Hi There,
I am trying to build an application that uses UART 0 (for debugging) and UART 1 (to read data over from a separate hardware). Simple objective is to send "Hello nrf_serial" on both UART and receive them at the other end. My code is given below and have attached it too. The issue that I am facing right now is, when I enable both UART, no data is received on both.
However, when only UART1 is enabled, I could receive data on UART 1. I enable and disable UART 0 and UART 1 using macros
Am I doing something wrong here?
Any help / pointer will be highly appreciated.
NOTE: I am using
nrf5_SDK_v15.0.0 and evaluation board with PCA10056.
Attached is main.c and sdk_config.h
Amol
//#define UART_0 1 #define UART_1 1
Full Code
#include <stdint.h> #include <stdbool.h> #include <stddef.h> #include "nrf.h" #include "nrf_drv_clock.h" #include "nrf_gpio.h" #include "nrf_delay.h" #include "nrf_log.h" #include "nrf_log_ctrl.h" #include "nrf_drv_power.h" #include "nrf_serial.h" #include "app_timer.h" #include "app_error.h" #include "app_util.h" #include "boards.h" /** @file * @defgroup nrf_serial_example main.c * @{ * @ingroup nrf_serial_example * @brief Example of @ref nrf_serial usage. Simple loopback. * */ #define OP_QUEUES_SIZE 3 #define APP_TIMER_PRESCALER NRF_SERIAL_APP_TIMER_PRESCALER static void sleep_handler(void) { __WFE(); __SEV(); __WFE(); } //#define UART_0 1 #define UART_1 1 #ifdef UART_0 NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uart0_drv_config, RX_PIN_NUMBER, TX_PIN_NUMBER, RTS_PIN_NUMBER, CTS_PIN_NUMBER, //SER_APP_RX_PIN, SER_APP_TX_PIN, //SER_APP_RTS_PIN, SER_APP_CTS_PIN, NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED, NRF_UART_BAUDRATE_115200, UART_DEFAULT_CONFIG_IRQ_PRIORITY); #endif //UART_0 NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uart1_drv_config, //RX_PIN_NUMBER, TX_PIN_NUMBER, //RTS_PIN_NUMBER, CTS_PIN_NUMBER, SER_APP_RX_PIN, SER_APP_TX_PIN, SER_APP_RTS_PIN, SER_APP_CTS_PIN, NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED, NRF_UART_BAUDRATE_115200, UART_DEFAULT_CONFIG_IRQ_PRIORITY); #define SERIAL_FIFO_TX_SIZE 32 #define SERIAL_FIFO_RX_SIZE 32 #ifdef UART_0 NRF_SERIAL_QUEUES_DEF(serial_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE); #endif //UART_0 NRF_SERIAL_QUEUES_DEF(serial_queues1, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE); #define SERIAL_BUFF_TX_SIZE 1 #define SERIAL_BUFF_RX_SIZE 1 #ifdef UART_0 NRF_SERIAL_BUFFERS_DEF(serial_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE); #endif // UART_0 NRF_SERIAL_BUFFERS_DEF(serial_buffs1, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE); #ifdef UART_0 NRF_SERIAL_CONFIG_DEF(serial_config, NRF_SERIAL_MODE_DMA, &serial_queues, &serial_buffs, NULL, sleep_handler); #endif // UART_0 NRF_SERIAL_CONFIG_DEF(serial_config1, NRF_SERIAL_MODE_DMA, &serial_queues1, &serial_buffs1, NULL, sleep_handler); NRF_SERIAL_UART_DEF(serial_uart1, 1); #ifdef UART_0 NRF_SERIAL_UART_DEF(serial_uart, 0); #endif //UART_0 int main(void) { ret_code_t ret; ret = nrf_drv_clock_init(); APP_ERROR_CHECK(ret); ret = nrf_drv_power_init(NULL); APP_ERROR_CHECK(ret); nrf_drv_clock_lfclk_request(NULL); ret = app_timer_init(); APP_ERROR_CHECK(ret); // Initialize LEDs and buttons. bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS); #ifdef UART_0 ret = nrf_serial_init(&serial_uart, &m_uart0_drv_config, &serial_config); APP_ERROR_CHECK(ret); static char tx_message[] = "Hello nrf_serial!