I get strange error. p_evt_write data array should contains 3 values but contain only one (first).
Please take a look:
What can be the reason and how to fix it?
Thanks!
this is like that because the data only points to the first byte (how it is defined in ble_gatts.h) , if you want to read the following bytes in the debugger you can just go to the memory location, and (0x20002468 in this case) and read the following two bytes.
