Nrf52832 + SDK 12.3 + SD 132 : TWI Not Working. No Output
Hi All,
I am trying to use TWI on NRF52832 using SDK 12.3 + SD132 but without any success.
For some reason, there is no signal coming out on the configured SDA + SCL pins. I checked using a logic analyzer. I tried using both the blocking and non blocking mode without any success. The pins that I am using are
SDA : 13
SCL : 12
My sdk_config.h section is
// <e> TWI_ENABLED - nrf_drv_twi - TWI/TWIM peripheral driver
#ifndef TWI_ENABLED
#define TWI_ENABLED 1
#if  TWI_ENABLED
// <o> TWI_DEFAULT_CONFIG_FREQUENCY  - Frequency
// <26738688=> 100k
// <67108864=> 250k
// <104857600=> 400k
#ifndef TWI_DEFAULT_CONFIG_FREQUENCY
#define TWI_DEFAULT_CONFIG_FREQUENCY 26738688
// <q> TWI_DEFAULT_CONFIG_CLR_BUS_INIT  - Enables bus clearing procedure during init
#ifndef TWI_DEFAULT_CONFIG_CLR_BUS_INIT
#define TWI_DEFAULT_CONFIG_CLR_BUS_INIT 0
// <q> TWI_DEFAULT_CONFIG_HOLD_BUS_UNINIT  - Enables bus holding after uninit
#ifndef TWI_DEFAULT_CONFIG_HOLD_BUS_UNINIT
#define TWI_DEFAULT_CONFIG_HOLD_BUS_UNINIT 0
// <o> TWI_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
// <4=> 4
// <5=> 5
// <6=> 6
// <7=> 7
#ifndef TWI_DEFAULT_CONFIG_IRQ_PRIORITY
#define TWI_DEFAULT_CONFIG_IRQ_PRIORITY 7
// <e> TWI0_ENABLED - Enable TWI0 instance
#ifndef TWI0_ENABLED
#define TWI0_ENABLED 1
#if  TWI0_ENABLED
// <q> TWI0_USE_EASY_DMA  - Use EasyDMA (if present)
#ifndef TWI0_USE_EASY_DMA
#define TWI0_USE_EASY_DMA 1
#endif //TWI0_ENABLED
// </e>
// <e> TWI1_ENABLED - Enable TWI1 instance
#ifndef TWI1_ENABLED
#define TWI1_ENABLED 0
#if  TWI1_ENABLED
// <q> TWI1_USE_EASY_DMA  - Use EasyDMA (if present)
#ifndef TWI1_USE_EASY_DMA
#define TWI1_USE_EASY_DMA 0
#endif //TWI1_ENABLED
// </e>
// <e> TWI_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef TWI_CONFIG_LOG_ENABLED
#define TWI_CONFIG_LOG_ENABLED 0
#if  TWI_CONFIG_LOG_ENABLED
// <o> TWI_CONFIG_LOG_LEVEL  - Default Severity level
// <0=> Off
// <1=> Error
// <2=> Warning
// <3=> Info
// <4=> Debug
#ifndef TWI_CONFIG_LOG_LEVEL
#define TWI_CONFIG_LOG_LEVEL 3
// <o> TWI_CONFIG_INFO_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef TWI_CONFIG_INFO_COLOR
#define TWI_CONFIG_INFO_COLOR 0
// <o> TWI_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef TWI_CONFIG_DEBUG_COLOR
#define TWI_CONFIG_DEBUG_COLOR 0
#endif //TWI_CONFIG_LOG_ENABLED
// </e>
#endif //TWI_ENABLED
// </e>
My TWI initialization code is
bool INTERNAL_I2C_Init(void)
    //INITIALZE INTERNAL_I2CTWIMASTER_TWI_INST_USE_EASY_DMA
    //ONLY INITIALIZE IF NOT ALREADY DONE
    if(s_initialized)
        return true;
    //INITIALIZE DRIVER
    ret_code_t ret;
    const nrf_drv_twi_config_t config = {
                                            .scl = BSP_EXTERNAL_DS3231_SCL,
                                            .sda = BSP_EXTERNAL_DS3231_SDA,
                                            .frequency = NRF_TWI_FREQ_100K,
                                            .interrupt_priority = APP_IRQ_PRIORITY_LOW,
                                            .clear_bus_init = false
    do
        ret = nrf_drv_twi_init(&s_internal_twi_handle,
                                &config,
                                s_internal_i2c_event_handler,
                                NULL);
        if(ret != NRF_SUCCESS)
        nrf_delay_ms(2000);
        nrf_drv_twi_enable(&s_internal_twi_handle);
        nrf_delay_ms(2000);
        UTIL_DebugPrint(MODULE_NAME_I2C"%s OK\n", __FUNCTION__);
        s_initialized = true;
        return true;
    }while(0);
    UTIL_DebugPrint(MODULE_NAME_I2C"%s FAIL\n", __FUNCTION__);
    return false;
and the write function is
bool INTERNAL_I2C_WriteData(uint8_t i2c_add, uint8_t reg_add, uint8_t* buff, uint8_t len)
    //SEND THE SPECIFIED DATA OF SPECIFIED LENGTH TO THE SPECIFIED REGISTER ADDRESS
    //THROUGH I2C INTERFACE
    //WAIT FOR ONGOING OPERATOIN TO FINISH
    while(s_operation_ongoing)
    ret_code_t ret;
    uint8_t final_data[len + 1];
    //CREATE DATA BUFFER
    final_data[0] = reg_add;
    memcpy(&final_data[1], (const void * restrict)buff, len);
    UTIL_DebugPrint(MODULE_NAME_I2C"A\n");
    //SLA+W + REGISTER_ADDRESS + WRITE_DATA + STOP
    s_operation_ongoing = true;
    ret = nrf_drv_twi_tx(&s_internal_twi_handle,
                            i2c_add,
                            final_data,
                            (len + 1),
                            false);
    UTIL_DebugPrint(MODULE_NAME_I2C"tx ret code %u\n", ret);
        return false;
    UTIL_DebugPrint(MODULE_NAME_I2C"B\n");
    return true;
When I write some data to the twi device (DS3231), the i2c write function returns with the data is never actually sent out. I checked the i2c device and it is working fine. I am able to communicate to it using bus pirate.
Not sure what I could be doing wrong here. Any help is appreciated.
