Hello
Im trying to find a way to send multiple messages (unreliable) in a row within a Mesh network in order to measure time taken,
Im using a modified version of the light switch example project files where the client node sends specified(e.g. 20) number of messages.
To do this Im simply pressing a board button that triggers a for-loop where I use access_model_publish() and an error check, but I receive NRF_ERROR_NO_MEM on about 16/20 messages and the remaining is successfully sent. Do I need to release resources to other event or something? how would I do this
Ive tried searching for other doing the same but cant find any answers except for using the health model to measure throughput but that's not what I'm after
access_message_tx_t message; void msg_set(uint8_t *msg, uint16_t length){ send_command_msg_t command_msg; command_msg.length = length; strncpy(command_msg.command, msg, length); message.opcode.opcode = SEND_COMMAND; message.opcode.company_id = ACCESS_COMPANY_ID_NORDIC; message.p_buffer = (const uint8_t*) &command_msg; message.length = length; } void msg_send(){ for(int i = 0;i<20;i++){ status = send_command_client(&m_clients[0]); if (status == NRF_ERROR_INVALID_STATE || status == NRF_ERROR_NO_MEM || status == NRF_ERROR_BUSY) { __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Cannot send. Device is busy: 0x%08lX \r\n", status); } else { ERROR_CHECK(status); } nrf_delay_ms(50); } } uint32_t send_command_client(simple_on_off_client_t *p_client) { uint32_t status = NRF_SUCCESS; status = access_model_publish(p_client->model_handle, &message); return status; }
Tried with different delays between each send as well from 0 to 50micro up to 500 ms
