How to add multiple elements in a server node?
I am experimenting with the mesh light-switch example. I want to control two LEDs on a single node using the SimpleOnOff model. I know I should add a separate element and add the second SimpleOnOff model in it, but how do I do it? Is there any sample code which you can point me to?
  • I did this in the server application application. When I press button 2 on the server board, LED 2 gets lit up, but now how do I control it from button 2 of my client board?
    diff --git a/Tools/nrf5_SDK_for_Mesh_v2.0.1_src/examples/light_switch/server/include/nrf_mesh_config_app.h b/Tools/nrf5_SDK_for_Mesh_v2.0.1_src/examples/light_switch/server/include/nrf_mesh_config_app.h
    index 9d70cc1..312ba5f 100644
    --- a/Tools/nrf5_SDK_for_Mesh_v2.0.1_src/examples/light_switch/server/include/nrf_mesh_config_app.h
    +++ b/Tools/nrf5_SDK_for_Mesh_v2.0.1_src/examples/light_switch/server/include/nrf_mesh_config_app.h
    @@ -82,7 +82,7 @@
      * @note This value has to be greater than two to fit the configuration and health models,
      * plus the number of models needed by the application.
    -#define ACCESS_MODEL_COUNT (3)
    +#define ACCESS_MODEL_COUNT (4)
      * The number of elements in the application.
    @@ -90,7 +90,7 @@
      * @warning If the application is to support multiple _instances_ of the _same_ model, they cannot
      * belong in the same element and a separate element is needed for the new instance.
    -#define ACCESS_ELEMENT_COUNT (1)
    +#define ACCESS_ELEMENT_COUNT (2)
      * The number of allocated subscription lists for the application.
    diff --git a/Tools/nrf5_SDK_for_Mesh_v2.0.1_src/examples/light_switch/server/src/main.c
    b/Tools/nrf5_SDK_for_Mesh_v2.0.1_src/examples/light_switch/server/src/main.c
    index 1048083..dabafd7 100644
    --- a/Tools/nrf5_SDK_for_Mesh_v2.0.1_src/examples/light_switch/server/src/main.c
    +++ b/Tools/nrf5_SDK_for_Mesh_v2.0.1_src/examples/light_switch/server/src/main.c
    @@ -57,12 +57,17 @@
     #define RTT_INPUT_POLL_PERIOD_MS (100)
     #define LED_PIN_NUMBER           (BSP_LED_0)
     #define LED_PIN_MASK             (1u << LED_PIN_NUMBER)
    +#define LED_PIN_NUMBER_1           (BSP_LED_1)
    +#define LED_PIN_MASK_1             (1u << LED_PIN_NUMBER_1)
     #define LED_BLINK_INTERVAL_MS    (200)
     #define LED_BLINK_CNT_START      (2)
     #define LED_BLINK_CNT_RESET      (3)
     #define LED_BLINK_CNT_PROV       (4)
     static simple_on_off_server_t m_server;
    +static simple_on_off_server_t m_server1;
     static bool                   m_device_provisioned;
     static void provisioning_complete_cb(void)
    @@ -89,6 +94,21 @@ static bool on_off_server_set_cb(const simple_on_off_server_t * p_server, bool v
         return value;
    +static bool on_off_server_get_cb_1(const simple_on_off_server_t * p_server)
    +    return hal_led_pin_get(LED_PIN_NUMBER);
    +static bool on_off_server_set_cb_1(const simple_on_off_server_t * p_server, bool value)
    +    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Got SET command to %u\n", value);
    +    hal_led_pin_set(LED_PIN_NUMBER, value);
    +    return value;
     static void node_reset(void)
         __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset  -----\n");
    @@ -122,6 +142,16 @@ static void button_event_handler(uint32_t button_number)
    +        case 1:
    +            uint8_t value = !hal_led_pin_get(LED_PIN_NUMBER_1);
    +            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "User action \n");
    +            hal_led_pin_set(LED_PIN_NUMBER_1, value);
    +            (void)simple_on_off_server_status_publish(&m_server1, value);
    +            break;
             /* Initiate node reset */
             case 3:
    @@ -151,7 +181,10 @@ static void models_init_cb(void)
         m_server.get_cb = on_off_server_get_cb;
         m_server.set_cb = on_off_server_set_cb;
         ERROR_CHECK(simple_on_off_server_init(&m_server, 0));
    -    ERROR_CHECK(access_model_subscription_list_alloc(m_server.model_handle));
    +    m_server1.get_cb = on_off_server_get_cb_1;
    +    m_server1.set_cb = on_off_server_set_cb_1;
    +    ERROR_CHECK(simple_on_off_server_init(&m_server1, 1));
     static void mesh_init(void)
  • I have been studying the server, client and provisioner application since yesterday, I understand that I would need to do some changes in the provisioner application. Can someone from Nordic respond to this question??
