Changing advertising modes from IDLE to FAST SDK V15.0
I am migrating from SDK v14.2.0 to v15.0.0 and from S132 to S112 (v6) using the NRF52810. I have mostly everything migrated, but a functionality that worked before does not seem to behave correctly now and have not been able to find the root cause.
I am using a whitelist, but if there are no peers, the device is started with:
ble_advertising_start(&m_advertising, BLE_ADV_MODE_IDLE);
and then after a user button press, the device will then switch to advertising without a whitelist:
    ret_code_t err_code;
    m_advertising.adv_mode_current = BLE_ADV_MODE_FAST;
    m_advertising.adv_modes_config.ble_adv_fast_timeout = APP_ADV_NOWHITELEST_TIMEOUT_IN_SECONDS;
but that results in an error code 7 (NRF_ERROR_INVALID_PARAM).
If the device starts out in BLE_ADV_MODE_FAST, instead of BLE_ADV_MODE_IDLE, calling ble_advertising_restart_without_whitelist(), returns correctly.
Any suggestions?
Thank you.
  • FormerMember
    0 FormerMember in reply to amorgan
    It  should not be necessary to comment out flags_set.
    When the advertising mode is BLE_ADV_MODE_FAST, could you upload a snippet of the current advertising parameters, like then one I have added below?
    (I have tested a simple example going from BLE_ADV_MODE_IDLE to BLE_ADV_MODE_FAST and that works. I think it's hard to see just from the code what is wrong, when the problem is invalid parameters, it is better to see what the parameters are.)
  • The file main.c I linked duplicates the issue, which occurs when it is in idle then ble_advertising_restart_without_whitelist is called to switch to fast mode. Would you be able to evaluate this?
    I will send the results of your request when i get back in the office.
  • FormerMember
    I cannot see directly from the main.c what is causing the issue. When you have the failing and working parameters avaiable, please upload them here.
  • Sorry for the delay, Attached are the before and after. Note I get the error when ble_advertising_restart_without_whitelist calls flags_set.
    Before update m_advertising coming from IDLE:
    Before updating
    Before ble_advertising_restart_without_whitelist calls flags_set:
    Before flags_set
    After flags_set returns Error (0x07):
    After flags_set
    LLet me know if this helps.
    TThank you.
  • static void sleep_mode_enter(void)
        m_advertising.adv_params.duration = 10000;
        m_advertising.adv_params.interval = APP_ADV_INTERVAL;
    Hi amorgan, try the code above instead. You were setting configs that are only being read during ble_advertising_init().
    On a related note, if you are not using whitelist, you should never have to call ble_advertising_restart...
    instead you can just call ble_advertising_start(&m_advertising,APP_ADV_MODE_FAST) when you get the idle event.
    Good luck!
