Programming nrf52832
I am using custom board with nRF52832 and Keil uVision5 as IDE. I started with simple example which is just to ON the LEDs.
Code(all necessary header files are added) :
int main(void) {
        nrf_gpio_cfg_output(17);
        nrf_gpio_cfg_output(18);
        nrf_gpio_pin_write(17,1);
        nrf_gpio_pin_write(18,1);   }
I flashed the chip and that was shown successful in build output in keil. I even checked temp.hex file and all lines were FFFFF....(according to this answer by tesc)
But LEDs are not glowing. I checked GPIO pins with multimeter and they weren't even high(value 1).
So, what may be the problem? What should I check/do?
