen 64  scopeid 0x20<link>
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 500  (UNSPEC)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 4  bytes 304 (304.0 B)
wpan0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1280
        inet6 fd11:22::540c:ed30:4494:6a9c  prefixlen 64  scopeid 0x0<global>
        inet6 fe80::540c:ed30:4494:6a9c  prefixlen 64  scopeid 0x20<link>
        inet6 fe80::3bdd:44c5:d59c:102e  prefixlen 64  scopeid 0x20<link>
        inet6 fdde:ad00:beef:0:a610:e28d:369:454e  prefixlen 64  scopeid 0x0<global>
        inet6 2600:XXXX:XXXX:96c9:1000::1  prefixlen 68  scopeid 0x0<global>
        RX packets 1  bytes 56 (56.0 B)
        TX packets 10  bytes 1371 (1.3 KiB)
CLI node:
>ipaddr
2600:XXXX:XXXX:96c9:ee61:43f6:eb74:b3e8
fd11:22:0:0:29e0:308e:1b41:a566
fdde:ad00:beef:0:0:ff:fe00:fc00
fdde:ad00:beef:0:0:ff:fe00:6800
fe80:0:0:0:8803:5bb9:52c6:1591
fdde:add0:beef:0:35da:1ab0:72b9:2919
The suggested command on the CLI node to test
>ping 64:ff9b::0808:0808
returns nothing
The following (and many other combinations) also return nothing:
>ping 2600::XXXX:XXXX:96c9::0808:0808
>ping fdde:ad00:beef::0808:0808
But this one succeeds
>ping fd11:22::540c:ed30:4494:6a9c
returns "8 bytes from fd11:22:0:0:540c:ed30:4494:6a9c: icmp_seq=5 hlim=64 time=74ms"
The ipv6 prefixes do not seem to match on the Raspberry Pi and the CLI node:
RaspPi eth0:      inet6 2600::XXXX:XXXX:96c0:ba27:ebff:fe94:7933  prefixlen 64  scopeid 0x0<global>
RaspPi wpan0:  inet6 2600::XXXX:XXXX:96c9:1000::1 prefixlen 68 scopeid 0x0<global>
Is this correct?  If not, how to fix it?
Mary
  • 1. RaspPi
    pi@raspberrypi:~ $ ip -6 route
    64:ff9b::/96 dev nat64 metric 1024  pref medium
    2600:xxxx:xxxx:96c0::/64 dev eth0 proto kernel metric 256  expires 1209485sec pref medium
    2600:xxxx:xxxx:96c9:1000::/68 dev wpan0 proto kernel metric 204  pref medium
    unreachable 2600:xxxx:xxxx:96c9::/64 dev lo metric 201  error -113 pref medium
    fd11:22::/64 dev wpan0 proto kernel metric 256  pref medium
    fdaa:bb:1::1 dev nat64 proto kernel metric 256  pref medium
    fdde:ad00:beef::/64 dev wpan0 proto kernel metric 256  pref medium
    fe80::/64 dev wlan0 proto kernel metric 256  pref medium
    fe80::/64 dev eth0 proto kernel metric 256  pref medium
    fe80::/64 dev wpan0 proto kernel metric 256  pref medium
    fe80::/64 dev nat64 proto kernel metric 256  pref medium
    default via fe80::e222:4ff:fe91:86b9 dev eth0 proto ra metric 1024  expires 1685sec hoplimit 64 pref medium
    'tcpdump -i wpan0 -nv icmp6 or icmp' and ping 64:ff9b::808:808 from CLI.
    <Nothing on RaspPi>
     tcpdump -i nat64 -nv icmp6 or icmp and ping again
    <Nothing on RaspPi>
    tcpdump -i eth0 -nv icmp6 or icmp and ping
    <Nothing on RaspPi>
    We will look into adjusting the prefix length at the router.
    Mary
  • We have an AT&T router that assigned 64 bit prefixes.  We don't seem to be able to change that.  Is Thread configurable in this regard?  Is it possible to set it to use a longer prefix?
  • From this page
    NoteWhen dealing with native IPv6 connectivity, make sure you use the DHCPv6 service, and not the popular Stateless Address Autoconfiguration (SLAAC) tool. This autoconfig tool will only provide a 64-bit long prefix that is not sufficient to delegate a new 64-bit long prefix for the Thread network.
    Do they mean on the RaspPi?  Is the image I downloaded not already set up properly? How can I check?
