The slow SPI transfer and interrupt issue
Hello tech support!
I am using the built-in SPI to transfer the data. Also, I adopted the "timer" example in the SDK for handling the SPI transfer.
However, it seems that the SPI may be too slow and too much time is spent in the interrupt. When the timer interval is set as 10ms, the SPI transfer can run normally for 10-20mins then the transmitting string would be destroyed and fragmented.
I have tried two method for SPI transfer. First one is the example SPI code given in the SDK, and second one is the SPI_master_fast method which is given in one of the post.
However, it seems both of them fails.
May I ask if there is anyway to speed up the SPI transfer?
Moreover, I am also wondering if there is any other interrupt which can slow down the SPI transfer which might be in the SoftDevice or any built-in application?
Many thanks!