\n\r"; ret = nrf_serial_write(&serial_uart, tx_message, strlen(tx_message), NULL, NRF_SERIAL_MAX_TIMEOUT); APP_ERROR_CHECK(ret); #if 0 while (true) { char c; ret = nrf_serial_read(&serial_uart, &c, sizeof(c), NULL, 1000); if (ret != NRF_SUCCESS) { continue; } (void)nrf_serial_write(&serial_uart, &c, sizeof(c), NULL, 0); (void)nrf_serial_flush(&serial_uart, 0); } #endif #endif // UART_0 #ifdef UART_1 ret = nrf_serial_init(&serial_uart1, &m_uart1_drv_config, &serial_config1); APP_ERROR_CHECK(ret); static char tx_message1[] = "Hello nrf_serial U1!\n\r"; ret = nrf_serial_write(&serial_uart1, tx_message1, strlen(tx_message1), NULL, NRF_SERIAL_MAX_TIMEOUT); APP_ERROR_CHECK(ret); while (true) { char c; ret = nrf_serial_read(&serial_uart1, &c, sizeof(c), NULL, 1000); if (ret != NRF_SUCCESS) { continue; } (void)nrf_serial_write(&serial_uart1, &c, sizeof(c), NULL, 0); (void)nrf_serial_flush(&serial_uart1, 0); } #endif // UART_1 }
/** * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA * * All rights reserved. * * Redistribution and use in source and binary forms, with or without modification, * are permitted provided that the following conditions are met: * * 1. Redistributions of source code must retain the above copyright notice, this * list of conditions and the following disclaimer. * * 2. Redistributions in binary form, except as embedded into a Nordic * Semiconductor ASA integrated circuit in a product or a software update for * such product, must reproduce the above copyright notice, this list of * conditions and the following disclaimer in the documentation and/or other * materials provided with the distribution. * * 3. Neither the name of Nordic Semiconductor ASA nor the names of its * contributors may be used to endorse or promote products derived from this * software without specific prior written permission. * * 4. This software, with or without modification, must only be used with a * Nordic Semiconductor ASA integrated circuit. * * 5. Any software provided in binary form under this license must not be reverse * engineered, decompiled, modified and/or disassembled. * * THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR ASA "AS IS" AND ANY EXPRESS * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES * OF MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE ARE * DISCLAIMED. IN NO EVENT SHALL NORDIC SEMICONDUCTOR ASA OR CONTRIBUTORS BE * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE * GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ #include <stdint.h> #include <stdbool.h> #include <stddef.h> #include "nrf.h" #include "nrf_drv_clock.h" #include "nrf_gpio.h" #include "nrf_delay.h" #include "nrf_log.h" #include "nrf_log_ctrl.h" #include "nrf_drv_power.h" #include "nrf_serial.h" #include "app_timer.h" #include "app_error.h" #include "app_util.h" #include "boards.h" /** @file * @defgroup nrf_serial_example main.c * @{ * @ingroup nrf_serial_example * @brief Example of @ref nrf_serial