  • The requirement is that /64 bit prefix needs to be passed to the Thread Network so the SLAAC mechanism is used for the address generation.
    I am not aware of any exceptions in that matter.
    In theory it should be possible to create additional local IPv6 network for Thread only and perform IPv6 to IPv6 translation (NAT66) to addresses from the global pool. It looks like a huge workaround and the fact that Thread nodes generate randomly their addresses with SLAAC which will not make things easier.
    Please note that this is just a theoretical consideration, I am not aware of any attempts taken.
    Typical solutions are sticking with NAT64 (with its limitation that the Thread node cannot be reached from the outside world as it does not have a globally reachable address) or contacting Internet Service Provider to provide shorter IPv6 prefix.
    Your attempts with do not look good, did you wait after executing ping on the CLI? It can take some time to see any output on the Raspberrys terminal in case of tcpdump.
    Is your configuration or image modified anyhow compared to the released versions?
    Edit. Regarding your post that appeared when I was writing mine:
    Image is configured correctly, paragraph you mentioned is about network equipment used at home or office.
    Even if your ISP delegates you prefix that is good enough, lets say /56 the router you connect Raspberry to sometimes delegates /64 to the Raspberry even if it could delegate shorter one.
    There are two ways of passing prefix to the next router/device, DHCPv6 is very configurable and can share specified address lengh and SLAAC which operates on fixed /64.
    Usually this can be configured in the router panel. Bad news is that many devices provide limited configuration or even do not lack of proper support of these features. From our experience OpenWRT custom firmware provides good support in this regard.
    To be honest issues with NAT64 bother me more as this is the configuration that works out of the box in all cases.
    I'm wondering if this can be related to your ISP or the AT&T router.
    Could you check setup with the different connection? Wi-Fi hotspot shared from the smartphone should be sufficient to check the NAT64.
    When all fails also the previous release (0.11.0) can be checked as that border router is completely different since it is based on OpenWRT not the Raspbian.
    Kind Regards,
    Piotr
  • I re-ran the tcpdum/ping tests and waited a bit.  I only got a response (and yes, delayed) for the eth0 test.
    pi@raspberrypi:/etc $ sudo tcpdump -i eth0 -nv icmp6
    tcpdump: listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
    15:39:00.763050 IP6 (hlim 255, next-header ICMPv6 (58) payload length: 112) fe80::e222:4ff:fe91:86b9 > ff02::1: [icmp6 sum ok] ICMP6, router advertisement, length 112
            hop limit 64, Flags [none], pref medium, router lifetime 1800s, reachable time 0s, retrans time 0s
              prefix info option (3), length 32 (4): 2600:xxxx:xxxx:96c0::/64, Flags [onlink, auto], valid time 1209600s, pref. time 1209600s
              route info option (24), length 24 (3):  2600:xxxx:xxxx:96c0::/60, pref=high, lifetime=1209600s
              rdnss option (25), length 24 (3):  lifetime 1200s, addr: 2600:1702:1d70:96c0::1
              mtu option (5), length 8 (1):  1500
              source link-address option (1), length 8 (1): e0:22:04:91:86:b9