    Yes, you have to make some changes in the provisioner application. Seems like the code in the server application is correct, I suggest you to have a look at this post.
  • Finally I was able to get it working... Here are the changes!
    diff --git a/Tools/nrf5_SDK_for_Mesh_v2.0.1_src/examples/light_switch/provisioner/src/node_setup.c b/Tools/nrf5_SDK_for_Mesh_v2.0.1_src/examples/light_switch/provisioner/src/node_setup.c
    index d9a6576..7ed5c85 100644
    --- a/Tools/nrf5_SDK_for_Mesh_v2.0.1_src/examples/light_switch/provisioner/src/node_setup.c
    +++ b/Tools/nrf5_SDK_for_Mesh_v2.0.1_src/examples/light_switch/provisioner/src/node_setup.c
    @@ -144,6 +144,7 @@ static const config_steps_t server1_server2_config_steps[] =
         NODE_SETUP_CONFIG_APPKEY_ADD,
         NODE_SETUP_CONFIG_APPKEY_BIND_HEALTH,
         NODE_SETUP_CONFIG_APPKEY_BIND_ONOFF_SERVER,
    +    NODE_SETUP_CONFIG_APPKEY_BIND_ONOFF_SERVER,
         NODE_SETUP_CONFIG_PUBLICATION_HEALTH,
         NODE_SETUP_CONFIG_PUBLICATION_ONOFF_SERVER1_2,
         NODE_SETUP_CONFIG_SUBSCRIPTION_ONOFF_SERVER,
    @@ -340,6 +341,7 @@ static void config_step_execute(void)
         uint32_t status;
         static uint16_t model_element_addr = 0;
    +    static bool next_element = false;
         /* This example configures the provisioned nodes in the following way
          * Node 0: Client node (Switch)
    @@ -394,16 +396,34 @@ static void config_step_execute(void)
             /* Bind the On/Off server to the application key: */
             case NODE_SETUP_CONFIG_APPKEY_BIND_ONOFF_SERVER:
    -            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App key bind: Simple On/Off server\n");
    -            access_model_id_t model_id;
    -            model_id.company_id = ACCESS_COMPANY_ID_NORDIC;
    -            model_id.model_id = SIMPLE_ON_OFF_SERVER_MODEL_ID;
    -            uint16_t element_address = m_current_node_addr;
    -            retry_on_fail(config_client_model_app_bind(element_address, m_appkey_idx, model_id));
    -            static const uint8_t exp_status[] = {ACCESS_STATUS_SUCCESS};
    -            expected_status_set(CONFIG_OPCODE_MODEL_APP_STATUS, sizeof(exp_status), exp_status);
    -            break;
    +            if (!next_element)
    +              __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Configure first element\n");
    +              access_model_id_t model_id;
    +              model_id.company_id = ACCESS_COMPANY_ID_NORDIC;
    +              model_id.model_id = SIMPLE_ON_OFF_SERVER_MODEL_ID;
    +              uint16_t element_address = m_current_node_addr;
    +              retry_on_fail(config_client_model_app_bind(element_address, m_appkey_idx, model_id));
    +              static const uint8_t exp_status[] = {ACCESS_STATUS_SUCCESS};
    +              expected_status_set(CONFIG_OPCODE_MODEL_APP_STATUS, sizeof(exp_status), exp_status);
    +              next_element = true;
    +              break;
    +            else
    +              __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Configure next element\n");
    +              uint16_t element_address = m_current_node_addr + 1;
    +              next_element = false;
    +              break;
             /* Bind the On/Off client to the application key: */
    @@ -82,7 +82,7 @@
    @@ -90,7 +90,7 @@
    diff --git a/Tools/nrf5_SDK_for_Mesh_v2.0.1_src/examples/light_switch/server/src/main.c b/Tools/nrf5_SDK_for_Mesh_v2.0.1_src/examples/light_switch/server/src/main.c
    index 1048083..1367e26 100644
    @@ -57,12 +57,17 @@
         return value;
    +    return hal_led_pin_get(LED_PIN_NUMBER_1);
    +    return value;
    +        case 1:
    +            break;
             case 3:
    Note that these changes are just to demonstrate the regions of code that you need to change for adding multiple elements. I just checked this with only 1 server board. The light switch client application already has multiple nodes in it(for 4 switches), I found it very helpful.