usage. Simple loopback. * */ #define OP_QUEUES_SIZE 3 #define APP_TIMER_PRESCALER NRF_SERIAL_APP_TIMER_PRESCALER static void sleep_handler(void) { __WFE(); __SEV(); __WFE(); } //#define UART_0 1 #define UART_1 1 #ifdef UART_0 NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uart0_drv_config, RX_PIN_NUMBER, TX_PIN_NUMBER, RTS_PIN_NUMBER, CTS_PIN_NUMBER, //SER_APP_RX_PIN, SER_APP_TX_PIN, //SER_APP_RTS_PIN, SER_APP_CTS_PIN, NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED, NRF_UART_BAUDRATE_115200, UART_DEFAULT_CONFIG_IRQ_PRIORITY); #endif //UART_0 NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uart1_drv_config, //RX_PIN_NUMBER, TX_PIN_NUMBER, //RTS_PIN_NUMBER, CTS_PIN_NUMBER, SER_APP_RX_PIN, SER_APP_TX_PIN, SER_APP_RTS_PIN, SER_APP_CTS_PIN, NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED, NRF_UART_BAUDRATE_115200, UART_DEFAULT_CONFIG_IRQ_PRIORITY); #define SERIAL_FIFO_TX_SIZE 32 #define SERIAL_FIFO_RX_SIZE 32 #ifdef UART_0 NRF_SERIAL_QUEUES_DEF(serial_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE); #endif //UART_0 NRF_SERIAL_QUEUES_DEF(serial_queues1, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE); #define SERIAL_BUFF_TX_SIZE 1 #define SERIAL_BUFF_RX_SIZE 1 #ifdef UART_0 NRF_SERIAL_BUFFERS_DEF(serial_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE); #endif // UART_0 NRF_SERIAL_BUFFERS_DEF(serial_buffs1, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE); #ifdef UART_0 NRF_SERIAL_CONFIG_DEF(serial_config, NRF_SERIAL_MODE_DMA, &serial_queues, &serial_buffs, NULL, sleep_handler); #endif // UART_0 NRF_SERIAL_CONFIG_DEF(serial_config1, NRF_SERIAL_MODE_DMA, &serial_queues1, &serial_buffs1, NULL, sleep_handler); NRF_SERIAL_UART_DEF(serial_uart1, 1); #ifdef UART_0 NRF_SERIAL_UART_DEF(serial_uart, 0); #endif //UART_0 int main(void) { ret_code_t ret; ret = nrf_drv_clock_init(); APP_ERROR_CHECK(ret); ret = nrf_drv_power_init(NULL); APP_ERROR_CHECK(ret); nrf_drv_clock_lfclk_request(NULL); ret = app_timer_init(); APP_ERROR_CHECK(ret); // Initialize LEDs and buttons. bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS); #ifdef UART_0 ret = nrf_serial_init(&serial_uart, &m_uart0_drv_config, &serial_config); APP_ERROR_CHECK(ret); static char tx_message[] = "Hello nrf_serial!\n\r"; ret = nrf_serial_write(&serial_uart, tx_message, strlen(tx_message), NULL, NRF_SERIAL_MAX_TIMEOUT); APP_ERROR_CHECK(ret); #if 0 while (true) { char c; ret = nrf_serial_read(&serial_uart, &c, sizeof(c), NULL, 1000); if (ret != NRF_SUCCESS) { continue; } (void)nrf_serial_write(&serial_uart, &c, sizeof(c), NULL, 0); (void)nrf_serial_flush(&serial_uart, 0); } #endif #endif // UART_0 #ifdef UART_1 ret = nrf_serial_init(&serial_uart1, &m_uart1_drv_config, &serial_config1); APP_ERROR_CHECK(ret); static char tx_message1[] = "Hello nrf_serial U1!\n\r"; ret = nrf_serial_write(&serial_uart1, tx_message1, strlen(tx_message1), NULL, NRF_SERIAL_MAX_TIMEOUT); APP_ERROR_CHECK(ret); while (true) { char c; ret = nrf_serial_read(&serial_uart1, &c, sizeof(c), NULL, 1000); if (ret != NRF_SUCCESS) { continue; } (void)nrf_serial_write(&serial_uart1, &c, sizeof(c), NULL, 0); (void)nrf_serial_flush(&serial_uart1, 0); } #endif // UART_1 } /** @} */