    15:39:01.489607 IP6 (hlim 255, next-header ICMPv6 (58) payload length: 32) 2600:xxxx:xxxx:96c0:91d1:7b34:f74a:4e1 > ff02::1:ffbb:bcae: [icmp6 sum ok] ICMP6, neighbor solicitation, length 32, who has 2600:xxxx:xxxx:96c0:c895:87f1:1ebb:bcae
              source link-address option (1), length 8 (1): 9c:eb:e8:19:c2:b1
    15:39:01.489610 IP6 (hlim 255, next-header ICMPv6 (58) payload length: 32) 2600:xxxx:xxxx:96c0:91d1:7b34:f74a:4e1 > ff02::1:ffe0:ea4: [icmp6 sum ok] ICMP6, neighbor solicitation, length 32, who has 2600:xxxx:xxxx:96c0:ec1d:637f:b8e0:ea4
    15:39:01.489612 IP6 (hlim 255, next-header ICMPv6 (58) payload length: 32) 2600:xxxx:xxxx:96c0:91d1:7b34:f74a:4e1 > ff02::1:ff4d:341b: [icmp6 sum ok] ICMP6, neighbor solicitation, length 32, who has 2600:xxxx:xxxx:96c0:95a6:eefe:9f4d:341b
    15:39:01.489614 IP6 (hlim 255, next-header ICMPv6 (58) payload length: 32) 2600:xxxx:xxxx:96c0:91d1:7b34:f74a:4e1 > ff02::1:ff83:1906: [icmp6 sum ok] ICMP6, neighbor solicitation, length 32, who has 2600:xxxx:xxxx:06c0:d987:6590:fb83:1906
    15:39:01.489616 IP6 (hlim 255, next-header ICMPv6 (58) payload length: 32) 2600:xxxx:xxxx:96c0:91d1:7b34:f74a:4e1 > ff02::1:ff29:3c7c: [icmp6 sum ok] ICMP6, neighbor solicitation, length 32, who has 2600:xxxx:xxxx:96c0:3ddd:7acd:5029:3c7c
    15:39:01.489618 IP6 (hlim 255, next-header ICMPv6 (58) payload length: 32) 2600:xxxx:xxxx:96c0:91d1:7b34:f74a:4e1 > ff02::1:ff09:de88: [icmp6 sum ok] ICMP6, neighbor solicitation, length 32, who has 2600:xxxx:xxxx:96c0:7487:e816:d409:de88
    15:39:01.491090 IP6 (hlim 255, next-header ICMPv6 (58) payload length: 32) 2600:xxxx:xxxx:96c0:91d1:7b34:f74a:4e1 > ff02::1:ff63:8caa: [icmp6 sum ok] ICMP6, neighbor solicitation, length 32, who has 2600:xxxx:xxxx:96c0:79a8:d89e:2e63:8caa
    15:39:02.489602 IP6 (hlim 255, next-header ICMPv6 (58) payload length: 32) 2600:xxxx:xxxx:96c0:91d1:7b34:f74a:4e1 > ff02::1:ffbb:bcae: [icmp6 sum ok] ICMP6, neighbor solicitation, length 32, who has 2600:xxxx:xxxx:96c0:c895:87f1:1ebb:bcae
    15:39:02.489603 IP6 (hlim 255, next-header ICMPv6 (58) payload length: 32) 2600:xxxx:xxxx:96c0:91d1:7b34:f74a:4e1 > ff02::1:ffe0:ea4: [icmp6 sum ok] ICMP6, neighbor solicitation, length 32, who has 2600:xxxx:xxxx:96c0:ec1d:637f:b8e0:ea4
    15:39:02.490234 IP6 (hlim 255, next-header ICMPv6 (58) payload length: 32) 2600:xxxx:xxxx:96c0:91d1:7b34:f74a:4e1 > ff02::1:ff4d:341b: [icmp6 sum ok] ICMP6, neighbor solicitation, length 32, who has 2600:xxxx:xxxx:96c0:95a6:eefe:9f4d:341b
    15:39:02.490237 IP6 (hlim 255, next-header ICMPv6 (58) payload length: 32) 2600:xxxx:xxxx:96c0:91d1:7b34:f74a:4e1 > ff02::1:ff83:1906: [icmp6 sum ok] ICMP6, neighbor solicitation, length 32, who has 2600:xxxx:xxxx:96c0:d987:6590:fb83:1906
    15:39:02.490239 IP6 (hlim 255, next-header ICMPv6 (58) payload length: 32) 2600:xxxx:xxxx:96c0:91d1:7b34:f74a:4e1 > ff02::1:ff29:3c7c: [icmp6 sum ok] ICMP6, neighbor solicitation, length 32, who has 2600:xxxx:xxxx:96c0:3ddd:7acd:5029:3c7c
    15:39:02.490241 IP6 (hlim 255, next-header ICMPv6 (58) payload length: 32) 2600:xxxx:xxxx:96c0:91d1:7b34:f74a:4e1 > ff02::1:ff09:de88: [icmp6 sum ok] ICMP6, neighbor solicitation, length 32, who has 2600:xxxx:xxxx:96c0:7487:e816:d409:de88
    15:39:02.490242 IP6 (hlim 255, next-header ICMPv6 (58) payload length: 32) 2600:xxxx:xxxx:96c0:91d1:7b34:f74a:4e1 > ff02::1:ff63:8caa: [icmp6 sum ok] ICMP6, neighbor solicitation, length 32, who has 2600:xxxx:xxxx:96c0:79a8:d89e:2e63:8caa
    Similar messages appeared periodically after these.
    No, I have not modified the RaspPi at all, except to install tcpdump.
    I will try WiFi on the Pi.
